Nothing used in regular service AFAIK, but there are all sorts of ways that a set can get reversed around Birmingham. Also near Glasgow, and I think the Newton-le-Willows electification creates a possible (if unlikely) electrified loop through Manchester.Very occasionally the Manchester - London Euston service is in reverse formation. How does this happen? Is there a route which is a loop instead of a terminus or is there just one set on the network thats back to front?!?!
Normally happens more on a Monday after weekend diversions which might not actually have to be an electrified route!
They do try and get the trains turned back around as quickly as is practical.
I don't get what people mean by reverse formation here?![]()
"1st class at the London end" is normal for, as far as I know:
Greater Anglia: Norwich Mark 3 sets (with the loco at the 1st class end),
EMT: Meridians and HSTs
With the two Fort William sleeping cars in the Highland sleeper, the first class coach is normally the last coach at the country end with the second class being the second to last and nearer to London."1st class at the London end" is normal for, as far as I know:
Scotrail: Sleepers, each "half train".
Loco on GA is always at the London end.
This is unusual because most main lines into London the loco is at the country end (GWML/WCML/MML/ECML). This was because the main depot was in London, so its easy to perform a loco swap.
However, the main depot for the GAML is Crown Point, to the south of Norwich station, so it is easier this way
Er on the GWML, the locos are usually on both ends........
Just musing - whatever the practicalities of the "1st Class at the London end" arrangement actually are, I wonder what kind of message this tradition may be sending unintentionally to the rest of the country?
Of course, the other way of looking at it is that, as the "locomotive" (or whatever passes for one these days) is at the front or "country" end of the train, the 1st class accommodation is at the *rse end of the train coming from London.![]()
Yes, well that's one way of putting it,
What about Grand Central?, I have seen some of their trains with FC at the Front, or in some cases one at the front and one at the back?
I think Hull trains FC and some non 125 FGW may be in the middle.
Does a 12 car 455 split into 3 parts ?
Not in the days of 47's and earlier....
Does anyone know why SWT have stopped turning their 444s back the right way?
They used to be quite good at this and I'd see only the odd one on a monday morning, but since about Christmas time roughly half the fleet is running in reverse.
