Restriction code 2C and Break in Journey
northwichcat
23 Jan 2009
Northwich
Am I right in thinking restriction code 2C, on a northbound journey from London Euston, only applies for leaving London Euston? For example, I could catch a weekday 14:12 London Euston to Stoke, break my journey, and recommence it at any time?
The relevant bit seems to be
Not valid on trains timed to depart:
  • London Euston after 04:29 and before 09:26 or after 15:00 and before 18:45 (Restrictions do not apply on Fridays)
bakerstreet
29 Nov 2009
I read it that if the train has departed London Euston at a restricted time, a ticket valid to board at Euston (or Watford Jn or Milton Keynes or the other stations listed) cannot be used on that train throughout, even if you board it north of the stations listed.
You mention weekdays. Note 2C doesn’t apply on Fridays
northwichcat
23 Jan 2009
Northwich
I suppose that makes sense. Otherwise anyone with an Off Peak ticket on an Avanti train could claim they broke their journey at the previous station.
However, would that not mean it only applies to London services. Therefore, if the break in journey is at Stoke or Crewe there would be no issue joining a XC, Northern, WMT or TfW Rail service to complete the journey?
bakerstreet
29 Nov 2009
I’d have to reread the restriction to ensure that’s not also captured but your logic is correct.
From memory there are still off peak tickets from north of Rugby / midlands to destinations further north which essentially have almost no restrictions so guards should be used to that.
Re XC, note the restrictions in 2C on trains timed to depart Reading.
Benjwri
16 Jan 2022
In general the advised rule to follow is that if you would’ve joined a service from a train that isn’t valid in your ticket, had you not broken your journey, it isn’t valid after the break.
It isn’t written anywhere, but you’re going to have a hard time convincing anyone on the group to let you through a gateline, or not to penalty fare you.
northwichcat
23 Jan 2009
Northwich
I'm not attempting to find a loophole to exploit. I've already purchased an Off Peak Return ticket for a route that already involves changing to a Northern service at Stockport, with restriction code 2C. Something has come up that may mean I need to break my journey between Stoke and Stockport.
I notice restriction code 2V says an overnight break in journey is permitted but in that instance you can't recommence your journey before 09:30 on a weekday. That's nice and clear.
Restriction code ND has the infamous no starting your journey or joining a connecting train between 16:00 and 18:30, which creates conflict when there's a "short notice change to the timetable".
For restriction code 2C it doesn't say you can't break your journey, or if you break it you can't recommence it between certain times. @bakerstreet Thanks for your input.
You can't be issued with a Penalty Fare for travelling at a restricted time on an Off-Peak ticket. You simply have to pay the difference in fare.
As for the OP's question, it is somewhat ambiguous. But in practical terms, I would doubt there would be any issue boarding an evening "peak" train north of Watford, as the wording for Milton Keynes for example doesn't include any evening peak restrictions (because, as a regulated fare, it can't).
You also can't be issued with a Penalty Fare for travel on Avanti because it isn't a Penalty Fares TOC. (Though I wouldn't put it past Northern's contract security incompetents from trying)
northwichcat
23 Jan 2009
Northwich
I suspect they would be more likely to question the break in journey than the restriction code.
Northern revenue staff can be appalling, as are the company they use to appeal the incorrect actions of their revenue staff:
I associate the brand "Northern" with poor training, inconsistency, unprofessionalism and poor quality generally, and I don't think they are at all bothered at being perceived that way.
But yes you are right that a PF could not - at least not legitimately - be issued in such circumstances, and also that Northern cannot be trusted to get such things right.
You are restricted based on the times trains departed from London, and the other restrictions listed. So from Stoke you could resume on XC or Northern and not have to worry about any time restrictions. If you are boarding an Avanti service, then you can't use one that departed Euston at a barred time (though in practice this may be accepted, depending on the circumstances).
bakerstreet
29 Nov 2009
2C does mention Reading which may remove XC as an option.
Unless thats overridden by
For journeys to/via Birmingham on Cross Country see restriction code 2V.
northwichcat
23 Jan 2009
Northwich
I just realised I can get the split ticketing site to show a valid itinerary for the journey I'm thinking of, by specifying a number of options including displaying flexible fare and requiring a change of train with an extended connection time.
Strangely it can also find an Advance Single for a journey from Euston to Northwich that includes a 2 hour wait at stations only served by the Stoke to Manchester stopper. I'm not planning to purchase one, but I thought it's an interesting observation.
