Recovering accidently deleted files on memory card
John Webb
5 Jun 2010
St Albans
I attended a one-off local event this past weekend. I have a DSLR camera and took over 70 photos. In the course of downloading to my computer I accidently deleted all the files from the memory card rather than downloading them! Is there any software people can recommend that would enable me to recover the lost JPEG files, please?
Peter Mugridge
8 Apr 2010
Epsom
I don't myself, but I can say this:
Until you have done this ( it's called an SD card recovery ), do NOT take any more pictures using that particular card; the more recent files get over-written first following deletion.
Mike395
23 May 2009
Bedford
I've had success with the free version of Piriform's Recuva software before.
Have you checked your Recycle Bin (assuming Windows) also? They might still be there if recently deleted.
(Also, endorse Peter's message above; do not do *anything* else with that SD card until you've attempted to recover the files)
John Webb
5 Jun 2010
St Albans
Gentlemen, thanks for your replies. I am aware of the need not to use the card again. However, it seems that when deleting items in a separate bit of equipment, such as a camera, the deleted items don't go into the Recycling Bin; this appears to only happen if the file is already on the computer.
I'll see if Recuva does the trick or not.#
Thanks again.
Peter Mugridge
8 Apr 2010
Epsom
That's correct, because it will be deleting on the camera - therefore there is no recycle folder.
However, on the SD card the files, although deleted to you, will still be there - simply marked for over-writing.
Should have added earlier, do not reformat the card either - but I think you're already aware of that?
John Webb
5 Jun 2010
St Albans
Indeed, but thanks. Have recovered some 90% of what I deleted, so far. The file numbering system set by the camera seems to get altered a bit. So the 10% missing may still be lurking on the card. I'll have a tea break and rest my eyes before resuming.
John Webb
5 Jun 2010
St Albans
Thanks for the link to the Recuva software. Took several goes and got the best results after taking the card out of the camera and using an independent USB card connecting box, if you follow me! Ended up getting back 78 out of 80 photos, which I'm very pleased about - they were of the 200th anniversary celebrations yesterday of my local church. I'd have had a rather red face if I hadn't recovered them.
speedy1
1 Sep 2023
Mossley
PhotoRec is excellent too (though more suited to 'geeks' familiar with the CLI), in case you wanted to try another attempt at those other 2 files
John Webb
5 Jun 2010
St Albans
Thanks - the missing two were at the end of the day and not of great importance.
