Railway General Knowledge.
Grumpy
8 Nov 2010
Yes you're right! Therefore the correct answer is Hornsey, Stratford, Ipswich and Kittybrewster (Aberdeen). I should have known that from the start, having bought the book and having seen a few of them in action (just!).
Correct. Although like your namesakes you had a failure before you got here.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Thanks. Continuing on the same theme:
Certain members of class 21 in their later years had a crude wire and handle device fitted below the driver's side cab window. What was the purpose of this device? (Hint: It was nothing to do with exchanging single line tokens).
Grumpy
8 Nov 2010
Queen Street banker release?
Grumpy
8 Nov 2010
Correct! For manually-uncoupling the loco from the rear of a train from Queen Street on arrival at the top of the Cowlairs incline. Your turn to cross over and run back down the bank.
Open floor please
EbbwJunction1
25 Mar 2010
Newport, South Wales
Thank you; we'll move onto the theme of fireless locomotives.
Where will you find a Baguley 0-6-0PM locomotive from 1916, and can you tell me the two locations where it worked?
EbbwJunction1
25 Mar 2010
No-one seems to know the answer to this, so I'll tell you.
It's at Statfold Barn Railway (specifically in the Roundhouse Museum on a plinth). It originally worked at the National Filling Factory No. 2 at Aintree, Liverpool and afterwards at the Jacobs' Biscuits Factory (also in Aintree, Liverpool).
Open floor!
Peterthegreat
22 Feb 2021
South Yorkshire
Thank you Sir Xot.
Staying with pre nationalisation "modern" traction.
What numbers did the Southern give to the two locos which were later to become class 70s?
The third loco was built under BR and went straight to the BR number.
D6130
12 Jan 2021
That is correct. The Southern Railway used French numbering practice.
Please electrify us with the next question.
Thanks. Next up:
By what model railway-related nickname were Southern Railway 'booster' electric locomotives CC1, CC2 and 20003 known to rail staff.... especially drivers and driver's assistants/secondmen?
xotGD
4 Feb 2017
Go on then...
D6819 was the first "centre panel" Class 37. What was it renumbered to under TOPS?
A bonus point for its later renumbered.
