Railway General Knowledge.
Whistler40145
30 Apr 2010
Lancashire
Class 40 D200 held the nonstop record for a Diesel loco between Liverpool Street and Norwich, which other loco now holds the record?
Graham H
16 Apr 2018
Hopefully a simple one. The three letter railway station codes can cause amusement (Bognor and Poole for example) but which stations code would apply to the reigning monarch sorry hadnt realised a new question was raised
Graham H
16 Apr 2018
OK so not modern and I would think a non stop run would be required which presumably means not a class 37 on normal service as I dont think any service trains were non stop ? So possibly a railtour and the only one I can think of is far too obvious given your ID.
Cowley
15 Apr 2016
Devon
I thought it was D9000 too so if I was to have another guess I’d probably go for D200?
Whistler40145
30 Apr 2010
Lancashire
Peter is correct, 40145 broke two records
Non stop Liverpool Street to Ipswich and the non stop record for Liverpool Street to Norwich.
Peter Mugridge
8 Apr 2010
Epsom
Thank you.
This should be an easy one... this is a picture of a younger version of me literally collecting a train number. At which depot was this locomotive scrapped?
Peter Mugridge
8 Apr 2010
Epsom
Yes, it was cut up at Slade Green, so having won the thread from 40 145, he now wins it back from me.
The locomotive was written off after a crash, yes - it ran into a stranded unit that it was trying to rescue that had hit a landslide. This was near Micheldever, if I remember rightly. which does make it odd that it wasn't taken to Eastleigh?
No, I didn't get any flak - I bought the data panel long before I even bought this house, let alone got married. Incidentally HQ permitted an inspection of it while the locomotive was still generally intact so as to indicate to the depot manager exactly which piece I was after, plus a direct collection from the depot once it was ready, so I got two officially sanctioned visits to Slade Green out of this purchase! :) I was originally after both data panels, but one of them had a main frame member directly behind it and it wasn't possible to recover it. The trimmed off corner of the one I did buy was for the same reason - a diagonal frame member was across there.
Whistler40145
30 Apr 2010
Lancashire
A very simple question here
Which preserved Mainline diesel worked railtour to Edinburgh on the day of Diana Princess of Wales Funeral?
Graham H
16 Apr 2018
As the accident happened at Micheldever any reason why it was taken to Slade Green instead of Eastleigh. Having seen a picture of the front end its surprising both train crew survived.
Graham H
16 Apr 2018
Well this will take a while as I thought just about all of them got names ! No idea of set numbers but I will give a few I can remember.... Beaulieu. The New Forest, someone that was a Mum in a million, City of Portsmouth. Operation Overlord. Well thats a starter. I am sure a few more will come to light. Pretty sure Woking, Southampton and Bournmouth appeared given they were prime stops, not sure about Weymouth though. Hope this helps jog the brain cells
444045
25 Apr 2020
Dorset
Thats a good start Graham H,you're on the right lines with some of the others.
