Railway General Knowledge.
341o2
17 Oct 2011
On the subject of propulsion, Edward Leveux, was granted a GB patent for powering tramcars in 1873. The same principle was later trialled in the US. What was it?
341o2
17 Oct 2011
A hint is that the method is entirely mechanical and will doubtless raise a smile when all is revealed
341o2
17 Oct 2011
Nope. Try a more homely device which today is usually battery powered
341o2
17 Oct 2011
Yes! or spring power as it was referred to. The cars had large springs wound up by a small engine by the roadside. The American version also had the ability to reverse gears and use the downhill momentum or braking force to wind the spring in.
The British example was demonstrated at Lillie Bridge depot (now LUL) in 1875, a decade later the US company were optimistic, but this is the last mention of a spring powered tram. Probably because electric trams were now established.
Illustration of share certificate.
Nick_C
30 Jan 2020
Hampshire
Correct, over to you (I wonder if there were any others with 100%? If not, I believe second place goes to the Freshwater, Yarmouth and Newport Railway with 50%)
xotGD
4 Feb 2017
Here we go: Which Deltic was missing one of its nameplates in the final couple of years of operation? (Please don't offer 22 possible answers!)
xotGD
4 Feb 2017
Correct!
From the Napier Chronicles website:
09.12.79
To Doncaster Works for Unclassified repair, which included the removal of one nameplate for inspection and repair following damage incurred. The nameplate was never replaced.
Always a disappointment for those who took nameplate 'rubbings' when it rolled in with the wrong side facing the platform!
Your turn...
Trackman
28 Feb 2013
Lewisham
Thanks.
Another Deltic nameplate question.
Which Deltic was without a nameplate for a month as someone tried to steal it?
