Rail Freight Flows and News UK
BRX
20 Oct 2008
The route that 4Z60 took would have been diesel hauled. No third rail or wires between Basingstoke and Reading West nor between Acton West and Acton Wells Jn on Acton Bank. This last bit is being wired at the moment though, see separate thread.
Also Northampton Gateway isn't wired as far as I know.
What's being discussed is the trial runs that were done with the train over the weekend, on HS1. These happened inbetween it arriving from Southampton and departing for Northampton.
Class15
30 Dec 2021
North London or Mildmay line
Indeed - these ran from Dollands Moor to Singlewell and back. I am assuming the 92 led due to its compatibility with the TVM430 signalling system?
JKF
29 May 2019
GBRF are back on the Portbury Steel traffic this morning, with 66768 doing the honours with 22 KEAs in tow running as 6C92. DB have also been on the traffic over the last two weeks and today ran on an earlier timing (as 6Z56 inbound, 6Z57 return). The two trains passed each other at Ashton Junction around 11:15.
DB are using 25 BYAs in their rake, but some aren’t being loaded, yesterday had three slabs on the front 22 wagons with the back three not loaded. I don’t know if they’re running longer sets at the moment because the rail head will be in a better state this time of year.
j37401
16 Feb 2017
DB are starting a Felixstowe North - Trafford Park service next week.
The return from TP doesn’t appear in the system yet but it is supposed to be departing at 0920 with the Southampton service now departing there an hour earlier at 0820.
Class15
30 Dec 2021
Interesting… are Maersk returning or are other companies interested in Felixstowe?
66701GBRF
3 Jun 2017
Now in
This service replaces the 4L38/4M34 FX/EMG service.
Other rumored changes within the next couple of months is GB's 4L53/4M78 FX-HH service moving back to the 4L02/4M02 timings.
geordieblue
11 Jan 2020
There are more paths in this week for the Seaforth-Wolverhampton steel - suggests the first trial was successful.
On a separate note does anyone know why DB are route learning the Cumbrian Coast?
3 Mar 2020
Furness
There are paths for northern 195's doing Barrow to Sellafield. I think one ran last Monday and the previous Wednesday evening. Ist the DB route learning / Northern 195's connected with the tunnel at Whitehaven closing in September for Engineering?
j37401
16 Feb 2017
I believe there will be a further two trial steel coils from Seaforth.
Route learning on the Cumbrian coast is for an upcoming drainage job at Whitehaven / Corkickle tunnel.
Oxfordblues
22 Dec 2013
Trainman40083
29 Jan 2024
Derby
I note an Immingham-Seaforth special today:
I wonder if it's empty steel-carriers for loading to Wolverhampton?
There is a suggestion of problems at Boston Docks, so this may be an alternative flow.
j37401
16 Feb 2017
Yes it is. It’s the set that usually does Immingham / Boston.
This is the return https://www.realtimetrains.co.uk/service/gb-nr:R06350/2025-07-22/detailed
Class15
30 Dec 2021
Hi all, does anyone know if there are any plans to run more services out of Northampton Gateway? Still just the 1 to Southampton that I can see, but plenty of paths in to Southampton, London Gateway, Tilbury and Felixstowe that aren’t being used at present.
Adrian Barr
2 Jul 2020
Doncaster
Officially, the max load up Filton Bank and through the Severn Tunnel westbound is 2260 trailing for a standard 66 or 2300 for a 66/6. I think the DB trains from Portbury are planned for 22 wagons and a timing load of 2200 tons, but the sets are also used on Newport Docks slab traffic where 25 is the normal load. Depending on the weights of the slabs loaded (e.g. 3 x 20 ton or 3 x 25 ton), the wagons often weigh less than their full 100 ton gross weight, so all 25 have been loaded on occasion. No DB trains at Portbury this week though...
Many of the coils coming into Boston are from Arcelor steel plants in northern France / Belgium - I found one of the ships on the marine tracking website sailing from Dunkirk to Boston. It would seem a bit of a long way round to re-route this kind of North Sea traffic to Liverpool. There's an established steel terminal at Seaforth (see info from Peel Ports below) which makes me hope this trial flow is for other import traffic that normally moves by road.
https://www.peelports.com/news-arti...ar-for-steel-imports-at-the-port-of-liverpool
https://www.peelports.com/news-arti...-steel-terminal-to-deal-with-growth-in-demand
There was a previous one-off steel coil trial from Seaforth to Middlesbrough Goods back in February 2021, with coils for Nissan. I think that one might have been some sort of COVID contingency planning for alternative sources of steel - Nissan normally receives coil from South Wales, with onward road movement from the warehouse at Middlesbrough Goods to their Sunderland plant.
On a less positive note, there don't seem to have been any coil imports railed from Hull for a few months. I think those are mainly from SSAB in Scandinavia. That traffic normally gets combined at Rotherham with coils from Immingham.
The Maritime press release for the first train into the terminal says that additional services to London Gateway and Felixstowe are planned, although I'm not sure when they are likely to start or with which haulier.
Two further services are scheduled to follow, connecting London Gateway and the Port of Felixstowe with Northampton
https://www.maritimetransport.com/n...first-train-to-northampton-via-east-west-rail
The video below has some good drone footage showing the track layout and the first train arriving into the terminal. After the train arrives they drive to another location to get a better view - you can skip to 8:30 for that bit. Interesting to see how close the terminal is to the "birdcage" at Roade where the fast lines veer off towards Weedon. As the train enters the terminal, a speed restriction sign is visible (30mph left, 5 mph right). I assume this means trains can enter the reception sidings at 30mph but would be restricted to 5mph if they entered directly through the gates into the loading area. The train splits into two in the reception sidings and uses a headshunt to access the loading sidings from the other end.
The first train into Northampton Gateway | Purple & Co Railway Adventures
HST125Scorton
4 Jun 2019
Atherton
A new flow began yesterday between Horton-in-Ribblesdale and Brindle Heath Eurofreight. A terminal that was never commissioned years ago? Anyway it was hauled by GBRf 60026 and a rake of loaded JNA-T's. It seems to have a long old run round via Bolton before joining the train at Brindle Heath.
6J84: https://www.charlwoodhouse.co.uk/rail/livetrain/R05939/24/07/25
0F84: https://www.charlwoodhouse.co.uk/rail/livetrain/98432/25/07/25
6F84: https://www.charlwoodhouse.co.uk/rail/livetrain/R05935/25/07/25
ExRes
16 Dec 2012
Back in Sussex
DCR 60046 worked loaded 6L82 Peak Forest D&C to Brandon Down Sidings yesterday, any ideas if this is a 'new' service or just a one off?
Thanks
Intercity_225
13 Jan 2024
March
Thanks
Can't have been that loaded since I saw it at March and didn't see anything (although we were at a level crossing so may not have seen it).
Penmorfa
16 Nov 2011
North Wales coast
70002 worked the first Llan Jct to Hope Earles sidings on Saturday morning. 6H67 ran via Crewe, Stoke, Derby and Chesterfield. From the rail freight desert of North Wales I hope it's the first of many more.
Rail Ranger
20 Feb 2014
Stockport closures are from 2nd to 22nd August (inclusive) into the early hours of 23rd August and Saturday and Sunday 4th and 5th October into the early hours of Monday 6th October.
HST125Scorton
4 Jun 2019
Atherton
With loco hauled weedkiller trains like 3Q99 what speed do they go at whilst spraying? The path itself is for 60mpg, but it seems very slack in the timings? This would be a GBRf 66 + 3 KFA + GBRf 66.
Northampton
Path is also for a 715t and IIRC the reference loco for the timings is a Class 56, so perhaps unsurprising that a 66 with 3 wagons is somewhat more sprightly.
j37401
16 Feb 2017
I could be wrong but i think it is limited to 20mph spraying hence why most of the paths are at night.
