Rail Freight Flows and News UK
BRX
20 Oct 2008
It made it to Dollands Moor. I wonder if 92015 will take it through the tunnel?
It's all rather mysterious.
Freightmaster
Verified Rep
7 Jul 2009
Not going through the tunnel - runs up to Northampton Gateway on Monday:
For info, the train normally recesses at Didcot over the weekend; no idea why DB thought that
Dollands Moor would be a convenient alternative?! o_O
MARK
BRX
20 Oct 2008
MARK
Ah! I did wonder if it was something like that but also thought Dollands Moor is an odd place to put it! Have they run out of space at Wembley or something? Or (optimistic speculation) could they be taking an opportunity to prove the routes/timings for future container traffic to/from DM?
furnessvale
14 Jul 2015
I would imagine security at Dollands Moor is in a different league to most other potential storage spaces in the UK.
That begs the question, what is that train carrying?o_O
Northampton
Isn't Wembley designated as a customs inspection point for channel tunnel freight so it would habe security comparable to Dollands Moor?
furnessvale
14 Jul 2015
I wouldn't be sure about that, thinking more about illegal entry to the UK rather than customs.
Rhinojerry
2 Oct 2019
Bamber Bridge
6E43 Colas Ribble to Milford West booked at 0653 this morning,and cancelled later.Is this done to protect a potential resumption of the Bitumen traffic ?.
The inbound paths still appear on RTT.Thanks.
geordieblue
11 Jan 2020
As noted a few posts back there is an intention to run a trial steel service from Seaforth-Wolverhampton and paths are now in for this on Monday/Tuesday this week (https://www.realtimetrains.co.uk/service/gb-nr:R03792/2025-07-07/detailed). I don’t know if this is a replacement for one of the current flows to Wolves steel terminal or in addition.
An MoD train ran to Glen Douglas last week for the first time in a while - there seems to have been a general pickup in MoD traffic recently.
I have also read that intermodal services are due to restart at Barking. No idea as to their origin.
Chris125
12 Nov 2009
Isle of Wight
MARK
There's a comment on youtube mentioning a trial run of 92+66 haulage on HS1, seems outlandish but so does diverting a container train through Didcot via Dollands Moor....
Class15
30 Dec 2021
North London or Mildmay line
Yeah I saw that comment too, interesting that they sent a deep sea container train from Southampton to Northampton down to Dollands Moor to do those trials…
It appears to have been these paths:
6Z12 Dollands Moor to Singlewell: https://railcam.uk/rcdata/RCData2_detail.php?r=S&tid=896Z121804
6Z15 Singlewell to Dollands Moor: https://railcam.uk/rcdata/RCData2_detail.php?r=S&tid=896Z151105
BRX
20 Oct 2008
I'm very curious what this is all about. Is it to do with a potential return of freight over HS1? When it was running previously (with the continental gauge Transfesa container service) they were splitting trains into two portions (a 92 at the head of each) in order to move them between Dollands Moor and Barking. As I understood it, this was to do with the quite severe gradients that exist on HS1. So are they trying to work out if trains can be run in one portion with a 92+66 combo?
Northampton
Possibly - or maybe trying to simplify operations at Barking so that the 92 simply cuts off and the 66 can lead it forward? The 92 will be needed to lead the train on HS1 for TVM signalling, but can a 92 work in multi with a 66?
littledude
21 Nov 2011
People’s Republic of South Yorkshire
A 92 definitely can’t work in multi with a 66. Was the train top and tail? One of the reasons for weight restrictions on HS1 is due to coupler strain. Having a loco powering from the rear (with a second driver, like the HOBC uses) would surely reduce these coupler forces into acceptable ranges. I suspect a 92 is more than capable of hauling a heavier train
DBS92042
13 Apr 2019
66131, 66186 and 92015 were all reported on 6Z12/15 but in what order and which ones powering at any one point, I'm not sure
Rhinojerry
2 Oct 2019
Bamber Bridge
66737 on its way to Kineton now from Glen Douglas,saw it on Ribblehead railcam earlier.
Chris125
12 Nov 2009
Isle of Wight
Weren't the coupler force calculations changed recently, after research found they were excessively conservative?
Chris125
12 Nov 2009
Isle of Wight
:face_with_monacle:
Report T1256 ‘Guidance on limits of freight train trailing length as governed by coupler strength’ didn't get much attention for some reason and I've forgotten where I read the specific details, but it did seem to find some useful extra train weights.
The research has enabled existing couplers, which connect freight wagons, to safely connect more load. The evidence means a 34.5 tonne coupler rating can increase 16% to 40 tonne, and some 56 tonne rated couplers increasing 13% to a new 63 tonne rating. Crucially the uprated values can be applied to wagons in use today without the need to upgrade or undertake a detailed engineering assessment.
As a result of the research, more than 12,000 rail freight wagons, over 50% of Britain’s fleet, will receive an increase in traction rating (the amount of weight it is able to safely haul).
20 May 2013
no stove-pipe hat? Or figure reclining on a House of Commons bench?
Ha!
Thanks!
*URL link to press release & report not showing for me, so re-posted HERE.
Class15
30 Dec 2021
Afternoon all, does anyone know what 4F42 Crewe to Ditton and 4K54 Ditton to Crewe paths were for today? Do they join/split from a London Gateway service that goes somewhere else after Crewe?
BRX
20 Oct 2008
I guess we don't know if these changes would have an impact as far as HS1 is concerned? But in 2022 the Dollands Moor - Ripple lane freights were still operating as half-portions as far as I know, which suggests that they didn't.
littledude
21 Nov 2011
The wagons were French and Spanish, did they maybe make a difference in the ability to operate the couplings at higher ratings?
Class 170101
1 Mar 2014
The route that 4Z60 took would have been diesel hauled. No third rail or wires between Basingstoke and Reading West nor between Acton West and Acton Wells Jn on Acton Bank. This last bit is being wired at the moment though, see separate thread.
Also Northampton Gateway isn't wired as far as I know.
