Rail Freight Flows and News UK
Adrian Barr
2 Jul 2020
Doncaster
Is this with both locomotives powering, or just the one at the front?
It's just the loco at the front powering - having the second loco in the middle puts it in the right place to haul the second portion away (without any loco moves being required) when the jumbo train splits at Hanwell Bridge or Southall.
When the trains were DB-hauled they split at Acton, the loco (normally a 59) would usually haul the first portion away and a loco would come off the stabling point at Acton to haul the second portion. There was a lunchtime arrival from Merehead which often ran with three (shorter) portions but most jumbo trains run with two.
The empties are also often combined into jumbo trains, but this is usually done at Wembley Reception sidings where the layout makes shunting the locos around easier than at Hanwell or Southall.
6V60 with two locos (Oct 2024): https://www.flickr.com/photos/93293618@N05/54109296337/ (Photo: FEWS FOTS)
6V60 with three locos (Apr 2025): https://www.flickr.com/photos/d1059/54441648419/ (Photo: Stephen Dance)
7C77 with four locos (Jun 2022): https://www.flickr.com/photos/d1059/52162472203/ (Photo: Stephen Dance)
There’s a slightly random Arpley-Doncaster running today
Confirmed sighting of 66304 which looks to be collecting them 5x IFA Flats.
Collected 8749093039 / 3286 / 3849 / 3898. It may have been intended to collect 8749093005 too but that one's still at Arpley.
JKF
29 May 2019
Portbury steel traffic news:
Last week we had both DB and GBRF running trains each day, with an early DB working (6Z56/57) arriving just after 7am and departing mid morning, passing the incoming GBRF working at Ashton just after 11am. This ran every day.
On Saturday, a DB return trip operated as 6Z55/53, on the more usual morning schedule. GBRF worked empties into the dock and their loco then ran light to Bristol East Depot.
GBRF returned on Tuesday after the bank holiday with a light engine move from Bristol East to collect the loaded steel. This departed about 50 mins late in the evening, and from my vantage point across the river it didn’t look like much steel was on it, though the KEA wagons make it hard to tell.
On weds a GBRF incoming service was scheduled but took a left turn at Dr Days and ran into Bristol East Depot instead. It’s not clear if this was empties or a light engine move (coded 0C92 but listed as conveying 600 tons). 66713 worked this but then did a few other trips out of East depot (Cardiff & Westbury).
No further GBRF trains ran on the branch after Tuesday, and on Friday a DB train ran (The 6Z50 afternoon train). So who knows what is happening, but it might indicate GBRF are having more issues.
DBS92042
13 Apr 2019
As far as I know, 0C92 was just 66713 light engine. 66713 then went back to Cardiff Tidal light engine on Thursday to move something from Tidal Sdgs to Margam TC before working light engine back to Bristol
ActonChris
30 Sep 2023
Acton
The Southampton service to and from Masborough is being replaced by a Felixstowe service as the customer pulls out of Southampton.
4L12 05:39 Masborough - Felixstowe North DBC
(RTT)
Returning as:
4E12 17:45 Felixstowe North - Masborough DBC
(RTT)
Starts this week. Expect further movement in the coming weeks from other customers moving around.
JKF
29 May 2019
I think they’ve done that before, just using the Portbury path to get something to East Depot for unrelated reasons.
Anyhow, tomorrow it appears that we have both DB and GBRF STP workings in the timetable, which suggests both will run as per two weeks ago, passing at Ashton around 11am which is a little too early for me to take a lunch break and pop down! Bring back the two DB trains per day which crossed around the more convenient time of 1pm.
Web4160
14 Aug 2019
portishead
66654 on 6Z57 to Margam left Portbury docks 40 minutes late this morning as a result 66314 on 6C92 from Margam arrived 30 mins late despite Real Time Trains recording its arrival as on time.
66701GBRF
3 Jun 2017
Surprises me those slabs are not strapped down. Wouldn't want to be in the rear cab in the event of a collision.
JKF
29 May 2019
Photographed from the Avonmouth Bridge by the look of it!
Parson St or the nearby footbridge would probably have been a good place to see these today, given there was also 37240+kettle passing through late morning and a working out of the old freightliner depot (which sees occasional use for wagon storage including short term storage of engineering trains).
AndrewE
9 Nov 2015
especially as the load of an early Long Welded Rail train speared the back of a loco in the early days, before the rails were clamped down in the middle of the train.* I thought the wagons might have big heavy headstocks (?) but doesn't seem to be the case from the pic...
P.s. I guess it would still require a very expensive repair!
However, aren't most freights OMO nowadays?
*OT, I believe they then went to 2 anchorages - and found the train couldn't go round corners!
DBS92042
13 Apr 2019
Can confirm Bartlett's Bridge (near Parson Street) was the place to be! A few of us there for unusually busy hour or so of activity
Web4160
14 Aug 2019
portishead
Yes photographed from the M5 bridge. A bit of a noisy spot!
geordieblue
11 Jan 2020
Presumably this is for RHTT work?
“Consisting of Full time work during thr Autumn and Winter months and then you will get your Spring and Summer off!!”
There's another opening on the website, also set at St Blazey, advertised as year-round so presumably that will be for the clay
Sun Chariot
16 Mar 2009
This post is one of idle curiosity.
Since mid March, 6O68 Westbury - Crawley (aggregates) has typically shown two different trailing tonnages:
1800t when pathed with bogie hoppers, for Stone Terminal 2.
2000t when pathed with bogie boxes, for Stone Terminal 1.
Simples, yes? Except... last Tuesday's data showed 1800t but the service ran with 19 bogie boxes; and today's data showed 2000t, yet 19 bogie hoppers ran.
So that blows my theory out! What is the likely reason for the different tonnages in the data fed to Realtime Trains etc?
Attached are the paths in RTT - and the actual trains which ran on them.
Northampton
I note the 2000t WTT schedule is TSX so the STP Tuesday Schedule maybe has to get around something that needs the slightly lower trailing weight for the SRTs?
Having said that a quick flick through the WTT schedule vs last Tuesday's STP schedule didn't show any major timing differences so have no idea.
Penmorfa
16 Nov 2011
North Wales coast
There is a 14.49 Penmaenmawr - Leyland 6N91 booked for tomorrow, a new destination. The stock arrived from Chaddesden this afternoon. No loco or wagon ID but any appreciated.
ExRes
16 Dec 2012
Back in Sussex
First DCR service to Leyland, loco is 60055 but can't help with the wagons
xotGD
4 Feb 2017
I see that 6O74 1139 Prestwick B.P.Oil to Grain Oil Terminal Gbrf via the S&C is running today.
If I'd noticed earlier I'd have turned out for a phot. Oh well.
Class15
30 Dec 2021
North London or Mildmay line
Previously I recall there being a 4M53 Felixstowe to Trafford Park service. I‘m assuming that this was removed at the same time as 4L67 going the other way. Now, it seems to terminate at Ipswich Yard. What is the purpose of this service, wagon maintenance at Ipswich?
Link to 4M53 Felixstowe to Ipswich service
I wonder if this service will return to Trafford at some point.
Freightmaster
Verified Rep
7 Jul 2009
Previously I recall there being a 4M53 Felixstowe to Trafford Park service. I‘m assuming that this was removed at the same time as 4L67 going the other way. Now, it seems to terminate at Ipswich Yard. What is the purpose of this service...?
4M53 forms this:
MARK
Class15
30 Dec 2021
