Rail Freight Flows and News UK
ExRes
16 Dec 2012
Back in Sussex
60046 has worked the first Penmaenmawr - Willesden for DCR today. Complete with headboard and load 24. I'd be interested to know where it goes after Willesden but at a cursory glance it did'nt look like ballast.
The headboard was "Y Chwarelwr Penmaenmawr" which is supposed to translate as "The Penmaenmawr Quarryman", as far as I'm aware the load, variously described as stone, aggregate & granite, is destined for Quainton Railhead and HS2
JKF
29 May 2019
66783 has finally escaped from Portbury with loaded slabs to Margam on 6B92 at around 6pm today.
There’s an STP DB working scheduled for next week, but running quite early (arrive 7am, out at 10:30am). This would allow it to be off the line before GBRF’s inbound arrives at 11:30. Will be interesting to see what actually runs.
geordieblue
11 Jan 2020
There’s a couple of interesting moves to Oxwellmains in the next week - although one admittedly ran today! The gypsum service from Hull/Doncaster which last ran back in (I think) November ran again this morning. Then on Monday there’s a move to Eastleigh, which I presume might be a wagon move - any ideas? https://www.realtimetrains.co.uk/service/gb-nr:R66469/2025-04-28/detailed
There also seem to be route learners running between Didcot and Northampton.
DBS92042
13 Apr 2019
Didcot-Northampton route learners possibly for water train diversions if they need to go over EWR?
Adrian Barr
2 Jul 2020
Doncaster
I’m pretty sure it has to run round or reverse twice to get in and out of the bulk terminal, there’s a fairly generous time for it to get from there to the waste plant. The waste plant entrance is also in the up direction, so once it’s entered the siding it then has to reverse into the plant, this might be a propelling move.
Yes... I was thinking about that after I'd posted about there being no direct access from Severnside into the Bulk Handling Terminal for 6A03 - the same also applies heading into Severnside for 6C03! Thankfully the moves have been observed with some good drone shots on flickr by robmcrorie and Andy Hoare. The caption to this shot of the Bulk Handling Terminal helps clarify that 6C03 runs round here, runs forward onto the Filton branch and then propels onto the Severn Beach line: https://www.flickr.com/photos/robmcrorie/54384438383/ (Photo: robmcrorie)
That picture is taken looking towards Severnside, with these photos giving slightly different angles on the run round move:
https://www.flickr.com/photos/robmcrorie/54369485088/ (Photo: robmcrorie)
https://www.flickr.com/photos/andy_hoare/54419127745/ (Photo: Andy Hoare)
Avonmouth Bennetts siding is visible on the left of this shot, along with the silos of the cement terminal.
https://www.flickr.com/photos/andy_hoare/54372222354/ (Photo: Andy Hoare)
From the run round loop at Severnside, the train is propelled into the terminal and split across two sidings for unloading and reloading of containers, as seen here:
https://www.flickr.com/photos/andy_hoare/54417390175/ (Photo: Andy Hoare)
Severnside waste terminal sidings with the "Energy from Waste" incinerator behind:
https://www.flickr.com/photos/andy_hoare/54374203983/ (Photo: Andy Hoare)
Once reloading with empty containers is completed, the train can reform, run round, and 6A03 normally departs via Clifton Down. I found a few pictures of 6C03 running top & tail in previous years, and a couple of them from 2020 mention possessions at Clifton as the reason:
https://www.flickr.com/photos/153712773@N08/49753508548/ (Photo: Steven Clements)
https://www.flickr.com/photos/brian_dentons_linesidephotos-europe/50151467858/ (Photo: Brian Denton)
I'm fairly sure that this train is currently only top & tailed if engineering work requires it - the question is if 6A03 has to run via Filton, what stops it doing a propelling move onto the Filton branch to access the Bulk Handling Terminal to run round there as per the outward 6C03?
The whole situation is becoming a major farce now - I still don't understand why Tata thought it was a good idea to spend a huge amount of money to create a fleet of bodged up wagon conversions rather than allowing DB to run the Portbury trains using purpose built, tried and tested steel carriers, as they do from Newport/Cardiff.
I think DB were just on a short-term contract while the three-year contract was sorted out. Workings were always STP and at times a bit ad-hoc.
It may not be GBRF’s fault, it depends on who procured the wagons, and whether a specification was given that a supplier has failed to meet. Does anyone know any more details on this?
I mentioned in a previous post that the wagons might be hired directly to Tata, but it's equally possible that the contract is set up so that the haulier supplies the wagons, in which case the KEAs might be on hire from VTG to GBRF. I can't find any press releases that make it clear one way or the other. Either way, I suspect there's a bit of contractual wrangling going on! It's interesting that the KEA wagons did leave loaded in the end (post #1829 above); we'll see what happens with these trains next week.
I read somewhere that Tata have a general policy of spreading risk when it comes to suppliers, so it's understandable that they want alternative options instead of a single haulier owning all the slab wagons and providing all the services for a critical materials flow (for the coil traffic many of the wagons are hired from third parties like VTG or Touax, making it easier for other companies to bid against DB during contract renewal). There is some recent history of wagon conversions on steel traffic, such as the JSA covered coil carriers converted from iron ore tipplers, which have since been converted again to either open coil carriers or box wagons. Having said that, cut-down KEA box wagons don't seem an obvious choice for slab traffic.
While on the topic of Tata wagons, this recent video on the Tata Steel UK channel has some interesting snippets of information on the scrap traffic that will be required when the electric arc furnace goes into production around 2027:
Tata Steel UK | SteelCast S3 E36: Step inside Port Talbot's £1.25 billion megaproject
The video starts in Margam yard; 66158 nearest the camera (seen departing at 3:25) is most likely on the 6B48 afternoon working to Trostre, which usually has import coils on it from Cardiff or Newport Docks - note the shipping labels on them. A figure of 70,000 tons of scrap per week is mentioned - if that amount arrives by rail, and there were ~1500 tons of scrap on each train, that would amount to something like 7 trains a day, six days a week. Those would replace a similar number of import steel services (slab and coil), but the scrap would be travelling from further afield.
At 6:06 the video moves across to the Peafield (or P. Field as shown on Trackmaps) siding, located between the main area of internal sidings to the south of the steelworks and Port Talbot Grange sidings. Import or Export slab traffic by rail was previously loaded or unloaded from the area of hardstanding to the left, but as mentioned in a previous post, the unloading of import slab now appears to have relocated elsewhere within the works. Trains accessed the Peafield siding with main line traction, but the slab trains now seem to be hauled by Tata internal locos to a different siding accessed from the other end of the works.
As discussed in the video, this Peafield siding will become the offloading point and sorting area for scrap traffic arriving by rail. Scrap traffic is traditionally conveyed in box wagons, but the video talks about the use of "Rotainers" - rotable containers. This is a brand name for a company providing various types of container designed for bulk handling, which can be lifted (e.g. by crane or reach stacker) using a special attachment which rotates the container to empty it, as seen here on the company's YouTube channel: https://www.youtube.com/channel/UCaxS0JVRlBx9E9ti9Omk47w/videos
The rotainer website - https://www.rotainer.com/ - lists a "Scraptainer" which the accompanying picture shows to be a toughened 20ft high cube designed specifically for scrap - the idea of "replaceable wear plates" sounds good considering how much of a battering scrap wagons get in typical use. Maybe we'll see something like this being used (a version which wasn't a high cube would be more suitable for UK routes). Tata have previously used containers for their Hardendale lime and the "tar tanks" to Middlesbrough, so they have some experience of using containers for bulk flows.
Later in the Tata video, there's a conveyor leading to an overhead bunker visible when the camera pans round at 13:53 - I think this is where coal trains for Llanwern were loaded in the Grange Sidings "back in the day" (with iron ore coming from Port Talbot docks down a separate branch joining the main line west of Margam Yard). After the blast furnaces shut last year there were some coke trains from Port Talbot Grange Sidings to Scunthorpe to clear stocks. It's possible these were loaded using this overhead bunker, assuming it's still functional, or they might have been loaded by shovel nearby. The smaller shed next to the overhead bunker is where coal from Cwmbargoed was discharged. Scrap from Trostre was previously unloaded from SSA wagons nearby within the Grange sidings, and processed slag (for use as aggregate) was also loaded into bogie hoppers here for despatch by Freightliner to various Tarmac terminals such as Hayes or Radlett.
Yes, the wagons went forward on 6M30 to Quainton this morning. The material does look a bit finer than railway ballast from what I can see in these photos of 6M22 from Penmaenmawr:
https://www.flickr.com/photos/whosoever2/54475545096/ (Photo: Nigel Capelle)
https://www.flickr.com/photos/stationger43041/54475469206/ (Photo: Geraint Jones)
Adrian Barr
2 Jul 2020
Doncaster
I've noticed that this Hither Green to Churchyard sidings working regularly seems to be topped & tailed at the moment.
I think whichever crossover was out of action at West Hampstead was fixed in mid-April after a few weeks out of action, with trains now running normally to St Pancras with one loco. The top & tail schedules reversed at West Hampstead and Cricklewood Up Goods loop before returning through West Hampstead again towards St Pancras Churchyard sidings.
The train service code 52495100 is listed under infrastructure management / engineers trains (Colas Rail) in the codes here: https://www.rail-record.co.uk/train-service-codes/
If it was running directly into Eastleigh Arlington it would look more like a wagon move, but combined with the train service code I think its more likely to be something related to infrastructure. 6Z08 is a headcode associated with one of the Loram rail grinding trains - https://www.ontrackplant.com/headcodes - but I think that's at Carnforth with the next working scheduled from there for the 1st May.
My best guess is that it's some random long-distance movement of on-track plant - there's an 0Z08 coming from Millerhill for it, so it should be loco-hauled at least.
Before I saw the train service code I wondered if it might be moving a couple of KVA vans which are still at Oxwellmains. These were part of a small fleet occasionally added to the cement trains conveying bagged cement (with those two last used in October it looks like), with most of the wagons ending up on Trostre tinplate workings. But if it was those (or a movement of cement wagons for overhaul or something) I think it would be more likely to be going straight into Arlington running on a different train service code.
I’ve noticed that there was a London Gateway - Ipswich service today and a return is booked for Monday. Do these run on to Felixstowe as an inter-port service?
I think that was the empty wagons off the 4L73 service from Tinsley that arrived in the early hours of Saturday morning. It might be some kind of set swap or maintenance move; it was running VSTP so might not be a regular thing. Freightliner do seem to stable a few sets at London Gateway over the weekend which I hadn't noticed before, also GBRF have the set off 4L90 Masborough - London Gateway in there, arrived Saturday early hours and departing again Monday morning. There was also a couple of GBRF Saturday departures from London Gateway which only ran as far as Peterborough - I think there's there's usually 2 or 3 sets that recess there over the weekend.
I remember occasionally being on Ipswich station on Saturday evenings and there might be a GBRF intermodal passing through heading to Harwich to stable there over the weekend - I think a couple of GBRF trains still do that.
With the expansion of Felixstowe there must be more room to stable sets there, and along with the Bacon Factory curve avoiding the need for reversals, Ipswich yard is probably less full than it used to be on weekends - along with that 4Y05 from London Gateway, I can only see a couple of other trains terminating there on Saturday, 4R93 and 4Y94 from Felixstowe.
Class15
30 Dec 2021
North London or Mildmay line
Thank you! That makes a lot of sense and points to either a maintenance move or possibly even a stabling move if there isn’t space at London Gateway over the weekend?
JKF
29 May 2019
GBRF inbound to Portbury is now on RTT for tomorrow, as well as an early DB run.
It’s down as a VST working, the usual booked service on a Monday should come from Bristol East Depot after working down over the weekend but there’s nothing there hence a Margam start.
dmncf
4 Sep 2012
There's currently a Freightliner aggregates train at Paddington New Yard. The Realtime Trains results below for location "Paddn Yd Marcon Topmix" suggest that the train will depart to today at 11:21:
But what's not clear is when did the train arrive? The most recent arrival I can see on Realtime Trains - shown below - is last Friday. Has the train been parked there all weekend?
Unobrow
19 Nov 2024
Manchester
Yes it went down ex-Tunstead Thursday night/Friday morning as 6V51, it’s a regular working.
HST125Scorton
4 Jun 2019
Atherton
Strange one tomorrow. https://www.realtimetrains.co.uk/se...25-04-28/0000-2359?stp=WVS&show=all&order=wtt
Apparenly Class 69 and x5 IFA wagons from Dallam. But currently nothing on site at Dallam yard and i see no obvious inbound working.
69010 ended up arriving into the bay between Plat 3 & 4 at Bank Quay. Now awaiting to depart to Doncaster as 0E45. I pass Dallam myself, no wagons in usually just MMA from Peak Forest with stone. Not sure where the IFA mentioned are?
geordieblue
11 Jan 2020
Potentially making a mountain out of a molehill… but one thing that comes to mind for IFA wagons at Dallam is that of car trains. IFA flats are used on a number of car services and DB have previously stated their interest in running a car service from Warrington Arpley (I think originating from the Halewood Jaguar plant). Perhaps today’s move was a trial (or was meant to be a trial) of an alternative loading point?
BRX
20 Oct 2008
Checked this morning & the hither green - churchyard sidings service is indeed back to one loco now.
BorderCollie
15 Apr 2025
Scottish Borders
Has the fledgling DRS Tees Dock - Trafford Park been withdrawn now?
It seemed to use various headcodes 4E59/4M59/4E58/4N59 - can't see it anywhere. And why did the eastbound end up always going via Crewe?!
j37401
16 Feb 2017
My contacts suggest x5 IFA’s are at Arpley yard somewhere to be purchased or leased by GBRF. I believe these are not ready to be collected yet so not sure what the purpose of the light engine move was in the end. also, not sure why the diagram was to Dallam either as i doubt DB would move them there. Could be a scheduling error of course.
The light loco move was GBRF possibly the class 69 based at Tuebrook. I believe GBRF are leasing the IFA wagons which are currently in store at Arpley somewhere. Not heard of any trial.
The only thing of note recently with the Halewood cars is that the wagons are now stored and maintained at the old Arpley stabling point (by Arpley jct) by STVA instead of tripping them to Donnington. These can be tripped as 6F49 usually on a Tuesday but runs as Req.
Class15
30 Dec 2021
Freightliner ran the 4L90 (Trafford Park to Felixstowe, today Ipswich however) path for the first time in over a year today. I’m overjoyed to see this train return. Is it a one-off or will it run regularly?
Adrian Barr
2 Jul 2020
Doncaster
Well... that 6Z08 out of Oxwellmains ended up being 56090 plus the two KVA ferry vans I mentioned. They might get some attention at Arlington, and eventually I suspect they will end up being hauled to Margam (for use out of Trostre) on the weekly DB Eastleigh - Margam loco move which sometimes runs class 6 to move wagons. The vans were occasionally used for bagged cement such as this Viewpark working in May last year:
https://www.flickr.com/photos/126612220@N04/53707833540/ (Photo: John Webb)
Yes, could be a stabling move, they may have an agreement to stable a certain number of sets at London Gateway over the weekend and maybe this was an extra one that needed moving out of the way.
I find these Tunstead workings into London for Tarmac quite interesting. There's another 6V51 tonight from Tunstead to Park Royal, and occasionally a 6O51 from Tunstead to Stewarts Lane (I noticed one ran on 9th April).
As mentioned, there are some 874909xxxx IFA flats at Arpley which were previously in use on car traffic. I think these are owned by Ermewa (wagon leasing company) but have been off hire for a while. There were twenty 874908xxxx IFA wagons on the car traffic plus seven of the 874909xxxx wagons, but six of the 874909xxxx wagons are no longer on the car traffic.
8749086025 fitted with decks for conveying cars: https://www.flickr.com/photos/dan700/29615498334/ (Photo: Dan Adkins)
8749093831 in use as a regular intermodal twin: https://www.flickr.com/photos/richardajones/50359511453/ (Photo: Richard Jones)
Those wagons have a distinctive profile when viewed from above and you can see some in this March 22nd drone view of Arpley yard:
https://www.flickr.com/photos/uk-railpix/54404568584/ (Photo: Steve Wakefield)
Three of them are seen on the Stoke trip in November 2024 after maintenance; I think they've been hanging around at Arpley since then.
https://www.flickr.com/photos/189838833@N07/54165524136/ (Photo: Rob Barton)
Meanwhile there was a 4Z45 Gascoigne Wood to Doncaster Down Decoy on Monday 21st April which brought some IFAs out of storage for use on the GBRF Doncaster Iport to Mossend service. These have replaced some of the IKA wagons which were on it (4S05 currently running with 11 IFA and 5 IKA). Given the planned destination of the Warrington move (Doncaster), the IFAs are quite likely intended for the same flow. The only thing that confuses me is that the IFAs are multifrets with a higher deck than the IKA megafrets, which are needed for the high cubes on that service due to the route being W9 gauge. For that reason it seems likely that the IFAs won't completely replace the IKAs on that service.
The Holding sidings where STVA are now doing maintenance on car wagons can be seen in this shot of 6O16 taken in February: https://www.flickr.com/photos/32865578@N02/54357766753/
Quite a contrast to this 1980 shot featuring class 40s and 25s: https://www.flickr.com/photos/richardboyd484/10059685834/ (Richard Boyd)
Or this improbable 1993 shot featuring a ridiculous number of locos: https://www.flickr.com/photos/penmorfas/8047814064/ (Photo: Dave Sallery)
stantheman
17 Nov 2017
Anyone know the reason for the frequent 2x 90 light engine return trips from Mossend to Newcastle ?
Iskra
11 Jun 2014
West Riding
Equally, can anyone please explain the current GBRF 57/3 Doncaster-Derby Mk3 coaching stock return runs via both Sheffield and Treeton junction?
stantheman
17 Nov 2017
Driver training for East Coast diverts of services to Coatbridge and Mossend. I’m afraid those trains won’t actually use 90s though!
Are you sure ? I read elsewhere that they were for a new flow but I took that with a pinch of salt .
john77
9 Sep 2016
I think they will....
Class15
30 Dec 2021
That appears to be a shot of the light engine move? I believe the point is that the 66s will work the actual loaded trains. For example, Felixstowe trains go via the unelectrified Ipswich-Peterborough section, and for London Gateway, the port is still unelectrified.
Northampton
In addition, ECML container trains usually use the Unelectrified GN&GE joint line via Lincoln between Peterborough and Doncaster. Although with diversions causing resource plans to be rewritten not impossible they run with a 90 north of Donny and 66 south of there.
Class15
30 Dec 2021
Indeed, although I have seen Freightliner diverts going via Retford. I suppose if they want 90s for the whole way to Ipswich they could use the Canonbury Curve.
Northampton
Staying on the ECML all the way restricts them to W9, doesn't it? Although with capacity being stretched I wouldn't be surprised if a mix of routes were taken.
BorderCollie
15 Apr 2025
Scottish Borders
95% of current freight also uses the unelectrified Edinburgh sub. Squeezing-in additional paths during the day through Waverley might be a challenge....
