Problem with customers
Bantamzen
4 Dec 2013
Cheshire
I suggest there is a flaw in how shops operate. Customers should not have direct access to items (e.g. alcohol) where an age-checking policy operates - they should have to request shop staff the get the item after providing proof of age evidence.
(Of course most supermarkets would object to such a policy as it might reduce sales of alcohol)
Crikey, you'd have to have large swathes of stores under lock and key, increasing the cost for everyone. Great idea, especially when most stores can successfully make necessary checks for those people who look under age, noting that it is not a requirement to prove your age if you are & look old enough. A sledgehammer to crack a nut solution methinks!
TheTallOne
2 Jan 2024
Alternative is to have a door that can be remotely locked. Force them to come back to the counter if they want to get out.
Although then do you get into the issue of false imprisonment? I guess if they put the alcohol down they're allowed out. :D
philthetube
5 Jan 2016
If you are worried about putting money through the till show it to a cctv camera then put it somewhere covered by the camera, assuming that the camera is good then this will display honesty on your part.
