Pretendolino
Masbroughlad
2 Mar 2011
Midlands
Saw the Virgin Pretendolino set in BHM at about 2035 on Friday.
What service would this have been working. Didn't realise it worked any ex-Euston services via Birmingham.
(As an aside, did First intend to keep the loco hauled train - not that it matters now!!!)
MCR247
7 Nov 2008
It works the 1843 Euston - Crewe every Friday :)
bb21
Emeritus Moderator
4 Feb 2010
That would be the 2020 service to Crewe. (1K39 London Euston - Crewe)
In answer to this point, as far as I'm aware, First never got far enough through their mobilisation to tell us if they'd keep it or not. Certainly I don't think they ever announced they'd be dropping it.
calc7
8 Aug 2011
Ah, cheers for that. Didn't realise any of its Pretendo services went through Brum.
Out of interest, where did you think it went to then?
Being the shortest of Virgin's usual runs I would think it's naturally the most obvious route to see it on (although I concede the set continues to Wolverhampton and then almost empty onto Crewe!)
Masbroughlad
2 Mar 2011
Midlands
Thought they went up the Trent Valley to the North West.
I wondered if this was standing in on a Euston - Wolves train.
MidnightFlyer
16 May 2010
I believe it has in the past when a 390 was unavailable long-term a few years ago (it may have been after the Lambrigg crash; AKA Grayrigg) - it did 3 Euston-Birmingham / Wolves services each way per day during the week for a good while. Of course I doubt it would happen nowadays with the four extra 390s.
dvboy
6 Sep 2011
Is it still mainly full of rail enthusiasts, mainly of the annoying teenager variety?
Greeby
15 Apr 2011
Between EUS - MKC it's jammed with commuters, being as it's the first open stop Virgin train between the two for three hours.
MCR247
7 Nov 2008
It tends to stick to Birmingham runs as they are the shortest and involve the least amount of 125mph running
dangie
4 May 2011
Rugeley Staffordshire
No, it doesn't. The carriage rake is worked back to Willesden from Crewe as empty coaching stock by a 57 (on the Sunday?) ready for the next weeks' working.
Thanks. Interesting. Never seen it passing through Rugeley Trent Valley which is I presume the route it would take. Is it a daytime timetabled run or could it be anytime day or night?
sprinterguy
4 Mar 2010
Macclesfield
Having done a little bit more research into it, it looks like the ECS move heads south from Crewe at 21:45 on the Friday night, straight after working the 18:43 from Euston. It arrives back at Wembley at 01:35, so it is quite a late night working. It does indeed travel via Rugeley and the Trent Valley, passing there at 22:38.
Here's the details on open train times:
http://www.opentraintimes.com/schedule/C55141/2012/11/2
NXEA!
22 Oct 2009
The Pretendolino usually works the FO 18.43 Euston to Crewe via Birmingham, but does have a regular diagram it can substitute on if needed (starting with the 07.03 Euston-Birmingham and 08.50 return I think?), and this is usually the case if there's a fall in Pendolino availability such as the winter two years ago where a number of sets were running around with covered up windows due to breakages from ice. As for whether First were planning to keep it, Tony Miles from Modern Railways reported that he had asked and someone had specifically told him that the set was going to be retained but DVT 82101 was going off-lease, not that this matters now! Hope this helps. :)
headshot119
31 Dec 2010
Dubai
Just to add its hauled back south by a 57. Not a 67 as someone has posted further back.
AndyLandy
30 Oct 2011
Southampton, UK
I did, however, post that it was hauled by a 57 in the post before the one that you are referring to. :)
Indeed you did. Just slipped in before I pressed submit. ;)
Not sure where I heard it was 67-hauled, clearly I was mis-informed. Unsurprising to learn it's actually 57-hauled, that certainly seems more in-line with what locos are likely to be available for that duty.
matt
30 Jun 2005
Rugby
As posted by captainbigun on wnxx the Pretendolino is now DVT-less as they are both at Eastleigh having bogie swaps the mark 3 set will be out of action.
DarloRich
Fenny Stratford
What a shame it wont run without a DVTthis Friday? I was looking forward to a run back on the pre Olympic 1843 service rather than the 1903 it ran during the Olympics
MCR247
7 Nov 2008
Matt just said above that the set will be out of action?
matt
30 Jun 2005
Rugby
The dvt is the brake vehicle so can't run without it. It depends how long a boggie swap takes but I don't think there are any other available dvts.
dk1
2 Oct 2009
East Anglia
Pop over & see us at Crown Point. Sure we can borrow them one.
Class172
Quizmaster
20 Mar 2011
West Country
Could they not borrow a mk2 BSO/DBSO from somewhere to act as a brake vehicle, or would that require a lot of paperwork?
matt
30 Jun 2005
Rugby
I doubt it as mark 2s are only 100mph coaches plus Virgin guards will only sign mark 3s.
MCR247
7 Nov 2008
And there isn't really a need because it isn't that vital
