PPM - Should it be in here or in the main forum ?
Mutant Lemming
8 Aug 2011
Limited to 20mph and with only a handful of seats should Class 139's be classed as light rail or not ?
Mike395
23 May 2009
Bedford
It's designed to run on heavy rail tracks, so I'd say no :)
Mutant Lemming
8 Aug 2011
..but could it really run on the national rail network ? It is restricted to 20mph on the Stourbridge branch and even then it's a fairly rough ride. I wouldn't fancy it's chances out on the proper rail network.
Simpler answer: it's used by National Rail, so it belongs on the National Rail board.
..but British Railways used to run the Grimsby-Immingham tramway and Vale of Rheidol line.
Crossover
4 Jun 2009
I'd actually love to see it out on the main line :D
I think part of the reason why they are so shaky is the jointed track of the branch line rather than entirely being the fault of the traction
Yew
12 Mar 2011
Maybe we could hook it with some pacers to the back of a 91 and see what happens at 125?
The Stourbridge Branch is a part of the National network, so by definition it can :)
WatcherZero
25 Feb 2010
It passed NR's tests for mainline certification, and they were more thorough with it since it wasnt from an experienced manufacturer...
Temple Meads
2 Sep 2010
Devon
I'll give you my verdict after I've ridden on it on Wednesday ;)
I'm strangely really looking forward to it!
185
29 Aug 2010
Deformed Ford transit with a lawnmower engine.
Still better than a 142 though ;)
sprinterguy
4 Mar 2010
Macclesfield
The Parry People Movers definitely count as light rail IMO. The Tyne and Wear Metrocars run over heavy rail tracks between Pelaw and Sunderland, but are still light rail vehicles.
As far as the PPMs are concerned, I'd also suggest that they are light rail vehicles in the traditional sense of the days of Colonel Stevens, rather than the ultra-modern supertrams that the term has come to describe in the present day. Quaint little contraptions that they are. They're the minibus equivalent of a Pacer!
Schnellzug
22 Aug 2011
Evercreech Junction
Although to be fair, a Model T Ford on rails would like a TGV in comparison.
Yes, maybe that's it; they a sort of rail breadvan.
Peter Mugridge
8 Apr 2010
Epsom
Has it ever happened yet ( that both 139s were failed at the same time and a 153 was drafted back in )?
WatcherZero
25 Feb 2010
Far as i know the only time the 153 returned was just after the trial when there was only one as the second hadnt arrived to provide cover in case of failure/maintenence. They are averaging 96% reliability and only on one occasion (to my knowledge) have both failed at the same time, second was sent out to recover the first after it failed and it failed too.
sprite
4 Jan 2011
All this talk of them looking like transit vans etc, am I the only one that sees them as a railborn Fiat Multipla?
If it wasnt for the engine using LPG I would be wholeheartedly in support of them to enable more hybrid light/heavy rail projects to occur.
But the LPG thing puts me off.
WatcherZero
25 Feb 2010
Their putting a normal diesel engine in the next attempt of their latest trial service, the first attempt the lpg engine didnt have enough oompth for the gradients and the flywheel ran out of power between stations. Also locals were concerned with LPG storage risks. I think they mainly trumpet the LPG to lower the emmisions compared to a normal diesel railcar.
150222
9 Jul 2011
They do if the 139s fail.
No they don't! The crews do not sign them anymore. I don't think they are even employed by London Midland. Also they have/are planning to segregate the branch from the rest of the network by lifting the junction to platform 1 at Stourbridge Junction.
I hope your on about the older one! :)
dooton
18 Nov 2010
I don't think so, they are looking at running them on the line to Brierley Hill which means they would be running on the same tracks for a short distance as the 172's. They would have to go into platform 1 as I cannot see there would be free paths into the main platforms. Perhaps this would mean a slight reduction in the shuttle to every 15mins?
WatcherZero
25 Feb 2010
The connection has already been lifted, the branch line is now physically isolated.
