Potential solutions for earth shifting after dry weather?
renegademaster
22 Jun 2023
Croydon
I have not thought this through deeply obviously, but if this was caused by earth shifting after dry weather, could a solution be either some kind of irrigation system in problem areas or having the RHTT train spray the track with water every night during dry weather.
This has been suggested many times.
The amount of water required even for one small site like this would be phenomenal. And there’s a hosepipe ban on!
But this doesn't apply to businesses if its for commercial or essential services. Maintaining and running a railway is an essential service
I know, but it’s not a good look with a train very publicly dumping a million litres of water a couple of times a week to keep just 1km of track ‘hydrated’ (that’s the sort of quantity we’re talking about). While Mrs Miggins can’t water her Dahlias.
Magdalia
1 Jan 2022
The Fens
Here in the Fens lots of railway would need to be treated, and there would not be enough water to do it.
Firefighters had to resort to some fairly drastic measures, including closing waterways to navigation, to get water to fight the Holme Fen fire.
EDIT I have now found the BBC News story on this:
A retired boat-dwelling couple fear they will be marooned for months due to efforts to fight a major wildfire and conserve water levels.
Terry and Margaret Watson, from Northampton, said emergency lock closures allowing firefighters to abstract water from the River Nene had left them stuck at Foxes Marina in March, Cambridgeshire - 80 miles (130km) from their usual home mooring.
Meanwhile, a couple mooring in the Ely area said they were stuck in Northampton.
The Middle Level Commissioners (MLC) body, which looks after the waterways in the Fens, said its system was acting as a "conduit" to transfer water to the Holme Fen fire area and working closely to support the various agencies involved.
Technologist
29 May 2018
If we look at monthly rainfall about 50mm is typical in drier bits of the UK, if we needed to replicate this on 5% of the network to a width of 10m we would be looking about 400,000 tonnes.
That would be about 130 fully loaded tanker trains per month.
Sounds pretty doable
positron
18 Oct 2022
Cardiff
This might be a silly suggestion but does it even have to be fresh water? Could you use sea water and thus not even use the precious fresh water reserves? Probably not great to dump a tonne of saline into the wider environment though.
I suspect the more viable long term plan is to reinforce and even rebuild some of these earth works to a higher modern standard?
SynthD
4 Apr 2020
Jump straight to this plan. Are land anchors a relevant temporary measure before building a more technically planned embankment?
Harpo
21 Aug 2024
Newport
Judging by the C2C restrictions, the impacts extend to all three basic earthwork forms of embankment, cutting and the following of flat terrain and extend for many miles. 2025’s restrictions were about 20 miles in total when I used it.
Acathater
11 Dec 2025
NorthWest
Using sea water would result in salt poisoning the soil in surrounding fields, badly affecting plant growth. You'd also kill much of the river life, most of which isn't salt tolerant
Mike Machin
19 Aug 2017
The amount of water would be truly phenomenal! To have any effect whatsoever the amount of water in say a twenty tank wagon train would only cover around twice or three times the length of that train, meaning that a squadron of dozens (possibly hundreds) of such trains would be needed for each route.
With people in the South and South East not only living with a hosepipe ban, but having to endure low water pressure and disruption to their supplies, including a complete loss of mains water for several days at a time, watering railway infrastructure could never be justified. And, in drought hit areas, the amount of water needed simply isn’t available.
Don’t forget that in dry conditions, the whole area is dry. Water you spray onto the tracks will, very quickly, percolate to a much wider footprint than 10metres as it spreads out.
And also, in very dry conditions in summer water sprayed locally will evaporate very quickly. (Look up “effective rainfall”).
All told, you need about 2-3000 tonnes of water per km of route per week, minimum.
And that which doesn't evaporate is mostly absorbed by plants.
Maybe what's needed is for water main leaks to only occur in the vicinity of railways in need of "watering" :lol:
JamesT
25 Feb 2015
The proper solution is that the track sits on top of something that isn’t affected by prolonged hot weather. But I suspect that rebuilding on that scale will never happen.
I can't find a dedicated thread for the current WoE line situation, but the area should be getting a decent dollop of rain over the weekend, on top of sporadic rainfall this week so far. Hopefully this should at least stabilise the embankments; likewise for other areas struggling.
Acathater
11 Dec 2025
NorthWest
more likely to result in washouts, collapses, blocked drains, and floods
Magrar
20 Jun 2026
Reading
The solution presupposes the railway even has the first clue which bits of it are vulnerable to this kind of settlement, where the long term absence of water is a factor, and which bits where the sustained application of even small amounts of water, if done over long enough periods, could have similarly disasterous effects.
I was quite struck by the fact the engineers who upgraded the Ashington freight line to passenger service, apparently had no clue that the embankments on the line were formed from ash from old mine workings. As a result, presumably with a mind to modern engineering standards, they had to do a lot more work than they had previously thought necessary, to ensure the embankment was stable enough for a double track.
You would think that kind of thing would be documented somewhere, as part of some nationwide land survey of the permanent way, let alone be common knowledge among the railway engineering sector. But evidently not.
I'm no expert, but running a rehydrarion train for weeks on end, over an embankment formed of ash, would not be advisable. I have been told by structural engineers that even a tiny crack in a toilet soil pipe, given the frequency and volumes of the typical household toilet, would far exceed the amount of water expected in rainfal, and thus, eventually, cause settlement in the foundation. And that's in ordinary soil, not ash.
The railway does know which parts of the network are vulnerable to Soil Moisture Deficit, which is why additional precautions are made for those sections.
Acathater
11 Dec 2025
NorthWest
Possibly a crazy idea but is there any way of stabilising embankments by injecting them with grout, like with unstable tunnels?
Magrar
20 Jun 2026
Reading
OK, so there must have been some other reason why they were apparently completely unaware the embankments on the Ashington line were built using ash not earth? Surely not just because it was a freight only line....
I think, perhaps, you might be confusing the detailed geotechnical part of a project’s development (which naturally sees increasing levels of detail though the debelopment process), and knoweldege of the base geology that site beneath the railway formation.
andy33gmail
23 Mar 2025
cambridgeshire
This seems to be the best place I can find to follow up some of the discussions on track repair caused by the hot weather / water deficit. But happy to be told otherwise
Exactly.
The required track geometry has been lost because of settlement of the soil under the ballast. There wasn't enough existing ballast under the track to allow the tamper to lift the track back into position and be able to pack the voids from the lift. So new ballast is dumped on top of the old ballast, the tamper lifts and packs both old and new ballast into the voids and geometry is restored.
Do you eventually run into practical problems if the thickness of ballast becomes too great? To take an absurd example, suppose an area of the fens drops a metre or two over a decade or two … presumably at some point the ballast would be unstable?
There is loads of additional tamping planned all over the affected parts of the network. When the banks ‘unshrink’ there will be issues, and that will need more tamping. It’s predictable in an unpredictable way, if you get my drift, as some of the sites go ‘off’ very quickly. The amount of ballast dropped on some of these sites over the past few years has been incredible.
Indeed. And statistically it is highly improbable that at some point you wouldn’t get a concentration of such incidents, especially in the current weather condtions.
Is there any correlation between track movement and frequent overhead equipment failures that have happened this summer? I.e. separate to the impact of heat on the overhead wires & supports, does misalignment of the track contribute meaningfully?
It‘s not unheard of, but not this year. The very recent ‘OLE issues’ north of Cambridge have been, err, not OLE issues north of Cambridge.
stuu
2 Sep 2011
The OHLE masts can also move - north of Ely has a history of doing so if I'm not mistaken
