Possible disruption 19th September?
sloaneesq
19 Jan 2020
Felixstowe, Suffolk
So the lines weren't closed at the request of the security services as all lines pass under the Westway and the route of the funeral procession to Windsor?
Edit: I got my geography wrong. The cars went A4 / Hammersmith Flyover, not A40 / Westway. Not near GWML.
Horizon22
Jobs & Careers
8 Sep 2019
Forgot HEx use mainline too...rather major oversight!
There’s no pure diesel stock on the route (with the exception of the 0541 to Greenford). On major issue is electric services still stranded on the line that need clearing, no way endeavour.
Internal source does not show it passing past Southall. RTT only shows eta of 6 late at Pad.
No even RTT has a last report at Hayes. Everything else is estimated.
embers25
16 Jul 2009
Traksy is still showing the 0534 stuck past Hayes. Hopefully they have evacuated by now! Also, all IEP on this route can and fine run on diesel so were a line to be cleared they could run through. I see the furs cross rail from West Drayton is nearing Reading and GWR managed a train to slough
JN114
28 Jun 2005
There was a separate thread to segregate out specific arising disruption but that has been silently locked so I guess here is the place:-
RE the Hayes disruption.
All trains were safely evacuated within a couple hours being stranded; it was evident very quickly that it was not going to be possible to restore traction power so efforts were the focussed on getting staff to trains to facilitate controlled evacuations of stranded trains - 6 in total (1 HEx, 3x GWR, 2x EL).
OLE damage affects all 4 lines. Down Main and Up Relief are in the process of being cleared of debris so that diesel traction can operate; but even when that is achieved there are 2x Crossrail units (Ex 9P23 and 9P25) blocking the dead section of the Up Relief which will need rescuing by locomotive. There is a loco on hand to achieve this at Paddington. There's also a Heathrow Express straddling the Down Main/Down Airport at Airport Junction; again without power due to isolated OLE sections.
The damage to OLE is however severe, so I would guesstimate no electric services in the affected sections for the remainder of the day; and a limited service likely tomorrow as it will need to be off for repairs to be afffected.
RE the Datchet disruption.
It had been planned, albeit not publicised (possibly intentionally) to close the railway at Datchet Level Crossings for a relatively short period of time to allow the procession from London to Windsor Castle to cross the railway at Datchet. The procession ran late; but BTP still took the closure of the railway on time. As such the line ended up closed rather longer than anticipated, with a ~40 minute pause in services between Staines and Windsor. This was then compounded as the train at the head of the queue at Staines couldn't be moved out the way as the crew only signed towards Windsor, not Egham so the train couldn't be diverted elsewhere to let the Readings stacking up behind through.
cactustwirly
10 Apr 2013
Why is it taking so long?
Should have been fixed by now? It's been a good few hours, all that needs doing is a new wire being strung up. That surely doesn't take 10 hours
RacingGreen
6 Aug 2017
The South.
How long should it take? Have you ever replaced OHLE? I think it's a little more complex than just "stringing up" some new wire.
Darandio
24 Feb 2007
At least two miles of cable damage. Trains stuck within said damaged area that require rescue. All masts and arms need checking for further damage, the latter might require replacement. Other associated lineside equipment needs checking in the areas wire has come down around it.
Yeah, easy.
IainG81
19 Mar 2017
Currently at West Drayton there's a service westbound only towards Reading, trains are terminating at West Drayton, there's a stationary train in Platform 2 that's not in service.
rebmcr
15 Nov 2011
St Neots
I would be unsurprised if full service was not restored for several days.
800001
24 Oct 2015
2 lines opening for diesel only, once the last 2 stricken trains are moved.
Damage is across all 4 lines of the Overhead cables, (have heard over 2 miles, not verified).
JN114
28 Jun 2005
Wires down/damaged over 4 lines, over a distance of 2 miles. That's not the work of a couple of hours.
cactustwirly
10 Apr 2013
Well clearly something has gone badly wrong today. The railway isn't fit for purpose if a major line out of London suffers this amount of disruption.
I thought the OLE was all upgraded in this section, clearly it was a waste of money.
This isn't the first time this has happened, either.
dciuk
1 May 2018
According to a previous post this was not part of the new electrification
Essexman
15 Mar 2011
The Night Riviera sleeper is cancelled tonight in both directions despite being diesel.
Could that be because they want all four line closed to work on overnight - but in that case it could have started and terminated at Reading. Or do they need the loco to assist elsewhere?
Hope the sleeper is running tomorrow as I'm booked to Penzance.
Ediswan
15 Nov 2012
Stevenage
The procession approached Windsor via Runnymede and Old Windsor, not via Datchet. Not saying the closure was not part of the grand plan though. Maybe the cars which had to beat the procession from Westminster to Windsor went that way.
cactustwirly
10 Apr 2013
The sleeper stock is based at Reading so no reason why it can't be started at Reading tonight
62484GlenLyon
30 May 2021
Royston
The ecs of last night's Penzance to Paddington sleeper, 1A50, is still in Paddington. Also, if I have understood OTT correctly, the inward loco of 1A50 is now 0Z99.
AlexNL
19 Dec 2014
The new bits start at West Drayton. Between Paddington and Airport Jn it's mostly a 1990s BR design of electrification, similar to what's around on the East Coast Main Line (headspans, wires holding up the juice wires). Which is equally prone to the type of failure where damage to one track can lead to the wires coming down across all four.
Paddington - Airport Jn has seen reinforcements during GWEP, but as far as my knowledge goes has mainly addressed the most riskful locations and not a complete re-electrification.
SuperLuke2334
23 Oct 2021
Welsh Marches
There appears to be a 1Z99 currently passing Southall heading for Paddington, maybe that is a loco to rescue the last 345? Potentially a 37 or 57?
skyhigh
14 Sep 2014
Nice to see that you've made a site visit, ascertained the level of damage, surveyed the technical requirements and come up with a repair plan. Maybe you should share it with the OHLE and control teams to give them a hand, seeing as they're missing your expertise?
sk688
11 Sep 2016
Dublin
had to travel to Bath from Milton Keynes for something ,and had one hell of a journey trying to get there as a result. Ended up having to do Clapham-Reading-Swindon-Trowbridge-Bath , but got there eventually.
Full credit to GWR staff who were trying their hardest in whats obviously not an ideal situation.
Will most likely go back via Oxford , and try get to Aylesbury/High Wycombe in terms of getting back.
Horizon22
Jobs & Careers
8 Sep 2019
Nope this is the old stretch of electrification previously in place for Heathrow services back in the 1990s, nothing like the bombproof stuff on the rest of the GWML.
And yes nothing like this has happened for many years. It’s just very very unfortunate timing.
Although please do tell us about the ease of replacing damaged 25kV wires over a couple of miles.
Wilts Wanderer
21 Nov 2016
I'm trying to work out if you're being deliberately sarcastic or are really this ill informed!
