Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
Peter Sarf
Croydon
75% availability only six days a week is the lowest threshold for success in GB rail today no?
Never let progress get in the way !.
The minimum an operator should have is one unit as a running spare and one unit available for maintenance. So if you only have eight altogether 75% is what it is. It is a microfleet after all.
It is getting better and if this holds up then really what more is there to expect/want ?. It is NOW not bad for a rather unusual/experimental train and a microfleet. But we must wait and see.
thealexweb
5 Jan 2014
7 out of 8 available from start to end of day routinely is a reasonable ask
Peter Sarf
Croydon
I would expect minimum one unit on maintenance and one unit as a running spare. So 6 out of 8 dictates 75%.
That's the issue with a micro fleet. If it were a fleet of sixteen I would still expect only two not used which takes availability to 87.5%.
You cannot got less than one on maintenance.
You cannot get less than one as a running spare.
Unless you want to do without one or other contingency, But that is never planned for iirc.
david l
27 Dec 2016
Wigan
Not much fun for those that rejoice every time one fails. ;)
Your irony made me smile and provokes this response. To have achieved the diagrammed number in service 3 times in a week is a better record (particularly with only 7 available) - having achieved this now 5 times since October. Something from management must have been done, as units now sometimes remain in service on diesel.
I take absolutely as a regular user no joy in reporting the daily shortforms/cancellations and to be honest I'd like to see what would happen if what has been inflicted on the users on the Southport-Manchester Ox Road/Stalybridge services (let alone the staff) were to be inflicted elsewhere anywhere south of Crewe (excepting the 175's............)
To reply to others, there are 6 diagrammed out of 8, with 2 on maintenance at AN. However the current c6 programme (taking around 10-12 weeks per unit) which, once 442 returns in about 10 weeks time having only gone there last week, still has to have 2 others to go (448/50) which means that the programme will not complete for over 6 more months, meaning that the availability has to be 6/7. Of course the 2 ex-TfW units which were supposed to cover have gone back to Long Marston - but 421 was as much use as a chocolate teapot working 3 days -and failing each day, whilst 452 was a little better.
Regretfully though the c6 to most of the units (only 2 have had c4's as well so far) has not brought a consistent uplift in reliability (431 was awful for months after its c6, 456 disappeared for weeks whilst 424 which came back last week has worked 2 days and disappeared off to AN).
The ongoing problem is that the leases on these units now apparently run until 2031 - really, it'll be 2032/33/34....... when allegedly the 'cavalry' should start to come in terms of new units and probability of cascaded units.
Of course I could also mention the fact that we have a 6 day railway in these parts - Sundays don't exist for 769's or the Wigan- Bolton line, the 'new' wires have never yet seen an electric service on a Sunday.......poor return for the £100million that it cost.
Rant over!!
Gricer99
21 Jun 2020
Hindley
Very well put. In view of another 6 months of unavailability for at least one unit I would have thought they could at least have persevered with the Welsh unit that occasionally worked.
317 forever
21 Aug 2010
North West
Rant over!!
The new wires don't seem to see many Monday-Saturday workings yet either.
david l
27 Dec 2016
Wigan
Perhaps not between Wigan Station Junc and Ince ( 2 or so per day) but the bit between Ince (changeover point from/to diesel/electric) to Lostock Junc sees up to 4 per hour - depending (mainly but not totally) on the 769 availability.
317 forever
21 Aug 2010
North West
Oh yes, I'd forgotten that the electrified section is already used as far as Ince now.
stevieinselby
6 Jan 2013
Selby
If you allow for 1 in 8 to be out of service for maintenance each day, it's perfectly reasonable to diagram the other 7 vehicles of a microfleet for service as long as you have sufficient vehicles elsewhere in the fleet to substitute in if needed. If Northern are running the full service on those routes then they clearly do have enough vehicles in total, so there wouldn't be a problem in diagramming 7 Flex units and then subbing in a 15X where required instead of intentionally starting the day with a 15X in service just so that you can leave a Flex in the yard all day as a spare.
Peter Sarf
Croydon
I agree having a more universal spare from a different and bigger fleet is more flexible. Especially, if you can justify only needing to rely in it say 25% of the time, it is then a shared resource with the bigger fleet.
The cautious one in me would want a spare 769.
david l
27 Dec 2016
Wigan
Mon 16/2
No delight in reporting this but this is what happens.
6 start the day but 769431 only got as far as Newton-Heath-Man Vic-Stalybridge before failing. 769456 has been also taken from service to go and rescue 769431. No replacements so several services already cancelled. 769456 apparently will resume later having taken 769431 to SP?? Left out currently are 434/48/50/58.
424 still OOS at AN and 442 at Brodies.
Peter Sarf
Croydon
Mon 16/2
Well that undoes any idea of a spare unit being possible from another class.
So maybe back to viewing 6 in use out of 8 as the best achievable - microfleets.
I should have remembered you need a unit of the same class to rescue :oops:.
david l
27 Dec 2016
Wigan
Mon 16/2
769456 has not re-appeared in service, but there were no units on SP when passing at 15.35
AM9
13 May 2014
St Albans
Sorry, I'm no expert, but what is the problem with these units? Is it the AC to DC conversion, the MAN engines, or just the switch from electric to diesel?
i and others have asked this question many times over the years, but no definitive information has been released but some posters seem to know why many of the failures to run occured, including lack of drivers, signal issues and other trains blocking routes.
Gricer99
21 Jun 2020
Hindley
There have been many problems with the ageing doors and the raising and lowering of the pantographs to my knowledge.
M60lad
31 May 2011
Not to sure which one but there was a 769 stabled at Newton Heath tonight at 19:25.
Soft Hands
27 Dec 2020
Bolton
769456 "worked" the 11.27 Oxford Road to Southport, starting at Manchester Victoria, and then terminating at Wigan Wallgate, when it "retired" to Wallgate sidings! They did try! RTT showed the usual "M8" (train unwell!) code. The following 150/156 combo was then split at Southport to run the next two services back towards Manchester!
david l
27 Dec 2016
Wigan
As well as a 769 going back to NH early this morning (769431?), there was a move booked from Wigan Wallgate CS to AN tonight that has been cancelled- presume 769456.
The 2 ECS from Wigan NW-AN tonight (5Y63/5) that are booked for 2 separate 769's are formed of 150108 and 156421 which were 'purloined' during the day to maintain a service. It also now appears that 769456 did not 'rescue' 769431 but had its own problems before attempting to work as above. Not good!
Bikeman78
26 Apr 2018
The doors look the same as classes 150, 318, 320 and 455, all of which work fine. The pantographs I can understand a bit more. It is rare for most UK EMUs to raise or lower the pantograph in service. For example, during 25 years of riding 317s, I can only recall seeing the pantograph lowered and raised once. That said, the 313s went up and down 10 times a day and it didn't seem to be a problem.
AM9
13 May 2014
St Albans
Likewise all 86 of the 319s went up and down for around 30 years with relatively few problems.
david l
27 Dec 2016
Wigan
5 start the day, yesterdays 'casualties' 769431/56 have failed to come under starters orders. 769424/34/48/50/58 out. 1 x 4 car 156 DMU covering off AN.
diligentdave
20 Oct 2007
Most issues with 769's revolve around the electronics that control the engines and associated equipment. Just like they always did when they were normal 319's, traction motor issues are always an issue with 769's. That's normally most of the faults covered in one sentence.
AM9
13 May 2014
St Albans
Any knowledge as to why the 1960s style DC traction motors are believed to be exceptionally problematic. The same type was used on the 317s, did they have a similar history to the 319/769s?
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
That is unusual as generally they're very reliable. Don't think EE507s used on Southern gave much, if any, trouble.
Perhaps it's because they weren't EE derived?
