Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
Greybeard33
18 Feb 2012
Greater Manchester
Perhaps the amount of power used in Notch 4 is just more than the gensets can supply?
At high speed, I imagine that Notch 4 applies the full bus voltage to the motors. But the gensets cannot supply as much current as a third rail supply, so the bus voltage will drop to limit the current. It might well be that the resultant power at the rail is no greater than, or even slightly less than, in Notch 3.
AM9
13 May 2014
St Albans
On level track, I would think that the 700kW 'ish net maximum (a 319 has 990kW) is probably OK for 75mph, - even with a normal full passenger load, but it might take some time to get up to that speed.
Greybeard33
18 Feb 2012
Greater Manchester
Well, 780kW total at the engine crankshafts, less the alternator and motor losses and auxiliary/hotel power. A 150 gets to 75mph quite quickly on the flat, but that has 213kW per car at the crankshaft (852kW total for a 4-car). I doubt there is much difference in the transmission losses at 75mph. The 150's Voith hydraulic transmission drives through a fluid flywheel, not the torque converter, when in high gear.
paul1609
28 Jan 2006
K
The 769s engines are rated at 390kw each maximum by the time you take in to account alternator efficiency and rectification and auxiliary uses I doubt you have anything like 700Kw available at the wheel and with dc motors then not over a very wide speed range.
AM9
13 May 2014
St Albans
The 319 motors are continuously rated at 990kW, that's how those motors are rated. If the two gensets plus cabling and electronic traction control losses take the maximum 390kW of the engines down to 700kW, that's what the motors get in that mode. The torque of the motors is controlled by the electronics, but the power is still whatever is input. As a comparison, the power at the wheels of a 4-car 150 consist is something less than 4 x 210kW (allowing for hydraulic and mechanical transmission losses but varying greatly depending on engine speed vs wheel speed) spread over 8 axles.
Greybeard33
18 Feb 2012
Greater Manchester
700kW of electrical power to the motors does not equate to 700kW at the rail. The motors have resistive, magnetic, windage and friction losses. The 319 traction motors would have been designed to optimise performance, size, weight and reliability. Efficiency would have been less important in the 1980s, with plenty of cheap power available from the third rail or OLE. I do not have the figures, but the motor losses might well be as high as 10% at 75mph.
Jamesrob637
12 Aug 2016
Maybe they should be used on Sundays too because they seem to have reliability problems Mondays as demonstrated in the past couple of weeks. Seems as though resting them a day does them no good :Dnot to mention it would free up diesels from the Stalyvegas to Southport (obviously the Alderley Edge should run Sundays too even if only 2-hourly, however that's for another thread).
507020
23 May 2021
Southport
Why? Southport - Alderley Edge is of course not a required connection any day of the week, but is there not the capacity on Crewe services that there is routinely overcrowding north of Alderley Edge on Sundays?
DBNR
14 Apr 2020
Germany
How has the service been with these units in recent months? Interested to know if there have been any changes in reliability in recent weeks
507020
23 May 2021
Southport
I’m not sure if it has only been in recent weeks but reliability has definitely since they entered service. I haven’t been going on them as often this year though.
david l
27 Dec 2016
Wigan
Not brilliant, on few occasions only there have been 6 units out of 8 working (as per diagrams). Generally 5 have worked but today for example only 3 have worked, although possibly other considerations today (cancellations for crew shortages) have intervened.
507020
23 May 2021
Southport
Other than cancellations which would have been equally possible for booked Sprinters, have there been any more failures in service that made their introduction catastrophic or not?
175001
3 Feb 2007
Between Heaven and Hell
They definitely have settled down. They all had software updates on them a few months back now and it's made power changeover far more reliable.
A few diagrams had 156s on yesterday but no failures in service.
D9006
28 Aug 2019
Wigan
Well today is 1st day this week, according to real train times all diagrams(5) are allocated 769s, but the Stalybridge diagram is a 2 car 150, let’s see how the day goes
D9006
28 Aug 2019
Wigan
For info and historical point of view, RTT showing all booked diagrams(6)scheduled to be 769 today, 5 on Alderley circuit and the 1 Stalybridge. Yesterday 5 apart from staffing problems mamaged to see the day through to end of service
childwallblues
3 Jul 2014
Liverpool, UK
I rode 769431 from Stockport to Manchester Piccadilly this morning. On alighting I noted that the unit was in diesel mode. I this a regular occurence? The unit isstill in service tonight on the 2013 Southport to Nanchester Victoria.
175001
3 Feb 2007
Issues in AC mode this morning meant it was in diesel mode for part of its diagram.
Its very irregular but has happened a few times in the past.
Piccadilly drivers seem squeamish when you tell them it's in diesel mode...
507020
23 May 2021
Southport
The 769s should always be in Diesel mode for part of their diagrams…
Why? Do Piccadilly drivers not normally go past Bolton?
The ability to run on Diesel when AC mode rails is a good thing when the alternative is the service being cancelled.
sportzbar
11 May 2014
Almost correct. As the 769s operate Southport to Alderley Edge/Stalybridge and only Wigan and Vic drivers sign to Southport, Piccadilly drivers only drive them to/from Alderley Edge to Manchester Oxford Road. So the vast majority of the time they are in electric...
Greybeard33
18 Feb 2012
Greater Manchester
From December these Oxford Road crew changes will be eliminated, as there are to be separate Southport - Oxford Road and Piccadilly - Alderley Edge services. This should improve Castlefield corridor performance significantly.
175001
3 Feb 2007
As I 769 driver, I know that
I was taking about it's whole day diagram.
Piccadilly drivers don't go north of Occy Rd with them. Vic or Wigan drivers take them to Southport from Oxford Rd.
507020
23 May 2021
Southport
So who drives the Blackpool North - Hazel Grove/Airport services past there? (I know these are pure electric)
Admittedly this sounds favourable operationally if drivers only sign as far as Oxford Road, minus the need to foul all lines to reverse out of the bay, which damages Castlefield performance quite significantly, but it’s not sustainable since it doesn’t serve the fundamental need from Southport/West Lancs passengers for a service at least as far as Piccadilly.
py_megapixel
5 Nov 2018
Northern England
It serves that desire fine, because changing at Oxford Road is extremely easy, so anyone who wants to go to Piccadilly can do that. Saving a half-minute walk for people from a provincial town 30 miles away is not a reason to hold up one of the country's most congested rail corridors with unreliable rolling stock and crew changes.
507020
23 May 2021
Southport
If the next Piccadilly service leaves from P3 then it is a lot more than a 30 second walk. It would be advisable and much more pleasant to change at Deansgate if trains stop there or even Salford Crescent than attempt to change at Oxford Road.
Llama
29 Apr 2014
Blackpool/Hazel Groves can be worked by any of:
Manchester Victoria drivers (partially or throughout. Only two links sign Oxford Rd - Hazel Grove, but all links sign Oxford Rd - Blackpool North), Buxton drivers (partially or throughout), Piccadilly drivers (Oxford Rd to Hazel Grove, possibly some from Oxford Rd-Preston as at least one link at Piccadilly signs Preston via Chorley), Blackpool drivers (Oxford Rd-Preston or BPN), Wigan drivers (Oxford Rd-Preston or BPN) or Liverpool drivers (only Preston-BPN).
The Manchester Airport-Blackpools can be worked by a similar list to the above - but Blackpool, Wigan, Liverpool drivers do sign Oxford Rd to Manchester Airport whereas they don't sign Hazel Grove. Buxton drivers sign Hazel Grove but not the airport. Liverpool drivers don't sign via Chorley.
There's nothing like keeping it simple.
py_megapixel
5 Nov 2018
Northern England
Almost everything to Piccadilly departs from platform 4. In fact, I can only see four services today that have used platform 3; none of them were booked to do that, and on all but one, an alternative was available from platform 4 no more than 5-10 mins later.
Ironically, 2 of the 4 were the through Southport services, which just highlights how unreliable they are.
Nothing stopping anyone who wants to changing at Deansgate or Salford, though.
Techniquest
19 Jun 2005
Nowhere Heath
Changing at Salford Crescent is certainly a better option than changing at Oxford Road, if ease of doing so is crucial. Otherwise, as you say, the vast majority of connections can easily be made on p4 at Oxford Road. Oxford Road is also ideal for those wanting the city, it's not that far a walk to St Peters Square for example.
I thoroughly dislike how long it takes to do Piccadilly to Oxford Road, and indeed onwards past Deansgate, when I'm in the area. So anything that helps improve that experience gets the thumbs-up from me!
Gricer99
21 Jun 2020
Hindley
That all sounds very complicated! So still absolutely no chance of getting a decent connection to Heald Green and the airport from Hindley from December then?
