Points failure between Hazel Grove and Buxton yesterday
dcbwhaley
4 Aug 2018
Does anyone know where the failure was.
There were no trains between the two yesterday but there was an advertised train in the evening to Furness Vale
Thomas6187
27 May 2011
Rochdale
The failure was at Buxton. I believe Network Rail found quite considerable damage which took several hours to fix
Mcr Warrior
8 Jan 2009
Possibly problems at Hazel Grove as well as EMR and TPE were apparently also affected earlier in the day. Might have been a separate incident though. Anyone able to confirm? Incident was reported as cleared at 21:13 and it does look like late evening services between Manchester Piccadilly and Buxton did resume.
Extract...
National Rail said:
Route(s) affected​
Between Manchester Piccadilly and Buxton
Description​
Disruption following an earlier points failure between Hazel Grove and Buxton has now ended.
dcbwhaley
4 Aug 2018
So why did they stop at Hazel Grove? They could have run to Furness Vale where there is a cross over
Its not a signalled move back to Hazel Grove. The shunt signal is only to go back towards Buxton. Presumably they needed a MOM/LOM to sort it on the ground.
dcbwhaley
4 Aug 2018
Is that crossover serviceable? No idea myself unfortunately!
I believe so. I drink with one of the Furness Vale signalmen and, a couple of weeks ago, he told me that he had used it. And been very nervous about doing so.
furnessvale
14 Jul 2015
My next door but one neighbour works that box, I'll ask him.
