Permitted routes between Skipton and London
xotGD
4 Feb 2017
I haven't got a clue about this routing lark. Could some kindly person please advise if any of the following are valid for travel between Skipton and London on a 'normal' ticket:
Skipton - Lancaster - Euston
Skipton - Lancaster - Birmingham - Marylebone
Skipton - Leeds - Birmingham - Marylebone
Skipton - Peterborough - Cambridge - Kings Cross
Skipton - Peterborough - Cambridge - Liverpool St
Next time I go to London and have time to spare I wouldn't mind making an excursion of it.
alistairlees
29 Dec 2016
Others will correct me if I am wrong (I have not had time to check properly) but I don't think that Skipton to London is valid via Lancaster. Nor do I think it's valid via Birmingham (you're not valid on Derby to Birmingham).
The last two routes via Cambridge are fine. You can also go via Lincoln. You could also do the MML (via either Derby or Nottingham) to St Pancras.
xotGD
4 Feb 2017
I was aware of the St Pancras routing - even our corporate travel provider throws up those options on the through services to or from Leeds.
They do make it difficult but if you think outside the box, you can get a ticket (or combination of tickets) that enables what you want to do.
Skipton - Giggleswick single plus Giggleswick - London Terminals return, allows a round trip outward via Lancaster and returning via MML or ECML etc.
Skipton - High Wycombe ticket routed +Any Permitted allows a round trip outward via BMO & MYB providing you get a train that calls at High Wycombe, and returning via MML or ECML etc.
xotGD
4 Feb 2017
Many, many thanks! :D
JB_B
27 Dec 2013
Does Lancaster Group pass the NFM64 fare check?
Could this be an issue with the RP Calculator, then?
The RP calculator isn't always right (people have discovered issues with other routes too).
It's the interpretation of more than one booking engine that Lancaster Group passes the fares check.
JB_B
27 Dec 2013
Thanks, Yorkie - that's useful to know.
I think I read somewhere that booking engines don't use the first-routing-point-group-member-encountered rule (Carnforth in this case) and instead do the fares check using a 'principal' group member - or did I imagine that?
