Penalty notice fraud
Mysterymum
26 May 2018
I have been sent a penalty notice, correct name and address. It doesn't give the time but I didn't get a train at any time that day and I have never been to one of the stations the fine is for.
Therefore someone has used my details fraudulently.
What is the process to appeal this?
Gloster
4 Sep 2020
Up the creek
Please post the notice in this thread. Please obscure your name, address and any other identifying details, such as reference numbers.
Haywain
3 Feb 2013
If it’s a letter you simply respond that it wasn’t you.
jfollows
26 Feb 2011
Wilmslow
You’re not appealing anything, you tell them that it wasn’t you.
This happens all the time and the rail companies know this. They have to prove it was you, which they clearly can’t. It does not harm if you think about where you were at the time, but don’t obsess about it.
That said, it’s pragmatic to work with them, so they may request something from you with your picture that they can compare against their records of the event. This ought to get them off your back.
Or you can tell them to get lost, but you might end up with having to go to court in future if you do. Working with them should avoid this. Just make sure you get something in writing from them.
WesternLancer
12 Apr 2019
To add to other posts someone is impersonating you. So immediately take wider measures to check and prevent any id fraud eg passwords, check all ok with bank accounts etc. if you have moved house recently get removed from electoral register at old address and get on the register for new address. Check with the local councils concerned to get that sorted.
