Paignton station footbridge on fire 21/07/26
REVUpminster
3 Jan 2021
Paignton
The portacabin ticket office was at Paignton Saturday but closed. A 5 car voyager came in from Manchester 47 late at 1941 and left for Bristol at 1947 using platform 2 instead of it's usual shunt via the crossover.
I was there at 1700 to see the Kingswear-Shrewsbury train depart at 1727 which waited just off the platform so it could pass through without stopping when the signal cleared to yellow. As usual there were no staff on the station after 1700 and there were people on platform 1; train spotters like me?. The gate to the platform has been locked since the fire so I don't know how they got there.
vlad
13 May 2018
Surprising that XC and Paddington trains are not serving Torre and Torquay yet, unless perhaps they can't use Goodrington sidings where they often rest up,
I notice that the trains to/from London Paddington are still only running as far as Torquay in passenger service, even though they're going to Goodrington to reverse. I suppose it's because they're too long to fit into the current platform at Paignton.
XC seem to be running to Paignton occasionally and at other times deciding they're going to terminate the train at Newton Abbot. There must be a reason for what they're running and what they aren't but I can't figure it out.
8 Jun 2026
Somerset
Yes, the platform lengths at Paignton have been restricted because of the damage (one platform more than the other, I am led to believe) - GWR local trains of up to 4 vehicles (max 80m length here normally) are fine, the longer IET and Voyager formations less so.
REVUpminster
3 Jan 2021
Paignton
Platform 2 can take five car trains. Todays Voyager's seem to be running late and turned at Newton Abbot. Interesting to see what happens tonight as the voyager usually goes into platform 1 and reverse via the crossover to platform 2. Nine car trains work empty Torquay-Goodrington-Torquay. The tour train last Saturday waited (11 coaches and top and tailed with a diesel locomotives) just off the platform until it received the starting signal (yellow) and proceeded through platform 2. It followed a local 4 car 150 train.
Add: Tonight's voyager cancelled at Bristol.
Future
28 Nov 2021
Devon
Roof now completely removed out the front of the station
Mcr Warrior
8 Jan 2009
Was it established whether the seat of the fire was the footbridge itself, or one of the buildings underneath and so at platform level?
REVUpminster
3 Jan 2021
Paignton
As far as I know it has not been said. The footbridge should be locked before the station staff go home. Looking at the pictures and the fire spread along the footbridge which as far as I remember was tarmac over wooden flooring I wonder if the gate was broken to start it on the upper staircase. Perhaps the boys phones have the answer.
Russel
30 Jun 2022
Lichfield
The bridge and structure around around it wood and covered in 100 years of paint it probably wouldn't take much to spread wherever it was started.
CR165022
12 Nov 2019
Buckinghamshire
Looking at the timetable from the 15th, services from Paddington will be able to run all the way to Paignton in service again instead of finishing at Torquay, but then still would still have to ECS back to Torquay to go back to Paddington
8 Jun 2026
Somerset
Trains can arrive can arrive in Platform 1, but they can only depart from Platform 2 which is currently restricted to 4 coaches.
CR165022
12 Nov 2019
Buckinghamshire
I believe they do but if they use it at Paignton when only a few carriages can fit on the platform, it would most likely overhang on the level crossing towards Goodrington
