nigelsporne
This may have been covered elsewhere but I have missed it. What will the platforms at Paddington and Liverpool Street, that currently take the Crossrail services, be used for once these services are diverted later this year?
A look at RTT for a date after the December timetable change will show how platform usage at both stations is changed once Elizabeth Line trains generally no longer run there.What will the platforms at Paddington and Liverpool Street, that currently take the Crossrail services, be used for once these services are diverted later this year?
Thanks for this. There is the opportunity at Liverpool Street to revamp the approach to the Station from Bow Junction. Really the two slow lines will become free once Crossrail is up and running. These lines took the Shenfield services and the occasional ECS and C2C services. So for example the Southend services, in part, could be diverted at Bow. Just a thought.
There is no point in making infrastructure interventions if they are not necessary for the service levels. With no sign that services will need to return to the levels seen prior to 2020, let alone more, the money needed to make interventions can be better spent elsewhere.There is the opportunity at Liverpool Street to revamp the approach to the Station from Bow Junction.
Liverpool St was supposed to retain peak only Crossrail extras to/from Gidea Park, running at 4 tph, but I don’t think that’s happening in the full numbers expected. I found 2 up trains in the morning and 2 down in the evening peak using P17, does anyone know if that has a planned date to increase?
Can 16 and 17 take 745s (not that it is the ideal place to put the flagship service)?If GA had kept to 4/8/12 x 20m instead if 5/10 x 24m stock that may have helped the business case for Bow Jn, but it's all too late for that now.
No, 745s are too long. The once muted Lowestoft to Liverpool St trains could use 16/17, but they bring their own set of different problems.Can 16 and 17 take 745s (not that it is the ideal place to put the flagship service)?
