Pacers at Manchester Piccadilly
gnolife
4 Nov 2010
Johnstone
Sheffield / Marple / New Mills Central / Rose Hill Marple are some of the destinations.
Plus Chester (via Altrincham), and I think they can turn up on Liverpool via Warrington Central services
sprinterguy
4 Mar 2010
Macclesfield
Looking up i cant see any pathed
If you're using publically available train times websites then that's not surprising: The rolling stock information they convey are (fairly general) timing loads, not necessarily what type of train is booked to operate a certain service.
Tony Candland
5 Feb 2019
I use the realtraintimes website
ForTheLoveOf
7 Oct 2017
This purely says what the timing load (i.e. the basis of the calculations for acceleration, deceleration and top speed) is. For many services where 100% accuracy isn't critical, this will be a generic timing load that bears no relation to the actual stock running the service.
Tony Candland
5 Feb 2019
Ah ok so its a matter of seeing if it turns up as a Pacer ?
sprinterguy
4 Mar 2010
Macclesfield
Yeah, just timing loads then.
Anecdotally the Manchester Piccadilly to Rose Hill Marple or Hazel Grove services are often pairs of 142s, although they also share those duties with 150s. I've also caught a 142 on a Preston service from Piccadilly, but that's something that's likely to be a thing of the past soon as class 319s are introduced to the route.
ForTheLoveOf
7 Oct 2017
With operators that have a fleet as large and varied as Northern do, a timing load of "15x" could mean just about any of their fleet (though likely the diesel contingent of it), pretty much, yes. What gets sent out will vary from day to day depending on the availability of stock (i.e. what's being maintained and what's working).
For smaller sub-fleets, diagrams are usually more accurate, and track particular units through the services they are scheduled to operate throughout the day. But until the Pacers become rarer, it'll be a hit and miss game unfortunately... Perhaps ironically, when there are fewer of them left it's possible there might be some more stable diagrams.
Tony Candland
5 Feb 2019
I'm off there on Thursday so i'll hopefully catch a few
Tony Candland
5 Feb 2019
Thanks for the valuable info , i'm hoping to ride a few before they are taken off altogether, last time i did was 20 years ago so its a nostalgia thing plus i wish to film photograph a few
ForTheLoveOf
7 Oct 2017
If you get yourself a walk-up ticket or a ranger/rover of some description, you would be very unlucky not to bag yourself at least a couple if you go around the Manchester area.
Clip
28 Jun 2010
You can also find them paired up with other units too just to make the trip to blackpool more interesting :D
13 Apr 2011
Helsby
To obtain the full Pacer experience it's best to wait until it's raining so you can enjoy the raindrops running inside the window and down your leg, certainly if you are over 6ft in height and your having to sit with your knees splayed and hard up against the side of the carriage. :smile:
Matt_pool
9 Nov 2016
You still get a lot of Pacers on the Liverpool - Warrington Central - Manchester Oxford Road service.
Sometimes you get them on the Liverpool - Manchester Airport service which calls at Piccadilly and Oxford Road. The 16.16 from Lime Street to Man Airport on 20/02/19 was a Pacer. Imagine you've got a Transatlantic flight from Manchester Airport but you start off your journey on a Pacer from Liverpool. :rolleyes:
Matt_pool
9 Nov 2016
P.S. the Liverpool stoppers via Warrington Central all use the bay platform 5 at Manchester Oxford Road, so if you enter the station through the ticket office and look over to the right you will be able to see straight away if your chariot will be a Pacer, 150 or 156! :lol:
jonesy3001
13 Jul 2009
Otley, West Yorkshire
Or go to ardwick station in manchester, you'll see everything on there.
The rose hills,marples,newton heath and longsight movements and the airport/stockport bound trains.
gnolife
4 Nov 2010
Johnstone
You're a bit stuffed if you actually want to travel on them though
