P.I.S. poor (on refurbed units)
SpacePhoenix
18 Mar 2014
On the Weymouth-Waterloo route, when the PIS is reading out the list of stops, does it have to load a second file? It gets to about Southampton, then there's a noticeable pause before it carries on reading out the stops
mbreckers
20 Jan 2015
Sometimes the PIS on 156's that operate Kilmarnock - Glasgow Central get confused as to whether they're approaching a station or whether they've left the station.
I've seen the conductor going into the rear cab and it fixing so I assumed they fixed it somehow, seemed to take seconds
Fincra5
6 Jun 2009
IIRC the Southern region Electrostars run Windows 98, although since Class 379 they've converted to a Linux platform - not sure about Class 376 or 378.
Been upgraded to Windows XP these days :)
redbutton
5 Sep 2013
377s run Windows XP as the OS underneath the MITRAC train management system. You see the shutdown animation when you aux-off the unit.
I don't know if the internal comms are Ethernet-based, but the MITRAC system must not be essential to move the train, since it's possible (and a procedure exists) to isolate it.
JaJaWa
14 Feb 2013
Slightly off-topic but the PIS on Go North East buses is literally built in PowerPoint!
scotraildriver
15 Jun 2009
156 have an oddball Alstom PIS, which works both on GPS but also the door system. It will only move on when the doors are released and is set up with the doors open. Therefore if it gets out of sync it stays that way until the driver resets it. Its not very good really.
TEW
16 May 2008
The system on the FGW Turbos works on door release too, and likewise can get itself out of sync and announce the station one ahead of where you actually are. If the doors are re-released for whatever reason at a station the system automatically jumps forward a station.
OpsWeb
14 Oct 2014
The Class 318/320 PIS system is also GPS and door operated. Sometimes you can "trick" it when in tunnels (and therefore no GPS feed) to advance through the stations, but if you out in the open (with a GPS signal) - trying to move it along is hit and miss.
I'm always amazed / disappointed that in this day and age, the PIS on trains is always about 30 years behind the rest of the technology. The Class 334 for example was a technologically advanced train when it came out in 2001, with regenerative braking, combined power / brake controller, remote download facility etc..., yet the PIS can't cope with the train reversing at Springburn!
ADRboy
13 Jul 2008
PIS systems in general are terrible IMO. Ridiculously hard to sort out faults with and the dot LED displays almost always look odd. Better to run a normal LCD screen that can show more info.
SpacePhoenix
18 Mar 2014
Will they be more reliable to ETCS lines (which could transmit station into to the train)
FordFocus
15 Apr 2015
Bombardier DMU PIS works on GPS and door release. Frequently gets lost and is quite unreliable.
mbreckers
20 Jan 2015
LED displays are generally more readable from a distance, which is required if your sitting away from a display
Kite159
27 Jan 2014
West of Andover
The PIS on the 458/5s gets a mention when they are on a Hounslow Loop service
On departing London Waterloo, "this train is for London Waterloo, next station is Vauxhall", couldn't SWT fool the PIS into saying that the train is for Hounslow or another station on the loop (before someone gets on it at Vauxhall thinking "it's taking a rather long time to get to Waterloo")
380gk
19 Oct 2014
In theory, guards on scotrail services should not be operating the PIS at all, as they're not trained on it.
507 001
3 Dec 2008
Huyton
I've not normally noticed a problem (save for the drop case) but last week when I was on one, having diverged from what some of the other forumites were up to, I was going from Greenfaulds to Springburn. All was fine until the junction before Springburn "We are now approaching Springburn........." followed a few seconds later with "We are now approaching Barnhill......" followed again by "We are now approaching Bellgrove". On arrival at Springburn we got "This is Bellgrove" and just after I left the train I heard "We are now approaching Glasgow Queen Street..............."
Yes they do. I believe it only works on Manchester to Liverpool runs. Anywhere else and it hasn't been programmed
Can't say I've ever heard it used to be honest! I've been using them for 15 years!
As for Northern 319s, is;
"We are now approaching xxxx. If you are leaving the train at xxxx please remember to take all of your personal belongings and hand Luggage with you. Please mind the gap between the train and the platform" really necessary before every. Bloody. Station????
Goldfish62
14 Feb 2010
We have similar sh*te on the 458/5s. Every damn station. The 458/0s had "The door buttons are now activated. This is..." Why couldn't they have just removed that and then left it alone? Instead it's now worse.
Juniper Driver
17 Jul 2007
SWR Metals
Have you seen how confused the good folk get with the door buttons? ;)
tsr
15 Nov 2011
Between the parallel lines
For some reason it also seems that the system on 171s sometimes dislikes local door operation in general, meaning that the carriage in which the local door was last used then has outdated PIS info until the next stop... oh, and not to mention forgetting half the preset auto-announcements which are quite useful for short platforms and the like.
hassaanhc
5 Jan 2014
Southall
"This is Hounslow please remember to take all your personal items with you when you leave the train" <D
The best bit however is this when approaching Waterloo:
"This train is for London Waterloo. Calling at , and London Waterloo" :lol: :lol:
SpacePhoenix
18 Mar 2014
Could they not have just installed a nice load "door unlocked bleeper", like what the Desiros have?
TEW
16 May 2008
The 458/0 door opening sounds are already pretty loud and piercing. You're far more likely to hear those than the pretty rubbish, and often too quiet PA.
Peter Sarf
Croydon
Does all stock after 2020 have to have the loud "door unlocked" bleepers?
Well they use a loud sound on the buses I use. Actually not sure if it is to tell you the doors are opening, opened or about to close. All I know is I get off as quick as I can as my head is right close to whatever anti-personnel device it is they use to emit the sound. I always sit as far as I can from the doors (upstairs on a bus) so that I have more chance of relaxing.
Oh so familiar. Southern trot that out on approach to Victoria (maybe other stations). So its probably a hangover from Southern/Thameslink.
507 001
3 Dec 2008
Huyton
I could understand before a terminus. But every station? Every single one????
(Can you tell it annoys me?)
Crossover
4 Jun 2009
And the fact that half the train has already alighted by the time it says the door controls are now active :P
