Oyster validators at Elstree & Borehamwood.
londonbridge
30 Jun 2010
Can someone tell me where the validators are at Elstree please? If I combine PAYG with a return from Elstree-St Albans is there time to jump off, touch out (in on return journey) and get back on the same train or not?
westcoaster
4 Dec 2006
DTOS A or B
No chance of the same train home, from what I've seen there are none on the island platform so must be on the gate line.
revenueadvice
17 Dec 2012
On the gateline unless the station building is closed in which case there is a side gate with oyster validators just outside.
Heading North then. I don't think so. I can't think of any reason why there would be a validator on Platform 2 (other than to allow people to do what you want to do, of course!).
When I went there, there was a validator at the side exit by platform 1, so if you said you were heading South, then it would be possible (if you got the right door position - it sounds like the door position may vary depending on whether or not the ticket office is open though).
But heading North, I think there's no chance.
Station plan: http://www.nationalrail.co.uk/SME/html/NRE_ELS/plan.html
londonbridge
30 Jun 2010
Thanks for the responses. PAYG (or a paper travelcard) coupled with a return from Elstree-St Albans is the easiest option as I'll be departing from Carshalton but returning to East Croydon. Paper travelcard means I don't need to get off en route to swipe in/out of course. Actually is there a boundary zone 6-St albans ticket and would that be cheaper than a return from Elstree?
Also once at St Albans how much time should I allow to transfer between the station and the Alban Arena?
John Webb
5 Jun 2010
St Albans
There are numerous buses between the station and St Peters Street, which the Alban Arena is just off from. If you want to walk then it's approximately a mile with some downhill and uphill work. Turn left out of the station building on Platform 1 and left again into Hatfield Road. Cross over the railway and carry on past Beaconsfield Road and Upper Lattimore Road. Cross over Upper Marlborough Road and turn down it and immediately right into Bricket Road. Bear right and immediately left alongside the two-storey carpark. This brings you to the Arena - turn right and walk up the side of the building then left to get to the front entrance. If you get directed along Victoria Street you will find this is slightly longer and more hilly!
LexyBoy
23 Jan 2009
North of the rivers
Most Thameslink services between St Albans and East Croydon run fast between St Albans and St Pancras, so you would be better off with the paper Travelcard + BZ6-St Albans option.
