Oyster question (King's Cross)
racklam
27 Apr 2014
While checking a single Oyster fare (St Margarets (London) to King's Cross) I entered King's Cross NR as opposed to the LU station. Apparently there are no fares available between St Margarets and King's Cross NR.
Out of interest, what would I be charged if I took the train from St Margarets to Vauxhall, then tube to Finsbury Park and train to King's Cross NR?
GW43125
8 Dec 2014
I don't think that would be a valid route as you double back.
Hadders
27 Apr 2011
This is strange. Although not necessarily the fastest route it's perfectly reasonable to travel St Margarets-Tottenham Hale-Finsbury Park-Kings Cross.
As long as you stay within the maximum permitted journey time and didn't exit at Vauxhall you'd be charged the St Margarets - Kings Cross fare but as we don't know what that is I don't know what you'd be charged.
There's no problem doing this with Oyster or Contactless as long as you stay within the maximum journey time and have sufficient credit for the journey you make. The system works out the appropriate fare depending on the journey you've made. The routeing guide doesn't apply if you stay within the zones.
MikeWh
15 Jun 2010
Crayford
Confusion alert: St Margaret's (London) is between Twickenham and Richmond. St Margaret's (Herts) is between Hertford East and Broxbourne.
You would almost certainly be charged the same as the default route to Kings Cross St Pancras LU. This is one of those illogical routes (according to the fare setters). My experience is that it will be charged at the NR1-T rate for the zones used (1-4).
Hadders
27 Apr 2011
:oops: Oops my bad! There aren't any fares from St Margaret's (Herts) to Kings Cross Rail either.
John @ home
1 Mar 2008
Both brfares.com and Avantix Traveller NFM26 show fares when given origin ST MARGARETS HTS and destination LONDON KINGS X. The adult single fares using Oyster are: Similarly, both sources show fares when given origin ST MARGARETS LDN and destination LONDON KINGS X. The adult single fares using Oyster are:
Hadders
27 Apr 2011
The Single Fare Finder on TfL's website shows 'No fares found, please try again'.
MikeWh
15 Jun 2010
Crayford
Interesting. I guess they believe that once you've joined the Victoria line at Tottenham Hale/Seven Sisters you'll remain with it all the way to Kings Cross if that is your destination. In normal circumstances I'd have to say I'd agree with that belief.
Equally interesting. I think there's a degree of clustering going on here. The fares described are those to the usual London Terminal (Liv Str/Waterloo). In view of the fact that both alternatives being discussed here would involve mixed mode travel I would expect them to be more expensive.
MikeWh
15 Jun 2010
Crayford
Indeed St Margarets (Herts) to Moorgate or Old Street are indeed £9.90/£7.80.
racklam
27 Apr 2014
I agree with the fare setters, it would be fairly illogical!
What do you mean by the NR1-T rate?
MikeWh
15 Jun 2010
Crayford
That might be something that MikeWh has devised for his website, not sure if it's official: http://www.oyster-rail.org.uk/fares-guide/guide-to-fare-scales/
Yes, sorry. NR1 is for those TOCs which adopted Oyster at the last minute in 2010 (mostly SE, SWT, SN, TL) but not the SE extensions to Dartford/Swanley which are in zone 8 and I call NR2. The -T signifies that the journey mixes NR with either LU or DLR.
