One for the tech guys?
RSDonovan
25 Oct 2019
Hove
I’m not sure if this is the correct forum, please advise if not and I’ll move it.
i want a plain text file containing all the three letter station abbreviation codes eg. STP EUS HOV ECR etc. as plain text I have seen many links that lead to spreadsheets etc. but I just need a text file, either undelimited eg STPEUSHOVECR or delimited eg STP,EUS,HOV,ECR or similar. I can deal with line feeds but only if they are consistent.
I hope someone will be able to help me!
Thanks in advance
The_Train
2 Jun 2018
I'm no expert but is it not just possible to save one of the spreadsheets you've been linked to as a .txt file?
RSDonovan
25 Oct 2019
Hove
Unfortunately not. There are loads of embedded control characters that would be almost impossible to unscramble! Thanks anyway
ComUtoR
13 Dec 2013
Would a csv file help ?
I have the original CSV and converted it to tab delimited but its ugly as sin. The forum doesnt allow .csv uploads. Just uploaded a slightly better version. Just a few tabs out of alignment.
  • station_codes-_07-12-2020_.txt
RSDonovan
25 Oct 2019
Hove
Hi! In what way is it “ugly as sin”? I’m trying to avoid too much processing. What if you just saved it as a .txt file?
SargeNpton
19 Nov 2018
Can you not just open up one of the spreadsheets, highlight the column that contains the CRS codes, then copy & paste that into a new text file?
RSDonovan
25 Oct 2019
Hove
I now see that it looks like a saved spreadsheet file. It still contains all the spreadsheet control characteristics which I am trying to avoid. Thanks anyway
I don’t have a spreadsheet program!
pelli
15 Sep 2016
You can use Google Sheets online if you don't want to install a free spreadsheet program such as LibreOffice Calc.
For example, National Rail Enquiries publishes their list here: https://www.nationalrail.co.uk/stations_destinations/48541.aspx . You can download the CSV file and open it in Google Sheets online, and extract the data you want. Also, in fact, you can just select and copy the entire table on the web page and paste into Google Sheets, then copy out the second column only into your text file (which is what I've done to get the attached file).
Edit: The web page is dated 5 Aug 2020 while the CSV file is dated 7 Dec 2020, but the only difference between the two is that the CSV file contains Okehampton twice.
  • stationcodes.txt
ComUtoR
13 Dec 2013
Only shows as a standard txt file for me. This was opened in notepad. What program are you opening it with ?
py_megapixel
5 Nov 2018
Northern England
I've just copied and pasted the list from the National Rail website and run it through a quick Python script that removes any control characters and then rewrites all the codes into a text file. There should not be any line breaks in this (except perhaps at the end), just the codes and delimiters. Is this suitable for your use?
  • crs_codes.txt
37078xotTE
29 Feb 2012
Thanks in advance
  • Station codes (all).xlsx
RSDonovan
25 Oct 2019
Hove
That’s brilliant thanks a lot
RailAleFan
2 Jul 2014
Midlands
Having seen the date I thought i'd double check and the National Rail Enquiries CSV is missing a couple of the more recent openings...
Bow Street (BOW)
Kintore (KTR)
Soham (SOJ)
RSDonovan
25 Oct 2019
Hove
That is absolutely brilliant thanks a million
