Oiling Locos
JoshW1992
1 May 2006
Warwickshire
Just a bit of advice guys...
I was given a tip to oil my 00 gauge locos with sunflower oil, as one of them was very squeeky. Trouble was... when I went to test run it, it started smoking, and I took it off about 5 seconds before it caught fire. The loco now no longer runs... so please, never oil your locos with sunflower oil! :(
4 Nov 2005
Parkstone
No, Never use sun flower oil thats the worst thing possbile to use!!
I brought something called Hob-E Lube, Lite oil. they do different grades and the light oil was the best. Works wonders
JoshW1992
1 May 2006
Warwickshire
Ah sweet, maybe next time (if I dare again...) I will use that. I still cant believe I used sunflower oil :(
LucaZone
24 Feb 2006
West End, Surrey
Some Dapol locos are recommend to be oiled before every time you use them.
Most locomotives come with a gummy oil that merely needs the loco run for about 30mins in each direction at a constant speed to gel it up and prepare for use. This normally only needs to be done the firts time you run the loco after purchase.
JoshW1992
1 May 2006
Warwickshire
My loco was a very old one made by 'Mainline.' I bought it second hand, so sadly, it didnt come with anything like that.
