It can't be all barriers. I buy a return from Filton Abbey Wood to Stapleton Road as it's cheaper than one to Temple Meads and the OUT portion works in the barriers both ways.
I am pretty sure they have no legal right to prevent you going past. I am pretty sure they can't lay a finger on you either, but perhaps a legal expert can confirm this?
There's no way I am missing a railtour because of some jobsworth anyway so the issue of compensation for missing it would not rise as far as I'm concerned.
What law is that then?
Of course you can go through "without a valid ticket" if there's a railtour you intend to get. :roll:
By the time they arrived, I'd be on the tour, and the tour organisers could simply tell them that their services are not needed :roll: They'd probably then tell NXEC off for wasting police time.
I note also that many of the "to be gated" stations in the NXEC list at the start of this thread are on the traditional "granny routes" of Cross Country services from the North East to the South and south West.
You can break at Brighton too - I know you can get through the gates there with an Eastbourne to Wyvelsfield ticket, which doesn't even have to go via Brighton. Does it depend on the station facilities? Both BTN and BRI (it should be BTM!) have station facilities outside the barriers (WH Smith etc), but LTN just has the ticket office and a bus stop.
I have also been told although not experienced it myself yet that New Street have regular spot ticket checks on the platform area itself as well as at the barrier, and will issue penalty fares if necessary!
Most of the stations in the former centro area have penalty fare notices and the staff who work in this station will tell you that it is and that you will require a ticket to either leave or join the station area.
And yes, if you are on or about the platform area you should be in possesion of a ticket regardless of the company you are travelling with.
At the end of the day, you have an obligation to purchase a ticket to travel at the earliest opertunity.
