WesternLancer
- Joined
- 12 Apr 2019
- Messages
- 15,351
I do not understand what the word 'coach' is here in your post? I realise the English is probably not your first language.Thank you for your reply. I am going to take printout because my writing will not good.i attached the draft coach with order. So can you check above whether the order is correct . So one is printout and another sheet which I received right? 2 sheets going to post. Please reply ASAP then only I take printout and send the letter soon.thank you.
But
Basically yes, do this.
It is good if you can print it and include it in the envelope with their original letter that you are sending back if you do not have good hand writing, Sign it with a pen under what you write.
Send them BOTH your signed print out, and the letter they sent you. Send all this in the same envelope as I explained above. make sure every separate bit of paper (on each side of the paper) has your reference number, and name, and address written on it
You say you are a student in your original post. If any of this is unclear about how to send this back to them I suggest you go to your college or university, (probably the student union), and ask someone to check all this and that you have followed the instructions correctly. Someone there will be able to help check it for you. They won't care about what you did to get into this situation so you can ask them for help.
