Northern Unit Refurbishments and depot allocations.
northwichcat
23 Jan 2009
Northwich
Best of waiting til the end of the year when they go off lease.
While I think the lease end date shown in the franchise agreement is 1/1/2019, there's also a mention that Northern cannot return off-lease units until replacement units are in unrestricted revenue earning service, so they need at least 17 x 331s in revenue earning service before the 323s are returned regardless of the date given.
northwichcat
23 Jan 2009
Northwich
I'm sure someone must have pointed this out by now - apologies if so as I haven't read the full thread.
What happens when a battery powered unit arrives at a non-wired terminus, lets say Windermere. Inbound service delayed, so the turnaround time is down to 5 minutes.
Obviously, this isn't long enough to do a substantial amount of battery charging. Does the service get delayed until the unit is charged? I can see that being a PR disaster.
I would hope if Porterbrook are using Windermere as the example route for their hybrid 350s that they would not use anywhere near 100% of the battery power on a run between Oxenholme and Windermere so there aren't delays due to recharging or the risk of a train being stranded because of a signalling problem on the branch.
Class37.4
8 Oct 2018
Battery power for Windermere I think we will wait a see on that. BBC news has just been on about hydrogen trains showing the Alstom unit in Germany and then Grayling was on expecting to see hydrogen trains in the UK fairly soon.
61653 HTAFC
18 Dec 2012
I wouldn't put too much stock in that, to be honest...
jonesy3001
13 Jul 2009
Otley, West Yorkshire
think 507021 might have to add the 323s to the list if they're hanging around for a bit longer but when they go for the C6 exams will they be going back in the new colours or plain white?
Chester1
25 Aug 2014
Battery powered 230s will have a range of 40 miles. Oxenholme to Windermere and back is much shorter than that so if 350s had the same range and used battery power for Airport services range shouldn't be an issue. Maybe Barrow services would require a battery with a range of 80 miles so only half a charge at Barrow would be neccessary? Clearly battery power adds a slight extra risk to time keeping but it should not be a significant issue if the timetable is not insanely tight.
I am not a 323 fan boy but I can see that retaining them for longer provides options for some 6 car services, making full use of Salford Crescent and Oxford Road platform length limits.
507021
19 Feb 2015
Chester
It hasn't been confirmed they're staying long term, so I'll hold off adding them for now.
Greybeard33
18 Feb 2012
Greater Manchester
The franchise requirement is for only four services daily from Windermere to Manchester, but an hourly service to Oxenholme. So each diagram has to include multiple workings from Windermere to Oxenholme and back, before the return working to Manchester. The round trip to Oxenholme takes nearly an hour, leaving only a few minutes under the wires at Oxenholme for recharging. A battery range of much more than 40 miles would be needed to work such a diagram. Unless two units were used alternately, with one recharging in a siding at Oxenholme while the other worked to Windermere and back - complicated and inefficient.
I doubt that Porterbrook is planning for battery recharging at the country end of an unelectrified branch. That would require substantial infrastructure investment for an "extension lead" from the electrified main line to deliver enough power. The local mains power distribution network would typically not have sufficient capacity.
The Porterbrook press release, https://www.porterbrook.co.uk/news/...unces-batteryflex-in-green-great-britain-week only mentions the Lakes line specifically, not the Furness line:
Porterbrook said:
With the addition of the latest battery technology, Porterbrook is confident that the 350/2 BatteryFLEX would be able to match, or outperform, diesel trains on existing non-electrified routes, particularly in key corridors across the North of England.
Mary Grant, CEO of Porterbrook, said:
“We believe this green technology could have a huge impact across the country, delivering cleaner travel on our rail network, including on picturesque routes like the Lakes Line.”
Porterbrook has modelled energy and power demands for routes such as the Windermere branch, where a BatteryFLEX version of the Class 350/2 fleet would eliminate diesel use on non-electrified lines, whilst maintaining the ability of these highly reliable trains to operate using overhead electrical wires.
1179_Clee2
4 Aug 2016
North East Lincolnshire
Mollman
21 Sep 2016
Preston
The LIAR magazine publishing rubbish AGAIN.
Northern have 100 repainted trains NOT 100 refurbished trains, see the Northern refurbished list by @507021.
(for example) RAIL claims 32 refurbished Class 319s, some of them still have First Capitol Connect interiors
I did wonder considering that only 1x158 has been fully refurbished so far.
deltic08
26 Aug 2013
North
All this uncertainty and p*****g about when electrification for the branch was straightforward. Screw Grayling. Parliament should just reverse his decision and electrify.
Class37.4
8 Oct 2018
Well yes lets have more NR electrification ridiculously over budget and years late.
Mollman
21 Sep 2016
Preston
It is interesting to see how quickly West Midlands Rail are applying the interim 'Tango' livery to stock whilst Northern haven't bothered even applying TOC names to non-refurbished units.
northwichcat
23 Jan 2009
Northwich
Apparently Arriva don't want to put their brand on non-refurbished units because they think they are a disgrace.
43096
23 Nov 2015
They’ve got that the wrong way round then! It would be quite hard to come up with something more cheap and nasty than the old Northern, but Arriva have, astonishingly, done just that.
Class37.4
8 Oct 2018
Well they are however of course many don’t think the refurbed trains are that great although a lot seems to revolve around the 3+2 seating on the 150’s but it seems like right choice to me the problem being they are currently working services they shoudnt be in the long term, and the choice of a flat fabric.
geml90
29 May 2018
On a refurbished 156 to/from Darlington today (normally a Pacer) the panels and trim didn't look great as gaps have opened up between the newly painted bits. The PIS / announcements worked in one direction only. It was warm and comfortable enough, even though a Pacer feels like it has a bit more leg room? The Northern site mentions LED lighting, but they look like normal tubes?
I think the 156s used by Greater Anglia have a better finish and are more airy (possibly shorter seats?), even though their refurbishment was a few years ago?
