Thank you. Second try. More scenario this time.
I am re-appealing as I do not believe my case has been considered properly on the appeals I have made so far.
I will again reinstate my 16 year old sons scenario. He was returning home from Rochdale College on 30th January 2025. On his return journey home to Walsden, there were two trains departing from the same platform at Rochdale Station - the 16:13 train from Rochdale to Leeds and the 16:17 train from Rochdale to Blackburn. Both these trains were delayed, which meant the trains departing times were almost identical. He inadvertently boarded the incorrect train due to the delay to the initial train and was, as a result, overcarried. The train he boarded passes though Walsden station but does not stop there. The only and first stop on this train was Todmorden, so he had no opportunity to get off this train before Walsden and board the correct train. He left the train at Todmorden where he was stopped by a RPO on the exit to the platform and issued a PF. He lives in Walsden and Walsden Station is within walking distance of our house. Todmorden Station is 2 1/2 miles away. He would not have intentionally boarded a train that only stops at Todmorden.
My points of appeal are as follows:
1. The delays on these trains, along with the fact they left from the same platform within 2 minutes of each other directly caused this issue.
2. My second appeal was rejected and stated:
"Of course, the exception would be where services were severely disrupted or where the train had failed to stop at the relevant advertised destination station on its line of route (given that both of these scenarios would be outside the passenger's control).I note that you mentioned that the train that your son was meant to board was running 2 minutes late and that both trains left from the same platform, this mitigation has been taken into consideration, and there is no evidence to support the discretion guidelines having been breached by the authorised collector at the time of issue"
I would ask the person handling this appeal consider my sons age here as well as the wider circumstances I've already described and show some discretion themselves, rather than consider whether the RPO should have acted differently at the time (given they did not have at the time, the extra context I've provided).
3. I do not believe the PF was issued in accordance of the regulations.
Regulation 9(2A) states ""the full single fare applicable” is the full single fare for the journey in question from the boarding station to the station that the penalty fare authorises the person to travel to under regulation 5(5A)"". 9(3A) also states ""the boarding station" means the station at which the person boarded the train"".
The boarding station was Rochdale. The PF was issued from Walsden to Todmorden and so was not issued in accordance with these regulations.
Should I also quote these regulations in point 3?
16(3A) "The grounds on which an appeal under this regulation may be made are that — the penalty fare was not charged in accordance with the requirements of these Regulations"
16(3D) states "there are compelling reasons why, in the particular circumstances of the case, the appellant should not be liable to pay the penalty fare".
18(2B) states "An appeal under this regulation must be made - on one or more of the grounds specified in regulation 16(3)". Finally, 18(4D) states "(4) If the relevant Final Appeal Panel, after considering an appeal under this regulation, concludes that any ground specified in regulation 16(3) applies, it must, subject to paragraph (7), allow the appeal".
