North Downs Line - making request stops
hkstudent
11 Nov 2018
SE London
When looking at the calling pattern of North Downs Line, it often finding many stations like Gomshall are only having 1 train per 2 hour.
It appears to be too infrequent for a line that is served by 2 trains per hour. Would it be better off to make those infrequent stops be request stops and be better demand matching?
Looking at the timetable, each stop costs about 2min. Making them request stops would save 1/2min per stop per GB timetabling conventions, so you would barely be able to squeeze one extra stop in, not 2. (I am assuming that Shalford, Deepdale and Reigate would not be request stops.)
I leave it to others with much more recent local knowledge to comment on potential offpeak demand.
simonw
7 Dec 2009
I think the op is suggesting allowing a customer to request a train, not currently scheduled to stop, to stop in addition to the 1 stop every two hours, not to make them all request stops.
30907
In which case you need to add 1.5min to each journey to allow for the potential stop, and that's impossible with the constraints on the timetable.
devon_belle
21 Jul 2022
I would propose instead to increase the frequency of calls to those stations. They have comparable usage to the Dorking-Horsham stations which benefit from a 1tph (albeit 5.5 days per week) electrostar service to/from London Victoria.
I'm not sure why those stations are 1tp2h, but there usually seem to be people getting on/off at the small stations between Dorking Deepdene and Shalford. I can't speak for Betchworth because I rarely get the train in that direction. Dorking West is an interesting one because it is the accessible alternative to Deepdene, although the pedestrian journey between the two is not the shortest or flattest. Additionally, tickets are often sold to 'Dorking Stations' so actual usage figures are hard to decipher.
I guess that when new trains with better acceleration come in every station will get at least 1tph, but I'm not sure if signalling changes would also be needed to achieve that and the coveted third train per hour. Gomshall should be the focus of any increase in service frequency in my view, as it is the busiest of the shacks and has lots of nature/walking appeal like Boxhill and Westhumble.
Northampton
1.5 min is a good approximation, although technically it can be more or slightly less depending on the SRTs.
Request stops are timed as a zero-dwell stop (also known as a 'dot stop') with an additional 30 seconds runtime after the request stop to allow for if the train needs to stop. This means that compared to a booked stop, you are only saving the Dwell time minus 30 seconds. If the dwell time at the station would be 30 seconds, then there is no timetable benefit to it being a request stop, only a potential performance benefit (offset by the potential to run early and be held at signals later).
Recessio
4 Aug 2019
Very anecdotal experience suggests a fair chunk of the traffic at Dorking Deepdene is school traffic. It would be interesting to know if the usage patterns at the other stations is constant or if it spikes throughout the day - would going from 1tp2h to 1tph be justified throughout the day? Or would it be better to have more stopping services in the morning and evening peaks but keep 1tp2h in the off peak.
Regardless I've never been a huge fan of request stops. You effectively have to timetable a stopping service just in case all the stations get stopped at anyway. So either just have a stop scheduled or don't.
devon_belle
21 Jul 2022
In mine it is a decent amount of airport traffic and a lot of commuting/leisure between Guildford-Dorking-Redhill. I've rarely found the trains to be overloaded or empty, having travelled at quite a few times of day for various reasons.
I believe they are already 1tph in the peaks. Certainly in the morning.
Agree.
izvor
11 Jun 2014
on the SER
I do wonder if some lines with a series of lightly-used stations (not necessarily the NDL) should make them request in the evenings, e.g. after 2000 or 2100. If it were considered unlikely that stops would be required at more than, say, 2 out of 5 then it might enable more stations to be served, as well as eliminating unnecessary stops.
It is a legacy of the stopping service having been scaled back in the 1980s. For a long time, essentially the equivalent of one unit was used to provide the off-peak stopping service east of Guildford.
It is a really difficult position to increase the services at Chilworth, Gomshall, Dorking West and Betchworth. They simply can't justify their own stopping service if taken out of the Gatwick trains.
The service is currently the best compromise available with seven units. 2tph at Wokingham, Blackwater, North Camp, Guildford, Dorking Deepdene, Reigate and Redhill, 1tph at Crowthorne, Sandhurst, Farnborough North, Ash and Shalford, 1tp2h at Chilworth, Gomshall, Dorking West and Betchworth. Even with better acceleration, is the priority more stops at the local stations or better journey times to Gatwick.
If it was desired to get 1tph at the four stations, I reckon that it would probably be desirable to have 3tph north of Guildford only, with then the local stops across the two trains that run through to Gatwick. However, that could well need nine units which is a considerable uplift in operational costs relative to now.
Farigiraf
23 Jul 2023
Bridge on the River Cam
They're a good idea for lines with lots of intermediate small stations which are skipped most of the time but do still provide an important benefit to the places they serve. It saves a bit of energy each time you skip one so it pays off after enough time, alternatively you could install some buttons to improve the passenger experience and reap the benefits through ridership growth and passenger satisfaction instead. On these kinds of lines speed is not the biggest priority, it's the train turning up at all, so the timetable padding required to accommodate these potential stops is not a huge inconvenience.
The issue is that we closed nearly all of these in the last hundred years.
I reckon that even without direct services to London, the North Downs line is useful enough that every station on the line can do with 1tph all day. If it doesn't ruin the timetable then yes it may be worth trialling a doubling of services only at peak times, but the benefit of having a predictable all-day (reliable) train service is that it starts being used by a lot more people for more reasons than just commuting, making it a useful transport hub for the town/village it serves, not just a peak-time traffic bypass combined with an off-peak safety net service for those who don't drive.
I reckon most would still park&ride at a mainline station for accessing London, but Reading, Guildford and Gatwick Airport still make for a great trio of connection options, as you can access many parts of the country (and other countries) from these destinations. If it would significantly increase usage then I may be wrong, but I think adding the proposed third hourly train on the line (with a faster stopping pattern) would be overall less useful compared to accepting that it's a regional connector (not an airport express) and giving most stations on the line a decent service. May cost end-to-end passengers (who are usually making less time sensitive trips) 10-20 mins but it saves other passengers 1-2 hours. It's quite a successful line already, all things considered (slow, unelectrified, non-London, low priority), so it deserves some investment anyway in recognition of that.
Northampton
As mentioned in post #6, there is minimal timetable benefit to making stops request stops.
izvor
11 Jun 2014
on the SER
I'd argue that, of the 4 stations mentioned above, only Gomshall might justify increasing to 1tph all day. But, M-F, there's only a few hours when it's less than that anyway.
It's Gatwick that has mainly made the line successful, plus development in the Blackwater Valley. End-to-end journey times are important for this market, and the perception must be that this is slow enough as it is.
All valid points. Plus the level crossing issue at Reigate, a problem arising with any increase to 3tph; and the fact that GWR struggle to run the existing service as it is. All mentioned in earlier threads on this line.
I saw this, and agree. My idea was more to make better use of available time.
devon_belle
21 Jul 2022
My guess is that airport passengers would prefer the timetable to be more predictable (and reliable), rather than shaving off a few minutes. After all, even with fancy new trains it's still going to be a sluggish journey from Guildford let alone beyond. The line serves a very useful purpose for leisure and commuting traffic, which I think is easy to overlook. That market (myself included) probably care more about how fast and frequent the service is than airport passengers, especially now that even short haul air travel takes up most of a day. If they ran overnight trains for the very early morning and late night budget flights that could be a different story, but it would be unnecessary to stop at Gomshall etc for that purpose anyway!
If it could be achieved with the constraints at Redhill and Guildford, 1tph semi-fast (i.e. no shacks) and 1tph all stops would be a very useful service in my view. 3 tph east of Guildford would be nice but I would prioritise 4 or 5 car trains first and regularise the timetable.
Sorry, realised I started rambling a bit there!
Farigiraf
23 Jul 2023
GWR are actually trialling night services at the moment for exactly this reason - link to the thread
Why? It may not be that busy but for low frequency overnight services it makes sense to serve as many places as possible to maximise the number of places served by an overnight connection. GWR night time Reading services stop at nearly all shacks partly for this reason, same with Thameslink's Bedford-Three Bridges.
Saving a few minutes at the dead of night is handy but won't make or break most travel plans. On the other hand, a night service on e.g. the North Downs line stopping at Gomshall, Dorking West etc, allowing for a transport option for nights out (with drinks), early flights, late evening events or even morning shifts at Gatwick allows for certain journeys to be feasible which otherwise wouldn't be if the train skipped these stops a few minutes. It likely only positively affects a handful of people per year but overall it's worth the small time and energy cost of a station stop.
Northampton
Whether it is worth it or not depends on how many people are being impacted because sometimes 5 minutes can make or break the overnight maintenance period being able to get the job done.
mickey
11 Mar 2010
Nowhere on this line should have less than 1tph. The blindingly obvious way to achieve it would be to fill in the electrification (Reigate-Guildford and Ash-Wokingham) and have faster, better-accelerating EMUs, but sadly third rail extensions are effectively banned even where they’re very sensible.
If Gatwick expansion goes ahead then I’d expect signalling upgrades to happen in preparation for it, which will allow some improvements and particularly better resilience. If we really must have DMUs there, I’ve often thought new 195s would work reasonably well. The option of 6-car operation with SDO would also be helpful.
DelW
15 Jan 2015
I think that most of the local off-peak traffic (i.e. not connecting into other trains), is better catered for by the hourly no32 bus. That runs via the A248 and A25 between Guildford, Dorking, Reigate and Redhill serving all the intermediate villages that the NDL serves and others that it doesn't (e.g. Shere, Westcott and Brockham). The bus stops are better placed both in the villages and in Dorking, whose stations are well away from the High Street shopping area.
That was more or less the timetable until about three years ago. Unfortunately, for the stopper to fit into the regular pattern at Guildford and Reading, meant it had to turn back at Redhill. Connections onward to Gatwick weren't very good, so Gatwick to/from Guildford and Reading was barely better than 1tph - it was usually better to wait for the next through train.
The current 2tph regular pattern to Gatwick, half hourly at the ends and around 25/35 minute intervals in the middle, seems to have increased ridership significantly based on my usage of the line. Even the small villages get roughly an hourly service in the peaks, and I doubt whether extra offpeak stops would add much more traffic. And obviously GWR is very short of DMUs anyway, so finding extra units to enhance the timetable is unlikely.
Recessio
4 Aug 2019
Incredibly selfish criterion here, but something that would be great would for a future timetable would be that if, in both directions, going from NDL via Gatwick to Eastbourne didn't result in a 25-29 minutes wait each time at Gatwick :lol:
