North Country Rover: After 0900...
Amaranthe
13 Aug 2020
Durham
I'm trying to plan out a North Country Rover trip and the terms say it is valid: By any train after 09:00 Monday to Friday.
So am I right in thinking I couldn't use it on the 09:00 Durham - York?
toffeedanish
13 Dec 2010
I'm not sure why you would think that.
jfollows
26 Feb 2011
Wilmslow
North Country Rover 4 days in 8?
Not valid on trains timed to depart after 04:29 and before 09:00.
So valid on a 09:00 departure.
Restriction code B3
Amaranthe
13 Aug 2020
Durham
Restriction code B3
You will be fine at 09:00 as the restriction B3 is before 09:00: https://www.brfares.com/!roverdetail?nlc=I744&rvr=NC8
Thanks both of you. I wonder why the National Rail site says By any train after 09:00 Monday to Friday then.
Mcr Warrior
8 Jan 2009
Which site?
Because https://www.nationalrail.co.uk/ticket-types/validity/b3/ says the same as I quoted above from BRFares.
The National Rail site linked below, perhaps? Does seem contradictory!
Extract...
National Rail said:
Validity - Terms & Conditions
By any train Saturday, Sunday and Bank Holidays.
Restriction does not apply to customer travelling from any station between Barrow in Furness and Carlisle or vice versa on direct services only.
jfollows
26 Feb 2011
Wilmslow
Thanks.
Not good, is it?
If the ticket you buy had B3 as its validity code, then the site you quote is just wrong. I suspect it will, and I doubt you’ll have a problem with the train you mention.
The exile
31 Mar 2010
Somerset
Because someone in a marketing department thinks that “not before” means the same as “after” but is more confusing. Lots of places get into the same muddle with age-related restrictions. The same “simplification” has introduced confusion about late-running trains by removing “timed to depart”. Your rover is, for example, not valid on the 08.45 even if it’s an hour late - but it is valid on the 09.01 even if it leaves 2 minutes early, but that’s not what the marketing implies.
jfollows
26 Feb 2011
Wilmslow
http://www.railrover.org/pages/north-country-rover.html also states
This ticket has restriction code B3
although I'm sure this was not really in doubt
