Liverpool 507
777018 started service forming 2G60 06:13 Kirkby to Liverpool Central.Thanks for the info,
Don't suppose you know what service it worked?
Thanks for the info, added it to OP.777018 started service forming 2G60 06:13 Kirkby to Liverpool Central.
Just to give a date, 196004 entered service 23/2196004, 197017, and 231005 all now appear to be in service.
119 entered service on 14/2. 05:45 Shenfield to Braintree/07:00 Braintree to Liv St.720119 on 1n20 1118 LivSt-Clacton 15-Feb. Not seen listed previously working.
121 entered service on 17/2. 15:56 Ingatestone to Colchester.I'm currently sitting on 720 121 at Liverpool Street; paired with 720 112 for the 15.14 to Southend Victoria.
Can't see it listed up thread?
Smells completely fresh and new, as it should.
Did you miss my post about the class 230s on post #45Thanks to all for information posted.
OP updated, Added into service are....
196005/ 007
231011*Info required on first service worked.
720123 / 125*Info required on first service worked.
777008.
Quite a bit of ???? as information/confirmations required, any help much appreciated!
OP Updated 06/04:
720124 GA 17/03/23*Info required on first service worked.
720126 GA 31/03/23 1F04 06:32 LST-CET
720518 GA 31/03/23 1N02 06:02 LST-TLS
I had 720 123 for haulage on Monday 3rd April, if that helps?Thanks to all for information posted.
196005/ 007
777008.
OP Updated 06/04:
(Source: https://www.westmidlandsrailway.co.uk/may23)West Midlands Railway said:Leamington Spa – Nuneaton via Coventry
Key changes for this route:
New Class 196 trains will be introduced to this line from May 2023 onwards
Many thanks, i'll add that date until I get any further info.I had 720 123 for haulage on Monday 3rd April, if that helps?
Many thanks,777001 and 777003 operated their first services on the Kirkby line today. 777008 failed and was replaced by 777001 at Sandhills on 2K32 1435 Liverpool Central - Kirkby. 777001 later failed at 1610 at Moorfields and was terminated at Sandhills, being replaced by 777003 at Kirkby on 2G62 1713 Kirkby to Liverpool Central.
Hi,Did you miss my post about the class 230s on post #45
Sorry, I didn’t realise you meant “brand new“. Entirely up to you, you created the threadHi,
Apologies, I did.
Primarily was just going to do new build trains but if everyones ok i'll add these as well.
