New toilets at London Bridge
Blindtraveler
28 Feb 2011
Hopefully once the busy summer season is over the existing facilities will be refurbished as they've coped with a lot in the 10 years they've been open
Benjwri
16 Jan 2022
We can hope, but having visited the new ones yesterday I would think it will cause issues. While not as bad as the women’s, the men’s can get fairly busy as it is. I went to visit yesterday and the men’s side is very small, at least half the size of the other toilets. I don’t think they would be able to anywhere near cope on their own.
Mikey C
11 Feb 2013
Agreed. The original men's toilets are pathetically small, with the hand dryers placed to get in the way of people entering! The new ones are much the same size or even smaller, so would similarly struggle if the original ones were closed for any period.
Backroom_boy
28 Dec 2019
Trend is to move hand driers above the sinks to stop the blockage near the entrance. St Pancras was marginally improved with this change. (On the men's side at least; the women's side os still horrific.)
Mikey C
11 Feb 2013
True, though if the toilets are large enough, then the hand dryers don't get in the way anyway, e.g. at Euston where they are at 90 degrees to the sinks.
jon81uk
17 Aug 2022
Harlow, Essex
...and all that does is cause a blockage around the sinks as half the sink space is now taken up by people drying their hands.
Is it better to have someone taking a full minute at a sink and dryer together rather than 20-30 secs at the sink and a further 30+ seconds at dryer.
My biggest peeve is public toilets that don't have enough dryers. There is no point having eight sinks if there is only one dryer. Eight sinks means eight dryers are needed, or a better design with 4-6 sinks and 4-6 dryers. It takes just as long, or longer to dry hands with an air dryer as it does to wash them.
Peter Mugridge
8 Apr 2010
Oakham
It takes a lot more than the stated 30 seconds to get hands fully dry*, and quite often because of the positioning of the drying blowers, it's not easy for anyone else to use the sinks on either side of anyone drying their hands.
Far better to have separate areas for each function.
*Especially if the blower is only producing cold air, which seems to be the case with half of them!!
jon81uk
17 Aug 2022
Harlow, Essex
The other major downside with seperate locations, particulay in travel circumstances is then needing to pick up bags with wet hands to move to the location of the dryer. Thats one main reason why airports and similar have switched to having the dryer above the sink, it keeps the luggage with the user.
Most modern dryers use high speed air to push the water off now rather than heat to actually evaporate the water. Dyson Airblade should work like a squeegee pushing the water down the fingers and off the end, so doesn't need heat.
Russel
30 Jun 2022
Lichfield
How on earth have Network Rail managed to burn through over £4 million on installing toilets?
J-2739
30 Jul 2016
  • NR-GN-CIV-200-04 Iss2 2021 Public Toilets.pdf
Benjwri
16 Jan 2022
I'm guessing there was quite a lot of fairly serious plumbing required given the previous use. They are also to be fair a lot more heavy duty than previous installations, so should last better. But I'm sure many consultant's fees were also involved.
Peter Mugridge
8 Apr 2010
Oakham
Are they Airblades hidden above the sinks? The stream of air doesn't feel that concentrated to me - and I've never managed to get my hands dry in a single cycle on an Airblade anyway...
Russel
30 Jun 2022
Lichfield
Would be interesting to see how a similar installation in a non-railway environment would compare, cost wise.
13 Jan 2024
Cambridge
But most people don't bother completely drying their hands as it takes too long. A lot of people (including me) only spend about 5-10 seconds at the hand dryer
Benjwri
16 Jan 2022
Significantly cheaper. But as I say they’ve used a lot more durable fittings, and I suspect a lot of money was spent creating the space to put them as I don’t believe it was existing, so a fair bit of structural work.
Blindtraveler
28 Feb 2011
In what way are the fittings etc. More durable? I've been quite shocked at the cheap quality of some of the post-pandemic network rail toilet refits, Edinburgh Waverly springs to mind, tiles coming off the wall and taps not working within a year of completion
Benjwri
16 Jan 2022
I would say it’s a more heavy duty installation, proper walls between cubicles, metal doors etc. you can see it in the photos above, and it’s been done surprisingly tastefully.
Obviously you can’t really judge the things you mention till time has passed, that’s more quality of install and non visible fittings.
talldave
24 Jan 2013
A large chunk of that will probably have gone on congestion zone & LEZ/ULEZ costs for contractors. All this pretending we care about air quality costs big money.
Russel
30 Jun 2022
Lichfield
Probably, yes... Lowering CO2 emissions etc are all current PR buzzwords, used while quietly hoping everyone forgets about the existence of Marylebone.
