New station set to open
northwichcat
23 Jan 2009
Northwich
The new Buckshaw Parkway railway station is set to be served by the Manchester Victoria to Blackpool North service from December 2011. Northern have put in an application to revise calling patterns to include a call at Buckshaw Parkway in the standard pattern between Chorley and Leyland.
WestCoast
19 Jun 2010
South Yorkshire
There was talk of TPE stopping there too, perhaps just in the peaks like they do with the other smaller halts on that line. I wonder if Northern are considering stopping the Hazel Grove to Preston service there.
northwichcat
23 Jan 2009
Northwich
They've not applied to for the December timetable change but if there's enough demand in the future then I imagine they'll look at it.
MidnightFlyer
16 May 2010
I thought that all services that served Horwich Parkway would call too (Hazel Grove-Preston / Manchester Victoria-Blackpool North / Manchester Airport-Blackpool North).
At my last visit, the footbridge was already intact and most of the platforms foundations were completed. The building was slightly advanced too.
Is this in the area that used to have a military-type establishment with its own station facilities?
Aye, it was an ammo factory in WW2, and was a staff halt until some time later.
northwichcat
23 Jan 2009
Northwich
The application is only for Manchester Victoria to Blackpool services plus the 06:53 Blackpool to Hazel Grove and the 17:04 Hazel Grove to Blackpool services to call there. TPE would need to put in their own application but Northern have certainly only applied to stop around half of their trains there.
VideozVideoz
23 Dec 2010
I know nowt about this new station nor the location. Could someone explain the purpose of it being built? Residential area?
premier01
17 Aug 2009
Yes it's effectively a new village-could be described as a commuter village-and yes there are other towns with larger populations with no station but guess it's because it's near an existing line and a lot of people living there will probably be commuting to Manchester-hope all Manchester trains don't stop there as it's already jammed on this line at peak times!
VideozVideoz
23 Dec 2010
I agree, the line is at near-full capacity especially after it joins the other line after salford crescent! THanks for the info btw
Lampshade
3 Sep 2009
South London
The Victoria - Blackpool North takes ages as it is, can't see it being very popular if the only service is an hourly all-stops 142.
WestCoast
19 Jun 2010
South Yorkshire
That service currently sees operation by 142/150/156/158/180 (talk about variety!).
I am sure TPE peak calls were mentioned at an earlier stage.
17 Apr 2011
From the opening all Northern services will call their in either direction. That's the Victorias and the Hazel Groves, throughout the day.
From December, TPE will have a roughly hourly stopping train (the xx10 from Preston) but only off-peak. The only peak time TPE trains are from Preston in the evening peak.
MidnightFlyer
16 May 2010
Passed this on Sunday. Platforms and footbridge 90-95% complete, just the very upper layer of tarmac needed doing. The building on the Manchester platform looks finished externally, inside was a bit bare.
It is almost identical to the new Bathgate, minus the OHLE.
Many sources (including BLS and TRUK) report that only the Blackpool-Victoria trains will call.
RAPC
30 May 2010
That is what I had originally heard as well, but the NRE site is showing the Hazel Grove services to be stopping there as well.
No sign of any TPE peak or even the mentioned off-peak calls for the dates in December that I just checked though.
Will be interesting to see what the passenger levels are like there when it opens and what level it displaces from Leyland and Chorley on either side of it.
driver9000
13 Jan 2008
Apparently the booking office hours are to be 06:30-00:20!
Platforms can take 7 coach trains, from what I have been told the Hazel Grove service will call at Buckshaw Parkway along with the Blackpool N-Victoria services. The running time between Leyland and Chorley has accounted for Buckshaw since 2008.
Toots
24 Oct 2009
Yes Paul,it's Chorley ROF you are thinking of and it did indeed have it's own station which was sited very close to where the new station is presently being built...
17 Apr 2011
They probably do report that. But I've looked at the Working Time Table. All Northern Services are booked to stop and an hourly off-peak TPE from December.
Xenophon PCDGS
17 Apr 2011
Not wishing to spoil all these celebrations, but another recent thread comes to mind. Would this station be classified as a "category E" station and be subject to having its booking office removed under those recent proposals, that encouraged so many replies from forum members being posted upon that thread.
Xenophon PCDGS
17 Apr 2011
If you're a committed anorak, National Rail gives you (kind of) journey planning info
http://ojp.nationalrail.co.uk/service/timesandfares/PRE/BSV/031011/0930/dep
Try putting MIA as your departure station to Buckshaw Parkway and you will find that you have to change trains at Manchester Piccadilly to another train leaving from Manchester Piccadilly.
For example, by doing this on the link that you provided, the following came up:-
MIA 0929-0944 MAN
MAN 0954-1035 BSV
northwichcat
23 Jan 2009
Northwich
TPE have not applied to the ORR to revise calling patterns so will maintain current calling patterns.
Northern specified Manchester Victoria to Blackpool and Manchester Piccadilly to Blackpool services in their applications. The latter has just a couple of peak time services but it's possible Northern made an error in their application but I imagine they would have to reapply before they could actually revise the calling pattern of Hazel Grove to Preston services.
Here's Northern's application: http://www.networkrail.co.uk/browse...th SA - consultation closed 09 September 2011
