Our new ticketing site is now live! Using either this or the original site (both powered by TrainSplit) helps support the running of the forum with every ticket purchase! Find out more and ask any questions/give us feedback in this thread!
How can it be compliant a wheelcahir user can't just rock up and board without assistance which I thought was more preferable than having ramps which take longer to deploy and then remove, especially on a tight section of the ECML.
Because it's a standard height platform. The platform cannot in general be higher than that because it would risk people having to step down into the train from the platform if it did. It may also be out of gauge.
The issue is that the height of the floors in 80x trains much, much too high. But of course that affects every platform in the whole country used by an 80x, not only Reston.
If a 755 stopped at that platform the floor would be at the same level. So the platform cannot have a hump.
However, I don't think there are any stations on the ECML where access is available without the use of a ramp. Even for a 378 I'm pretty sure you still need a ramp? Others may be able to confirm.
A 700 doesn't need a ramp at London St Pancras platforms A and B but they're allowed to be non-standard heights.
As gimmea50anyday notes, the floor height difference is contained within the step at the door, not at a ramp (except for walking through the corridor to or from the driving vehicles).
A 700 doesn't need a ramp at London St Pancras platforms A and B but they're allowed to be non-standard heights...
The level boarding interface with 700s in the Thameslink core is only at the centre of the train, where the wheelchair area doors are. It’s still a hump, but a properly installed one. The rest of the platform is lower.
This is true, although the main reason for that at at pancras is that other platforms that the trains stop out would not be able to have level boarding across their whole length. There's no point a wheelchair user getting themselves on at the end of the train and then finding they can't get themselves off at their destination.
More generally, those platforms are extremely straight with a very low through speed. The clearances for that are very different to the clearances required on a high speed line where most of the trains are going straight through
Does anyone know the exact date and time of this working (I'm guessing it was Tuesday 22nd or the morning of Wednesday 23rd Feb) and which unit was involved (impossible to make it out in the photo)?
Times are shown in Real Time Trains for services Sunday 15 May onwards. Services as previously discussed, plus a couple of Edinburgh - Berwick-upon-Tweed trips. You have to trick RTT to get it to reveal the details - use Reston Signal eg402 and eg403 then click on the individual journey and it brings up the calls at Reston [RSN].
No guarantee that this is the opening date though, could simply be data in the system for the upcoming timetable change and be amended at a later date.
Although more of a timetabling question, has the frequency of trains calling there been sorted out properly yet?
I do recall reading the East Coast 2022 timetable consultation that the section for Crosscountry mentioned that although they are happy to call at Reston, they would not be able to also call at Dunbar with the same train.
Should ICXC call all trains at Reston and leave Dunbar to ICEC/LNER being as Dunbar has always had direct London trains?
There’s no XC calls in the May timetable as far as RTT is showing. Looks as if the consultation has been ignored regarding that point. Wasn’t the intended TPE service yet to be decided when the consultation was published?
Either that or a bus every 2 hours to Ayton. Don't miss the one back though.
Think that could be why there is a new station with an hourly train service.
The TPE 802s have started announcing Reston as a station stop so need to be manually programmed to remove the stop from the journey setup in the TMS. I don’t think Reston was ever envisaged when Neil Rudd did the original PA recordings so I expect he was brought back in to the studio to record the new station announcement
That's certainly the nearest. Or you can take your life in your hands, cross the A1 and head towards the sea. Coldingham has two I think, and there's another down at the beach.
This is drifting off topic, but the Thameslink platforms aren't all straight- the St Pancras ones are for much of their length but have a surprisingly sharp curve at the south end. Farringdon they're neither straight nor level! But the low speed speed part does apply (slab track too, I think, which helps)
