Network West Midlands
Ascot
26 Nov 2005
Birmingham, UK
Haven't played this in time, might load it up now and have a go, looks good with all the new trains and routes.
1D53
2 Apr 2006
The new branch is quite good. Plenty of whistle boards!
Techniquest
19 Jun 2005
Nowhere Heath
Just downloaded this new version last night, should be interesting to see the new branch.
I see too that it mentions some activities involve turning around and going back. That is an interesting developement!
nath9425
10 Nov 2006
Milepost 84 Chiltern Mainline
:shock:
Rather interesting, I was happily buzzing along in the 170 up until I saw the approach to Salford Bridge, which is where the Overhead lines REAPPEAR!! <(
I was enjoying my little ride without them! Now they are back :( Although I must say the branch is a fantastic little ride for diesels, shame the wire had to come back up. :mad:
:mad: Another little grotty moan - Own up - Who went and touched Riverside and gave it an industrial makeover :shock: It now is classed as an "Extroidanary piece of work" :shock: Although I do like the entrance to the tunnel after the bridge, makes it look very authentic.:neutral:
Apart from that.....(Who resized the repearter banners! :oops: I forgot to look for one and SPAD'd!)
:D
Good work guys!
Jordy
9 Jun 2005
WCML South
Excellent work! :)
The wires are only there because Salford Bridge is a Junction with the WCML, they will disappear after that when the rest of the route is released.
Aureol
29 Sep 2005
Excellent route and a pleasure to drive on once again :D
Time to do a spot of route learning on the branch methinks.
Coxster
9 Jun 2005
Here's to praying that I'll be home from work at a reasonable time tomorrow night to give this new branch a thrashing <D
175001
3 Feb 2007
Between Heaven and Hell
Superb extention. 1st run on the new branch, and overshot Steelhouse Lane by some distance due to the high speed limit, added with the decent gradient :D
Loving the new overheads, and the banner repeaters. They look much more authentic now.
P156KWJ
26 Nov 2007
Nottinghamshire
Excellent work on the bridges, tunnels, repeaters etc. but I find it EXTREMELY hard to stick to the timetable, mostly because the signal doesn't clear until about 4 minutes after you've supposed to have gone, and the speed limits seem to be decreasing agin, yet no timetable easing :( and when you leave Lower End towards Whitminster, it gave me a TPWS brake demand after passing a signal that cannot display red :???:
Other than that, it's a damn sight better than what I could do :lol:
Bill EWS
10 Feb 2006
Didcot
Hi,
I have enjoyed the latest NWM upgrade files that I have run so far. Excellent upgrades and the new branch looks great. Luckily I ran a passenger train over this route first, which meant that when I ran the freight train I managed to get up the grade without any problem. Proving what route learning is all about.
The changes to the Mammerwich route is also very interesting. I like the objects at Riverside and the Bridge and tunnels. The new repeater signals are also more realistic. At first I was sorry to loose the old river bridge, but as it appears in a other routes this makes the Hammerwich a bit more individual'.
I can still see the old bridge ocassionally when running the other routes.
The three Hi-Res files also ran well and the quality is really noticeable. I didn't suffer any worse frame rates than normal for my computer. The new overhead gantries also look great with a nice 3-D effect.
I forgot about the overhead isolated sections with the 323 and with a bang and a rumble the pantograph dropped and the train came to a stop. I had to put the reverser into neutral and press the number 2 (start) key to raise the pantograph and get going again.
All the route ran perfectly. However the following day I loaded up the Pacer Route and got the dreaded 'Blue Screen'. There were no error messages. The train cab is complete but the Object screen is completely blue. Is it my computer, or are others getting the same error and that there is a fault with the file?
Here is a grab shot of the blue screen...
Thanks to everyone involved on producing the route. A fantastic effort.
Cheers.
BillEWS.
Coxster
9 Jun 2005
Last night I had the chance to drive much of the route and what can I say apart from great work to all involved! It's a nice little extension and an improvement on the already very good released sections. Particularly the first crossing you come to on the new Salford extension [map] ;)
velaro
25 Jun 2007
Reutlingen, Germany
Re Class 143 Pacer: This train uses panels with a non-standard width. Try using MS Paint (Menu: Image\Attributes) to increase the width of panel_wide.bmp and panel_wide_n.bmp to 2048. If that doesn't work: the train does come with (smaller) alternate panels. Go into panel.cfg and set DaytimeImage = d3d\panel.bmp and NighttimeImage = d3d\panel_n.bmp.
laseandre
27 Oct 2007
Does this work in BVE2? If not, is there a download link for a BVE2 version?
adamp
5 Oct 2007
Manchester
Forgive me if this has been mentioned above, but is there the only 3 routes with the new branch on? and will there be any night routes on the new branch aswell?
P156KWJ
26 Nov 2007
Nottinghamshire
not counted the number, think there are about 3. there is a 56, 156, and 170 diagram. would be nice, but I like the branch anyway 8-)
