Some more updates published on Saturday.
New dataset published RJRG098 13 February 2016
To add permitted routes between South Wales and Manchester via Newton le Willows, (to allow connections on to direct train services that go via Warrington, Earlestown and Newton le Willows to Manchester), the following changes have been made.
Map sequence added
Bridgend (BGN) and MANCHESTER GROUP (G20) - added sequence 'AW+NC+CL'
Cardiff Central (CDF) and MANCHESTER GROUP (G20) - added sequence 'AW+NC+CL'
Craven Arms (CRV) and MANCHESTER GROUP (G20) - added sequence 'AW+NC+CL'
MANCHESTER GROUP (G20) and Hereford (HFD) - added sequence 'CL+NC+AW'
MANCHESTER GROUP (G20) and Newport S.wales (NWP) - added sequence 'CL+NC+AW'
MANCHESTER GROUP (G20) and Pontypridd (PPD) - added sequence 'CL+NC+AW'
MANCHESTER GROUP (G20) and Shrewsbury (SHR) - added sequence 'CL+NC+AW'
MANCHESTER GROUP (G20) and SWANSEA GROUP (G38) - added sequence 'CL+NC+AW'
MANCHESTER GROUP (G20) and Whitland (WTL) - added sequence 'CL+NC+AW'
These add mapped routes which go via Nantwich and Newton-le-Willows, I assume in connection with the current engineering works.
In each case, there were already mapped routes via Warrington and Glazebrook.
To remove circuitous routes via York and Scarborough between Llandudno Junction and Goole Routeing Points, the following changes have been made.
Map sequence added
Goole (GOO) and Llandudno Junction (LLJ) - added sequence 'HL+TP+JG'
Goole (GOO) and Llandudno Junction (LLJ) - added sequence 'HL+TP+JO'
Goole (GOO) and Llandudno Junction (LLJ) - added sequence 'HL+TP+MJ'
Goole (GOO) and Llandudno Junction (LLJ) - added sequence 'TP+JG'
Goole (GOO) and Llandudno Junction (LLJ) - added sequence 'TP+JO'
Goole (GOO) and Llandudno Junction (LLJ) - added sequence 'TP+MJ'
Goole (GOO) and Llandudno Junction (LLJ) - added sequence 'YK+VK+JG'
Goole (GOO) and Llandudno Junction (LLJ) - added sequence 'YK+VK+JO'
Goole (GOO) and Llandudno Junction (LLJ) - added sequence 'YK+VK+MJ'
Map sequence removed
Goole (GOO) and Llandudno Junction (LLJ) - removed sequence 'HL+MN+JG'
Goole (GOO) and Llandudno Junction (LLJ) - removed sequence 'HL+MN+JO'
Goole (GOO) and Llandudno Junction (LLJ) - removed sequence 'HL+MN+MJ'
Goole (GOO) and Llandudno Junction (LLJ) - removed sequence 'WY+MN+JG'
Goole (GOO) and Llandudno Junction (LLJ) - removed sequence 'WY+MN+JO'
Goole (GOO) and Llandudno Junction (LLJ) - removed sequence 'WY+MN+MJ'
This removes all mapped routes which go:
via York;
via Selby and Halifax; and
via Knottingley and Halifax.
It adds mapped routes which go:
via Liverpool (but not via Bidston);
via Doncaster and Wakefield;
via Selby and Doncaster; and
on the line between Wakefield and Mirfield.
If anyone was wondering, the sequences which didn't change are HO+JG, HO+JO and HO+MJ.
To provide permitted routes via Crewe between Llandudno Junction and Salisbury Routeing Points the following addition has been published
Map sequence added
Llandudno Junction (LLJ) and Salisbury (SAL) - added sequence 'CH+OP+WC'
This adds mapped routes which go via Chester, Crewe, Shrewsbury and Newport.
There were and are no mapped routes via Chester, Wrexham and Newport, although the shortest route
is via Hawarden, Wrexham and Newport.
Easements changed 3 easement(s) changed electonic data only to ensure the Journey planners apply the easements.
Easement changed16 change(s) in 700620: During engineering works 02 to 11 April 2016, the route between Bristol Temple Meads and Bath Spa will be closed. Alternative routeings will be in force via Chippenham, Swindon and Bristol Parkway. For journeys from Portsmouth, Fratton, Cosham, Fareham, Southampton Central, Romsey, Salisbury, Warminster and Dilton Marsh that would travel to or via Bristol on tickets routed ANY PERMITTED (00000), NOT VIA LONDON (00700), VIA YEOVIL (00829), VIA SALISBURY (00618), AP SALISBURY (00438) may travel via Swindon. This easement applies in both directions
Easement changed25 change(s) in 700614: During engineering works 02 to 11 April 2016, the route from Bristol to Weymouth will be disrupted. Customers with tickets to Bristol travelling from Weymouth, Upwey, Dorchester West, Maiden Newton, Chentnole, Yetminster, Thornford, Yeovil Pen Mill, Castle Cary, Bruton, Frome, Westbury, Trowbridge, Bradford On Avon, Avoncliff, Freshford, Bath Spa, Melksham and Chippenham on tickets routed ANY PERMITTED (00000), NOT VIA LONDON (00700), VIA YEOVIL (00829) and VIA SALISBURY (00618) may travel via Swindon. This easement applies in both directions.
Easement changed35 change(s) in 700621: During engineering works 17 April 2016 the route between Bristol Temple Meads and Bath Spa will be closed. Alternative routeings via Chippenham Swindon and Bristol Parkway will be place. For journeys from Portsmouth, Fratton, Cosham, Fareham, Southampton Central, Romsey. Salisbury, Warminster, Dilton Marsh, Weymouth, Dorchester West, Maiden Newton, Chetnole, Yetminster, Thornford, Yeovil Pen Mill, Castle Cary, Bruton, Frome, Westbury, Trowbridge, Bradford on Avon, Avoncliff, Freshfold, Bath Spa, Melksham and Chippenham that would travel to or via Bristol on tickets routed ANY PERMITTED (00000), NOT VIA LONDON (00700), VIA YEOVIL (00829), VIA SALISBURY (00618) may travel via Swindon. this easement applies in both directions.
No changes to the text.
A further set of changes was released last Wednesday.
New dataset published RJRG0399 17 February 2016
A review of Map permissions in West Yorkshire has resulted in the following changes.
In the following, I've used "Healey" to refer to the line between Mirfield and Wakefield Kirkgate. There is a place with this name of the line, but there's no station.
In the same way, I've used "Askern" to refer to the line between Pontefract Monkhill and Doncaster.
I've used "Knottingley" to refer to the line between Pontefract and Goole, as that's the only line you can access from the station there.
Map sequence added
Barnsley (BNY) and PONTEFRACT GROUP (G22) - added sequence 'AD+JL'
Barnsley (BNY) and PONTEFRACT GROUP (G22) - removed sequence 'SY'
This removes mapped routes via Meadowhall, to leave only ones via Wakefield
Doncaster. (DON) and PONTEFRACT GROUP (G22) - added sequence 'DO'
BRADFORD GROUP (G03) and WAKEFIELD GROUP (G30) - removed sequence 'GU'
No effect.
PONTEFRACT GROUP (G22) and HALIFAX GROUP (G39) - added sequence 'DP'
PONTEFRACT GROUP (G22) and HALIFAX GROUP (G39) - removed sequence 'GU'
PONTEFRACT GROUP (G22) and HALIFAX GROUP (G39) - removed sequence 'WK'
PONTEFRACT GROUP (G22) and HALIFAX GROUP (G39) - removed sequence 'WY'
This adds mapped routes which go between Huddersfield and Leeds, either via Dewsbury or via Wakefield.
It removes mapped routes via Swinton and via Doncaster.
PONTEFRACT GROUP (G22) and HUDDERSFIELD GROUP (G40) - added sequence 'YK+SL'
PONTEFRACT GROUP (G22) and HUDDERSFIELD GROUP (G40) - removed sequence 'WK'
This adds mapped routes via Leeds and Healey.
It removes mapped routes via Swinton.
PONTEFRACT GROUP (G22) and Meadowhall (MHS) - added sequence 'HD+BB'
PONTEFRACT GROUP (G22) and Meadowhall (MHS) - added sequence 'JL'
PONTEFRACT GROUP (G22) and Meadowhall (MHS) - added sequence 'SY'
PONTEFRACT GROUP (G22) and Meadowhall (MHS) - removed sequence 'WK'
This adds mapped routes which go through Doncaster but not Wakefield.
It removes mapped routes via Barnsley and Doncaster.
PONTEFRACT GROUP (G22) and WAKEFIELD GROUP (G30) - added sequence 'JL'
PONTEFRACT GROUP (G22) and WAKEFIELD GROUP (G30) - removed sequence 'DH'
PONTEFRACT GROUP (G22) and WAKEFIELD GROUP (G30) - removed sequence 'GU'
This removes the mapped routes via Doncaster.
WAKEFIELD GROUP (G30) and HALIFAX GROUP (G39) - added sequence 'NB+GU'
WAKEFIELD GROUP (G30) and HALIFAX GROUP (G39) - removed sequence 'DP'
WAKEFIELD GROUP (G30) and HALIFAX GROUP (G39) - removed sequence 'GU'
This removes mapped routes via Pontefract and via Dewsbury.
WAKEFIELD GROUP (G30) and HUDDERSFIELD GROUP (G40) - added sequence 'HL+YN'
WAKEFIELD GROUP (G30) and HUDDERSFIELD GROUP (G40) - removed sequence 'WY'
This removes mapped routes via Pontefract.
To remove Circuitous Routes from the Goole Routeing Point the following changes have been made.
Map sequence added
BIRMINGHAM GROUP (G02) and Goole (GOO) - added sequence 'BM+TP'
BIRMINGHAM GROUP (G02) and Goole (GOO) - added sequence 'WH'
BIRMINGHAM GROUP (G02) and Goole (GOO) - removed sequence 'BM+MN+WY'
BIRMINGHAM GROUP (G02) and Goole (GOO) - removed sequence 'XL'
BIRMINGHAM GROUP (G02) and Goole (GOO) - removed sequence 'XL+WY'
This adds routes:
via Gilberdyke;
via Stalybridge, Healey and Pontefract;
via Halifax, Healey and Pontefract;
It removes routes:
via Coventry;
via Barnsley;
via York;
via Sheffield and Pontefract;
via Glazebrook and Knottingley; and
via Brighouse and Knottingley.
Chester (CTR) and Goole (GOO) - added sequence 'JG+LY'
Chester (CTR) and Goole (GOO) - added sequence 'JG+LY+HL'
Chester (CTR) and Goole (GOO) - added sequence 'JG+TP'
Chester (CTR) and Goole (GOO) - added sequence 'JG+TP+HL'
Chester (CTR) and Goole (GOO) - added sequence 'JO+LY'
Chester (CTR) and Goole (GOO) - added sequence 'JO+LY+HL'
Chester (CTR) and Goole (GOO) - added sequence 'JO+TP'
Chester (CTR) and Goole (GOO) - added sequence 'JO+TP+HL'
Chester (CTR) and Goole (GOO) - added sequence 'MJ+LY'
Chester (CTR) and Goole (GOO) - added sequence 'MJ+LY+HL'
Chester (CTR) and Goole (GOO) - added sequence 'MJ+TP'
Chester (CTR) and Goole (GOO) - added sequence 'MJ+TP+HL'
Chester (CTR) and Goole (GOO) - removed sequence 'JG+MN+HL'
Chester (CTR) and Goole (GOO) - removed sequence 'JG+MN+WY'
Chester (CTR) and Goole (GOO) - removed sequence 'JO+MN+HL'
Chester (CTR) and Goole (GOO) - removed sequence 'JO+MN+WY'
Chester (CTR) and Goole (GOO) - removed sequence 'MJ+MN+HL'
Chester (CTR) and Goole (GOO) - removed sequence 'MJ+MN+WY'
The sequences which haven't been replaced are MJ+HO, JG+HO and JO+HO.
This adds some mapped routes via Healey.
It removes routes via York and ones via Brighouse.
Craven Arms (CRV) and Goole (GOO) - added sequence 'MC+LY'
Craven Arms (CRV) and Goole (GOO) - added sequence 'MC+LY+HL'
Craven Arms (CRV) and Goole (GOO) - added sequence 'MC+TP'
Craven Arms (CRV) and Goole (GOO) - added sequence 'MC+TP+LY'
Craven Arms (CRV) and Goole (GOO) - removed sequence 'MC+MN+WY'
This adds some mapped routes via Gilberdyke and via Healey.
It removes routes via York and ones via Brighouse and Bradford.
EARLESTOWN GROUP (G78) and Goole (GOO) - added sequence 'NO+LY'
EARLESTOWN GROUP (G78) and Goole (GOO) - added sequence 'NO+TP'
EARLESTOWN GROUP (G78) and Goole (GOO) - added sequence 'NO+TP+HL'
EARLESTOWN GROUP (G78) and Goole (GOO) - added sequence 'NR+LY'
EARLESTOWN GROUP (G78) and Goole (GOO) - added sequence 'NR+LY+HL'
EARLESTOWN GROUP (G78) and Goole (GOO) - added sequence 'NR+TP'
EARLESTOWN GROUP (G78) and Goole (GOO) - added sequence 'NR+TP+HL'
EARLESTOWN GROUP (G78) and Goole (GOO) - removed sequence 'NO+MN+WY'
EARLESTOWN GROUP (G78) and Goole (GOO) - removed sequence 'NR+MN+WY'
This leaves NO+DB, NO+DW, NR+DB and NR+DW untouched.
This adds some sequences via Gilberdyke.
It also adds ones via Healey and Pontefract (there were already ones via Healey and Doncaster).
It removes routes via York.
It also removes routes via Brighouse, Bradford and Knottingley.
Goole (GOO) and Hooton (HOO) - added sequence 'HL+LY+NO'
Goole (GOO) and Hooton (HOO) - added sequence 'HL+LY+NR'
Goole (GOO) and Hooton (HOO) - added sequence 'HL+TP+NO'
Goole (GOO) and Hooton (HOO) - added sequence 'HL+TP+NR'
Goole (GOO) and Hooton (HOO) - added sequence 'LY+NO'
Goole (GOO) and Hooton (HOO) - added sequence 'LY+NR'
Goole (GOO) and Hooton (HOO) - added sequence 'TP+NO'
Goole (GOO) and Hooton (HOO) - added sequence 'TP+NR'
Goole (GOO) and Hooton (HOO) - removed sequence 'WY+MN+NO'
Goole (GOO) and Hooton (HOO) - removed sequence 'WY+MN+NR'
This adds sequences via Gilberdyke and ones via Healey.
It removes mapped routes:
via York;
via Bradford and Brighouse; and
via Leeds, Warrington and Earlestown.
Goole (GOO) and Huyton (HUY) - added sequence 'HL+HM+NO'
Goole (GOO) and Huyton (HUY) - added sequence 'LY+NO'
Goole (GOO) and Huyton (HUY) - added sequence 'TP+NO'
Goole (GOO) and Huyton (HUY) - removed sequence 'DW+NR'
Goole (GOO) and Huyton (HUY) - removed sequence 'WY+MN+NO'
Goole (GOO) and Huyton (HUY) - removed sequence 'WY+MN+NR'
This adds mapped routes via Gilberdyke and ones via Healey.
via York;
via Wilmslow;
via Pontefract and Warrington; and
via Knottingley, Bradford and Brighouse (although there are new mapped routes via Gilberdyke, Bradford and Brighouse).
Goole (GOO) and Kirkham And Wesham (KKM) - added sequence 'HL+DP'
Goole (GOO) and Kirkham And Wesham (KKM) - removed sequence 'DO+NP'
This adds mapped routes via Gilberdyke.
via York;
via Barnsley;
via Askern;
via Doncaster and Selby; and
via Moorthorpe and Leeds.
Goole (GOO) and Oxenholme Lake District (OXN) - added sequence 'HL+LX'
Goole (GOO) and Oxenholme Lake District (OXN) - removed sequence 'DO+NP+XP'
via York;
via Askern;
via Moorthorpe and Halifax;
via Barnsley and Halifax; and
via Selby and Halifax.
Goole (GOO) and Preston (Lancs) (PRE) - added sequence 'DB+WG'
Goole (GOO) and Preston (Lancs) (PRE) - added sequence 'HL+DP'
Goole (GOO) and Preston (Lancs) (PRE) - removed sequence 'DB+XW'
Goole (GOO) and Preston (Lancs) (PRE) - removed sequence 'DO+NP'
via York;
via Lancaster;
via Barnsley;
via Askern;
via Moorthorpe and Halifax; and
via Doncaster and Selby.
Goole (GOO) and Runcorn (RUN) - added sequence 'HL+LY+MS'
Goole (GOO) and Runcorn (RUN) - added sequence 'HL+TP+MS'
Goole (GOO) and Runcorn (RUN) - added sequence 'LY+MS'
Goole (GOO) and Runcorn (RUN) - added sequence 'TP+MS'
Goole (GOO) and Runcorn (RUN) - removed sequence 'WY+MN+MS'
This adds mapped routes via Gilberdyke, and via Pontefract and Healey.
via York;
via Knottingley, Hebden Bridge and Stalybridge;
via Knottingley, Bradford, Guide Bridge and Reddish North;
via Knottingley, Bradford, Guide Bridge and Levenshulme; and
via Knottingley, Bradford, Guide Bridge and Styal.
Goole (GOO) and Shotton (SHT) - added sequence 'HL+LY+JG'
Goole (GOO) and Shotton (SHT) - added sequence 'HL+LY+JO'
Goole (GOO) and Shotton (SHT) - added sequence 'HL+LY+MJ'
Goole (GOO) and Shotton (SHT) - added sequence 'HL+TP+JG'
Goole (GOO) and Shotton (SHT) - added sequence 'HL+TP+JO'
Goole (GOO) and Shotton (SHT) - added sequence 'HL+TP+MJ'
Goole (GOO) and Shotton (SHT) - added sequence 'LY+JG'
Goole (GOO) and Shotton (SHT) - added sequence 'LY+JO'
Goole (GOO) and Shotton (SHT) - added sequence 'LY+MJ'
Goole (GOO) and Shotton (SHT) - added sequence 'TP+JG'
Goole (GOO) and Shotton (SHT) - added sequence 'TP+JO'
Goole (GOO) and Shotton (SHT) - added sequence 'TP+MJ'
Goole (GOO) and Shotton (SHT) - removed sequence 'HL+MN+JG'
Goole (GOO) and Shotton (SHT) - removed sequence 'HL+MN+JO'
Goole (GOO) and Shotton (SHT) - removed sequence 'HL+MN+MJ'
Goole (GOO) and Shotton (SHT) - removed sequence 'WY+MN+JG'
Goole (GOO) and Shotton (SHT) - removed sequence 'WY+MN+JO'
Goole (GOO) and Shotton (SHT) - removed sequence 'WY+MN+MJ'
The sequences which haven't changed are HO+JG, HO+JO and HO+MJ.
This adds mapped routes via Healey.
It removes mapped routes via York, and via both Bradford and Brighouse.
Goole (GOO) and Shrewsbury (SHR) - added sequence 'HL+LY+MC'
Goole (GOO) and Shrewsbury (SHR) - added sequence 'HL+TP+MC'
Goole (GOO) and Shrewsbury (SHR) - added sequence 'HO+MC'
Goole (GOO) and Shrewsbury (SHR) - added sequence 'LY+MC'
Goole (GOO) and Shrewsbury (SHR) - added sequence 'TP+MC'
Goole (GOO) and Shrewsbury (SHR) - added sequence 'WH+CA'
Goole (GOO) and Shrewsbury (SHR) - removed sequence 'DB+MC'
Goole (GOO) and Shrewsbury (SHR) - removed sequence 'DW+MC'
Goole (GOO) and Shrewsbury (SHR) - removed sequence 'WY+MN+MC'
Goole (GOO) and Shrewsbury (SHR) - removed sequence 'WY+XL+CA'
Goole (GOO) and Shrewsbury (SHR) - removed sequence 'XL+CA'
All of the sequences for this route have been replaced.
This change adds mapped routes:
via Gilberdyke;
via Worcester; and
via Pontefract, Healey and Crewe.
via Barnsley, Coventry, Reddish North, Wigan or York;
via Stockport and Warrington;
via Leeds and Warrington; and
via Pontefract and Sheffield.
HUNTS CROSS GROUP (G70) and Goole (GOO) - added sequence 'NR+LY'
HUNTS CROSS GROUP (G70) and Goole (GOO) - added sequence 'NR+LY+HL'
HUNTS CROSS GROUP (G70) and Goole (GOO) - added sequence 'NR+TP'
HUNTS CROSS GROUP (G70) and Goole (GOO) - added sequence 'NR+TP+HL'
HUNTS CROSS GROUP (G70) and Goole (GOO) - removed sequence 'NR+MN+WY'
This change adds mapped routes via Gilberdyke and via Healey.
via York; and
LANCASTER GROUP (G64) and Goole (GOO) - added sequence 'LX+HL'
LANCASTER GROUP (G64) and Goole (GOO) - removed sequence 'LX+DO'
LANCASTER GROUP (G64) and Goole (GOO) - removed sequence 'XP+NP+DO'
This change adds mapped routes via Gilberdyke.
via Barnsley;
via York;
via Askern;
via Burnley and Moorthorpe;
via Burnley and Selby; and
via Hellifield and Wakefield.
LIVERPOOL GROUP (G18) and Goole (GOO) - added sequence 'NO+LY'
LIVERPOOL GROUP (G18) and Goole (GOO) - added sequence 'NO+LY+HL'
LIVERPOOL GROUP (G18) and Goole (GOO) - added sequence 'NO+TP'
LIVERPOOL GROUP (G18) and Goole (GOO) - added sequence 'NO+TP+HL'
LIVERPOOL GROUP (G18) and Goole (GOO) - removed sequence 'NO+MN+WY'
LIVERPOOL GROUP (G18) and Goole (GOO) - removed sequence 'NR+MN+WY'
This adds mapped routes via Gilberdyke and via Healey.
It removes all mapped routes:
via York;
via Warrington and Leeds;
and via Brighouse and Bradford.
WARRINGTON GROUP (G31) and Goole (GOO) - added sequence 'NO+LY+HL'
WARRINGTON GROUP (G31) and Goole (GOO) - added sequence 'NO+TP+HL'
WIGAN GROUP (G34) and Goole (GOO) - added sequence 'EH+NR+DB'
WIGAN GROUP (G34) and Goole (GOO) - added sequence 'EH+NR+DW'
WIGAN GROUP (G34) and Goole (GOO) - added sequence 'NN+DB'
WIGAN GROUP (G34) and Goole (GOO) - added sequence 'NN+DW'
WIGAN GROUP (G34) and Goole (GOO) - removed sequence 'XW+DB'
WIGAN GROUP (G34) and Goole (GOO) - removed sequence 'XW+DW'
This adds mapped routes via Patricroft, via Wilmslow, and ones via both Ince and Atherton.
It removes mapped routes via Preston.
WREXHAM GROUP (G49) and Goole (GOO) - added sequence 'JG+LY'
WREXHAM GROUP (G49) and Goole (GOO) - added sequence 'JG+LY+HL'
WREXHAM GROUP (G49) and Goole (GOO) - added sequence 'JG+TP'
WREXHAM GROUP (G49) and Goole (GOO) - added sequence 'JO+TP'
WREXHAM GROUP (G49) and Goole (GOO) - added sequence 'JO+TP+HL'
WREXHAM GROUP (G49) and Goole (GOO) - added sequence 'MJ+LY'
WREXHAM GROUP (G49) and Goole (GOO) - added sequence 'MJ+LY+HL'
WREXHAM GROUP (G49) and Goole (GOO) - added sequence 'MJ+TP'
WREXHAM GROUP (G49) and Goole (GOO) - added sequence 'MJ+TP+HL'
WREXHAM GROUP (G49) and Goole (GOO) - removed sequence 'JG+MN+HL'
WREXHAM GROUP (G49) and Goole (GOO) - removed sequence 'JG+MN+WY'
WREXHAM GROUP (G49) and Goole (GOO) - removed sequence 'JO+MN+HL'
WREXHAM GROUP (G49) and Goole (GOO) - removed sequence 'JO+MN+WY'
WREXHAM GROUP (G49) and Goole (GOO) - removed sequence 'MJ+MN+HL'
WREXHAM GROUP (G49) and Goole (GOO) - removed sequence 'MJ+MN+WY'
This leaves JG+HO, JO+HO and MJ+HO untouched.
It adds some mapped routes via Healey (there were already routes via Huddersfield and Wakefield groups, but they all went via Leeds).
It removes routes:
via York;
via Stalybridge and Halifax;
via Glazebrook and Halifax;
via Newton-le-Willows, Stalybridge and Selby (Newton-le-Willows, Rochdale and Selby is still fine).
Crewe (CRE) and Goole (GOO) - removed sequence 'MS+MN+WY'
Goole (GOO) and Stoke On Trent (SOT) - removed sequence 'WY+MN+SK'
These remove all mapped routes via Knottingley, leaving behind only ones via Doncaster.
To bring Darlington and Middlesborough map permissions to Oxenholme in line with Newcastle and Northallerton the following changes have been made
Darlington (DAR) and Oxenholme Lake District (OXN) - removed sequence 'MT+MX'
MIDDLESBROUGH GROUP (G42) and Oxenholme Lake District (OXN) - removed sequence 'MT+MX'
These remove routes via Manchester, leaving only ones via Hexham.
To ensure Journey Planners showed Advance Tickets on journeys via Bedford the following easement has been published.
Easement added
700622: For Journeys from St Albans City; Harpenden; Luton Airport Parkway; Luton; Leagrave; Harlington and Flitwick to destinations beyond Chesterfield this positive Routeing Point easement will override fares checking which is preventing journey planners showing some ticket types on journey plans. This easement applies in both directions.
These stations are associated with Bedford and West Hampstead Thameslink. I don't know off-hand what journeys were being prevented by this.
For engineeering works affecting Cross Country services the following easement has been published
Easement added
700623: During engineering work on the 01 and 02 May 2016, Cross Country services between Chesterfield and Wakefield Westgate are replaced by rail replacement road services. This map easement will create temporary map permissions directly between Chesterfield and Wakefield Westgate, to allow Journey planners to show the full range of tickets for journeys via Chesterfield.
I'd be disappointed if this didn't also cover journeys to Chesterfield on those dates.
