N Gauge - Board Width
Michael.Y
14 Oct 2011
I want to create a simple two-track loop with a couple of sidings and a station or two.... I don't have much room for a model railway so N is my only option..... what's the minimum board width I'd need? (Thinking of wall mounting the whole thing).
StripeyNick
25 Apr 2012
Cowbridge, S.Wales
I'd say that 2ft is the minimum to go for. It'll give you a bit of room to play with and won't see you trains right on the very edge of the board.
PaxVobiscum
4 Feb 2012
Agreed.
I started one last year 3 feet by 7 feet and it seems enormous though I can almost manage 'real' radii on the curves. If yours will be level, then 2 feet by 6 or whatever you can manage should give a lot of scope.
I have gradients on the curves (grade separated figure of 8) so the extra space makes that work.
tjlrailblue
20 Sep 2013
check out the n gauge forum
my layout is 80cm wide but for 2 loops probably 60cm is enough if you use tight radius curves
Tim
Jonny
10 Feb 2011
4' by 2' is about the minimum for a tail-chaser (round in loops) in N gauge. That is assuming that you're not bothered about tight curves.
Michael.Y
14 Oct 2011
Not particularly bothered by curves - I will probably disguise any lack of reality with a tunnel and trees.
Cheers for replies, will do some more research.
