More problems on WCML. (7/10)
Hellfire
14 Dec 2012
Between 15 and 30 min delays out of Euston on VT services tonight. Incoming trains delayed by signal problems near Crewe. Not a great week for WCML
Rugd1022
19 Feb 2010
Rugby
Track curcuit failure south of Stafford too this afternoon, but trains were being talked past signals in good fashion so the delay wasn't too bad.
Antman
3 May 2013
Also delays of 30 minutes in the Wigan area due to a trespasser
user15681
3 Jun 2012
Was bad Sunday afternoon too... Points failures at Hanslope Junction and Ledburn Junction, as well as a TCF at Canton Junction.
voyagerdude220
13 Oct 2005
Also issues between Motherwell and Glasgow Central, I think in the Newton area.
Southbound Scotrail's 1C52 18:39 Ayr to Edinburgh got stuck outside Motherwell for over an hour, with Virgin's 20:10 Glasgow Central to Crewe also over an hour late.
68000
27 Jan 2008
There have been a few incidents today affecting WCML traffic in Scotland
1. Points failure at Uddingston Junction after overnight works meaning all traffic diverted via Bellshill (hopefully fixed tonight)
2. Freight train got stuck for a while on the incline towards Bellshill (now fixed)
3. Points failure at Newton this evening (now fixed)
eMeS
12 Jun 2011
Milton Keynes, UK
For an ignoramus, what's a "TCF"? Thanks.
I certainly noticed the odd running yesterday pm at Wolverton with the UP Fast being host to slow moving passenger trains, and with Voyagers & Pendolinos running on the UP Slow. Down traffic seemed more normal.
GB
16 Nov 2008
Somewhere
It stands for Track Circuit Failure generally used when a track circuit is showing occupied when it shouldnt. Its a bit of a misnomer really as the signalling is doing its job. ie its detected there is a problem and gone into its default state.
Should be track circuit showing occupied when clear (SOWC) or showing clear when occupied (SCWO) if you really wan't to get into semantics.
Boodiggy
8 Nov 2012
There is a 50 TSR north of the station on the up fast so that is why trains will be passing by slowly.
The reason trains were diverting on to the slow lines was due to S&T working on points at Ledburn Junction
elementalpat
7 Nov 2011
Seems the wires have gone down again in the northern stretch of the WCML at Lockerbie.
Bad weeks for the WCML so far.
Just curious as then upgrade was done several years ago, were any works done for this part as this area seems quite prone to issues recently.
Muzer
3 Feb 2012
A failure is a failure, IMHO. Do you also object to the term "fail-safe" because if it fails safe, it hasn't really failed? The track circuit is not detecting trains. It is not doing its job. It HAS failed in a manner which is safe, but nevertheless it is still not operating as a track circuit. It has failed.
carriageline
11 Jan 2012
Some part of the circuit has failed, be it a relay, track side module, cable, IBJ, part of the rail.
Sent from my iPhone using Tapatalk
thenorthern
27 May 2013
There was a failure this morning as well, London-Manchester via Stoke trains were diverted via Stafford which added quite a bit on. I think it was something to do with signalling.
voyagerdude220
13 Oct 2005
I notice that a train has broken down this morning, between Penrith and Oxenholme Lake District, causing a few trains to be delayed by over an hour. I don't know which train has broken down though.
Would this be the one that was sat in the sidings at Carlisle at approx 1130ish? An eight car 350 no less!
