MML Electrification: progress updates
Helvellyn
28 Aug 2009
Not seen it mentioned but at the weekend the old platform 4 brickwork at Wellingborough was demolished and removed. Not sure if extra clearance is required to reinstate the fourth track or it is just easier to build the platform from scratch.
Also looks like a site office and compound for the Wellingborough works is going up beyond where the reinstated platform 4 will be.
It’s highly likely it is being moved back. The planning drawings mentioned a few weeks ago showed P4 is completely new construction. There’s also a fairly significant amount of widening out to realigned tracks on the south end of P3 as well.
24 Jun 2014
Derby
It would be a massive spend, and potentially conflicting with proposed Leicester remodelling work to add signal overlaps and perhaps a new platform - though none of that is approved yet as far as I know.
I guess it depends upon what is meant by "massive".
In post 2914, I mentioned that Ian Walmsley had reported that, at the recent IMechE Conference, it had been reported that the Cardiff Intersection Bridge solution could be used at Leicester; in the RIA Electrification Cost Challenge report, it records that these works cost less than GBP1m.
24 Jun 2014
Derby
Is it correct to presume that the OHLE being installed on the MML will be able to cope with 2x5-car EMUs running at 125mph on a regular basis, irrespective of the daily frequency of the multiple EMU unit trains using the route?
59CosG95
18 Aug 2013
Beeston (Notts)
Yes. From what I can see, the new OLE is independently tensioned catenary & contact wires. The existing Mk3b OLE south of Bedford uses equalising plates (i.e. 1 set of balance weights tensions both wires), which means both are at the same tension (11kN for Mk3b). The new UKMS wiring uses 12kN in the catenary, and 15kN in the contact - the same as on the WCML (where UK1 equipment is installed) and on the GWML.
The greater tension means that multiple pantographs will be able to run without a significant risk of the front pan's carbon-contact interface oscillation compromising the rear pan's current collection.
The lower tension south of Bedford means that 125mph operation with multiple pans is out of the question unless they are sufficiently spaced - this was also partly the reason why 12-car 319s were restricted to 75mph (while 700s, 377s and 387s could do 100mph). The 319s were mainly fitted with heavier Stone Faiveley AMBR pans, which caused more oscillation than the lighter, aerofoil-equipped Brecknell Willis HS pans fitted to the Electrostars & Desiro Citys.
59CosG95
18 Aug 2013
Beeston (Notts)
Rumours are circulating that Wellingborough Up Yard is due to receive some upgrades as part of the electrification work. These, allegedly, are:
  • A new connection to the Slow Lines at the northern end of the yard
  • Electrification of the first two (i.e. westernmost) sidings in the yard, which will be used by Network Rail
I hope this means that electrically hauled freight might make an appearance on the MML! It does, of course, play into the hands of bi-modal locos, as the main freight routes from the MML south of Wellingborough are unelectrified (Marston Vale, Dudding Hill, the Tottenham Curve (to the GOBLIN)).
Roast Veg
28 Oct 2016
What are the major flows into and out of that yard? Do they pass through enough electrified railway to make it worthwhile?
59CosG95
18 Aug 2013
Beeston (Notts)
GBRf currently operate all flows from the yard, which mainly come from quarries (Cliffe Hill, Mountsorrel, Rylstone, Tunstead, Whatley), thence supplying railheads at Elstow (Bedford), Luton Crescent Rd, Radlett Lafarge, Cricklewood, Ferme Park (Hornsey - ECML) and Acton Yard (GWML).
Currently, the lack of wires on those routes mentioned above would make an AC-only loco pointless, but the non-wired distances are probably short enough to warrant a bi-modal loco hauling freight over those routes in the short term, as well as shunting within the terminals if OLE can't be accommodated.
However, NR may have different plans for the yard if they take it over - what they are remains to be seen.
InTheEastMids
31 Jan 2016
This is consistent with my observation in Post 2806 that additional hardware has been attached to the outside of (I think) the 4-track portals here.
philjo
9 Jun 2009
Presumably this could also be used for planned or emergency stabling/turnback for EMUs - either the Corby services or Thameslink.
I can't see anything being done for freight, so I assume it's stabling for overnights or emergencies. I believe the yard is currently in a temporary state and what is now its headshunt becomes the Up Slow.
Class 170101
1 Mar 2014
NR orginally planned to wire the link between the T&H and MML but it was shelved on gounds of cost.
Before Kettering. The costs of the T&H job went up.
It seems to have been pulled during 2015. You’ll possibly recall it was discussed a few times in the Goblin wiring thread, eventually I found that it’s last official mention was in the Jan 2015 CP5 delivery plan, then it had disappeared when the plans restarted after the Hendy review.
westcoaster
4 Dec 2006
DTOS A or B
Back from a week's holiday here is the current state of play at Wellingborough.
Jozhua
6 Jan 2019
Hi all! Found a petition asking for government to electrify all UK rail:
https://petition.parliament.uk/petitions/259903
Wether it is a realistic goal, would be worth signing to show people we care about rail electrification on both the MML and in the rest of the country.
DogsOnTrains
6 Aug 2019
How long will the new platforms 3+4 be at Wellingborough? 12 car train long?
londonmidland
22 Dec 2009
Leicester
I can’t give a specific location but between Kettering and Wellingborough, the signals in the way of the fourth track are being replaced with new overhead signal gantries, which are being erected.
59CosG95
18 Aug 2013
Beeston (Notts)
Would that be Harrowden Junction, by any chance? There's definitely an extant gantry that needs a-choppin'.
WymoWanderer
18 Dec 2017
Between BDM and WEL
Been away for a couple of weeks and a bit of progress around Wymington, North Bedfordshire.
  • Wires are now up on the fast lines as far as I could see to the South of the village. To the North of the village the wires end where the deviation starts.
  • New signal / telecom cabinets installed on the fast line
  • Local power distribution lines running over the fast lines have been removed and presumably buried
  • Notification of temporary closure of the footbridge over the slow lines just at the Northern entrance of the Sharnbrook tunnel. Work is schedled for 2 months for waterproofing and parapet height raising.
  • New works depot located near said footbridge
Now disused power line mast following cable burial.
y4m7g_cOxQn_1PIGSezJz85X9KsyE7popogRUR3x2-7MyvUKWUNRZT5BBB9pTNW8jNTnMGmVdLbootmnKeJav8-HYTpNoyikz_q2EYbbnQTxue59vBPUxg86xiQwWv3x2RC5MFUB6jvz9IyYsYaXzLTOxstgaGV5mVdYwqOcO2Lrg8vrkb1J_ZPHp-jC8hnZqOIpVcKlyCON6LoXcNfQZy48w
New comms / signalling cabinets
y4mZMgocL-f8d1mQElZ3ZVHB-ko7cU0E2strF0lsseF4PMQaeYYArmdyoqCjj-yi2iNd0t-PMjbnSCKRnffbeK47qIY8qbx68Sp05xysHSGyixWwhwtms4tOgpZSwKSQtxwsPbgjjI-h-prTgFba10wMNaIiJ1QdtLHrMK7GwegcrMXX6a_ZCMaAEZQ6tjbdU8fAdq1T_ZH_iHLUI89PxFvNQ
Start of OHLE wires on fast lines
y4mY2HPuefIO4AwHuGVV-JEqgnd2-z0Ra8e03TRYVyGmTQTr2oYG-XeBpcHsmVy34sKUu7tHUBbQzjfEv4JX05tFZhbkB8g--Cm7BCiuUSv0Tm8oW6Dix7VRsNpm_-mLxXWnTibsJoLbjPuEJmQQmd86nMulsxftNKROd3wSMeQwXg4TIcPWG472-GxEZ4Xao82HcWgzkPsKBtkIGjlb8WD6A
y4mHpxChkQ0afR21lolPzeUJoAfGda-Xz5uKOKpkrdbn9w_HyTw68kP_-rVVvKbRno6FVTaPM7uwKAynvmA1up7LFxfkmUgf3f9GMlG46lXosJz9dFSl2T1sl0GzwtnB0tIolNpevd3RPwabGx0D9stab7zUyhqCc7RUfb_a8Cwu1yQ3HgVdMMOC-diLpVb1DVY1ZGmqXihxtL-UpBpKIRYUg
Close up of OHLE wires
y4mVVhMm93XtkmNmXlqdTKZ4-t1qGLk_26uOOnoRYw4_KsOojLj01t7vziWAFhq1fbUiCXkHq_OiXAgTA4HVE3sfT-VMihB78bMG5iEvRXv0EXnnSiVhnk1_wx0tBqe3OWAFqqd2xmcXYLwqURZuqKcbPRgc3ggtlA-735WKvRoghRvzINXaB-x-ZFSWOMrJP6UgPe0UgCkxmN2jGAkybRObQ
Fast lines looking South toward Souldrop
y4mQNutRqBl37OH1_O8MAASfHkNwA_cwExqNeJM2j0CxdGL2-oG5a2WBJ4JJFPDSnAGXvBQJ16Krsup-tF9gpNkPt8YmSLVDU38oTfRsPN9O23LBOZwmCzMWZgEzDPzRD-8jjJbmuYcsixAfVgp32dY1_Ayn5iimDsdZxdKMBtl9_32cdzauDaHfoQrq2eve1uUsIfn5NUfw2gGf4N7YPkJRw
Fast lines looking North toward Irchester
y4mI16W6xH7spTg3Y_d54OWx3IuBfmMSDHzKcA6uwmcXWvyylVQ7IzWFyf-XpAN9YRfailc6_pYCXKPjG-bW5KIT4LH9WMig-Ac6dMhxPdE8KiScg7AJwuEcYOPOx17qNzCeR0drrjkOUUPKZUAJYrfdr7CnXMSs2AwoE7dlzYEn_vtpkFqxIpxqPaDXwMjhMF6R8ll8CHtvYaQWeiddV-LMw
Footbridge temporary closure
y4m8cZZLlmEhu_2k8QMliTynWhMoKKNE_oN1JvDNfSHsEvzhyo1Itnf2PyeI4pxg2Fxzq5LVh4QDnaMfyvL89R6K6BRc7QyXuLj2nMG2qeAkTB3wH_tgIw01SDyb8n4jjCtu3qO-ZKHqn1dXeXFAyMykqkBrAjz5NqTGzaoT4HP18AeCYE2Pf6hW7uGaCI_X5_lXuByYbTPDWDIU5uH7fga2A
y4mXpWwWQHYxKTR_tJQFDfxF4bKCvexFut6scD1jNX6u0Qc8mnm5Abxgz5g10YlqrCIGsYUli8yDsHrCdRLKcK_P4Ci1-DRZlAqYPOtTyJaUVZhxuSP6_5MwQhiMOCeE2v9NU0CQWpCPno-xeWm08GEfVG1Hs2x0xsqmQaRjvN5U1qdFuTzvFhWqoGSgLQzOgj4BYEOlYiee3VWQfm6UlBhgw
y4mOQr7DW_fPiPTy-kK7mv0ZTlLs1qvi8en3bieS2mEZzBHwmhpwK-vr_MFahbiFwJyCTpP4TjefTyz8LYmhhvHRAusd_ZCoReUefHXVCcPA5xYhY1gKzxWKMHb0yd14G-gNCK6K4RTUtcdK8bZBueZHG7Cd7978jgFz7lKMg53Ss_YXfexZl_53aZpuNoKNzOwC5eUYSCPQasX5R_CUtX5jg
More OHLE
y4mN33z09OpBKqweowFXlbEEOTEQLWvIw8H1uYvLMtHhBn9a597nRrlFauOK3ZxArlalHGD-wkrbqZUJUnQR7gRMw7JHAel977dxyjLfO8E4lNThPH-8dT-vLDQjTaZ070dWq1wtHgGzhnrvL-oAMK8WdoJAog-rgS9XL1O3x-XbKKRlaX_F84yZjGlFEgIfJwOF2qR6GL2Yphdo9WbVSut4A
y4mtqtCu72YmmYA61DL3nN3RrCYiuh3TdVOx9k1lS6PWjCcPQiZIzEROF2wL0PjPKVpRnLl3kTc2KMl-9mmXJXKKEihm_hoUqTOeEL9iMEjaIQTFy-dxYuiqYbcnXXO8PB5PJztVGWsP5_8XgH3I-wHIw79A2tAEWkUDTGq_SQ99_Wazw8URgVUgZeBZrQqtFnryhHCWYkQhYFAHNI3KY0GNg
y4mfoTCM4ZHvOUhNW4fRZ_T4t8P2iKM6_GthrfyJ5m_Y_Qqwq6IdeEK_xPzzX8bNS2reyuB2DtecF3iRkQ4LNNefTriRc7RQDkJqdASdwTbPwTRpQCtb3EabgG6w8IpKaxTrLX2as__1ot0MREKmlr8r4YPi04r5ll07bLk1wy6KtBdDrgqjOGm48W5BCZ2nZBlc3yXH-cWIX8OSn3dB92b8A
59CosG95
18 Aug 2013
Beeston (Notts)
More OHLE
Lovely set of shots there! Looks like the Fasts are now wired all the way from Souldrop to the Irchester end of the Deviation.
Fully aware of this fact, but some pressure on the DaFT to actually fufill some electrification projects would be useful!
You misunderstand how government works.
Firstly, they won’t even be aware of it until it has 10k signatures.
Secondly, even if it gets past that number, it will land on the desk of a middling official in the DfT who will very quickly provide a short reply explaining why such a proposal is completely impractical and unaffordable, and that the Department carefully considers cases for electrification put to it.
It would cause precisely no pressure on the DfT at all.
