Misuse staff pass
BristolLondon
23 Jul 2026
Hi everyone, I want to ask for advice on a TfL misuse staff pass case. I have read on the other thread that is quite similar with my case. Here’s the details of my case
Context:
  • I’m 30, not in education or employment
  • First time offender
  • I’m on dependant visa, waiting to do ILR next year and British citizenship the following year
  • On 22 July 2026 I was caught using a staff pass on Leicester Square, that I found on the tube station which wasn’t mine
  • When approached by the inspector I cooperated fully, confirmed my details, name, address, DOB. I handed it over, and gave my full details
  • I had used the card almost for a month. My husband found it on 2 July 2026 but I’m the one who keep using it. I don’t know the owner of the card.
  • I haven’t received any letters about this case.
What I want to know is:
  1. How long will I receive the letter since the day I got caught?
  2. What is the realistic range of outcomes here? Will I receive a warning letter / prosecution under TfL Bylaws / SJPN?
  3. Will it be written as a criminal record and affecting my ILR & citizenship process?
  4. If I got prosecuted and found guilty (which I am) should I go to the court or is it unnecessary?
Any advice appreciated. Thank you.
Huntergreed
Events Co-ordinator
16 Jan 2016
Dumfries
Context:
Welcome to the forum.
The first thing it’s important to point out is that it is illegal for us to give out any advice related to immigration and/or citizenship matters, so we will not be able to provide any advice on this issue I’m afraid.
TfL by default normally prosecute all cases of pass misuse and a prosecution under their byelaws is the normal outcome. This doesn’t mean that it is impossible to reach a settlement, however experience suggests a prosecution is very likely in these circumstances.
To answer your questions:
1) The letter could take anything from a few days to a few months - TfL have up to 6 months to ‘lay the papers’ for a byelaw prosecution so it could take up to this amount of time.
2) As previously advised, a byelaw prosecution is most likely - if you plead guilty through a SJPN, it is unlikely you will need to attend court, but each case is different.
3) We are legally unable to comment on this as it is illegal for us to advise on immigration matters.
4) If you are issued a SJPN and plead guilty, it is unlikely you will be summoned to appear in court. You will be sentenced by the court without being present and be required to pay a fine under TfL Byelaws.
BristolLondon
23 Jul 2026
Hi thank you for your answer.
3. Yesterday the officer asked me a question “you know what you’re doing is really wrong. You know you’re guilty right?” And I said “yes”. Will I 100% got the SJPN because of that?
4. If I got the SJPN and plead guilty will be written as a criminal record?
If I got my DBS check will it be written there? Do you know how much approximately the fine?
Haywain
3 Feb 2013
As you seem to have a good deal of use from the card it is likely that TfL will seek to recover the fares avoided by way of having you 'ask' for the additional offences "to be taken into consideration" - this is done by sending you a list of journeys for you to agree that you made the journeys, and submit that list to the court - and if that is done you will be required to attend the court hearing in person.
Realistically, your only chance of avoiding prosecution and conviction is to engage a solicitor in the hope that they can put forward suitable mitigation in line with TfL's prosecution policy to covonce TfL to issue a warning. However, this does not come cheap and the services of a specialist solicitor are likely to cost you in excess of £800.
Mattplans
27 Sep 2024
London, UK
TfL prosecute under their own Bylaws which are not recordable on DBS checks, but they may anyway, in certain circumstances, show up on an Enhanced check. That is a separate matter as to one's legal obligation to disclose the conviction; some roles may lawfully demand all criminal history, even spent convictions. I believe such a conviction is deemed 'spent' upon paying the fine?
T
fl are going to write to you in the next 30 days asking for your explanation of what happened. This is your opportunity to provide mitigation for the offence and overall is how they decide how to proceed. As mentioned above, TfL will usually take these cases to prosecution.
BristolLondon
23 Jul 2026
T
Do you have any suggestions what should I write on my explanation letter?
Should I mention that I found it and has been using it for a month?
I will keep this case updated here. I’ll upload the letter here when I got it.
Adam Williams
2 Jan 2018
Warks
Do TfL not hotlist lost/stolen staff passes so they immediately fail to operate the gateline?
Of course, that presumes the staff member in question noticed they'd lost it and reported it accordingly, but on the face of it it's pretty wild to me it worked for nearly an entire month.
Mawkie
17 Feb 2016
If I recall correctly, they hotlist them in batches.
There are a lot of "found a staff pass on the floor" cases which suggest to me many of them are acquired via other means.
SECR 65
2 Apr 2026
East Sussex
Straus
20 Jun 2025
Manchester
I'm not sure the cost benefit to engage a specialist solicitor appears to be there based on the (limited) information in this post, especially with the admission of guilt to staff.
Egg Centric
6 Oct 2018
Land of the Prince Bishops
I think there probably is actually, due to the reason we can't talk about. But I agree it's likely to be futile.
Egg Centric
6 Oct 2018
The reason we can't talk about? You mean the OP's status?
I think that the OP should go to either https://www.immigrationboards.com or https://www.reddit.com/r/ukvisa/ to understand what the likely implications of a criminal record are for both of their applications, and feed this into their evaluation of whether a specialist solicitor is worth it. We cannot advise on the former, what we can say is that the only hope of "getting off" is the specialist solicitor, and it is probably unlikely (but the only way to find out is talk to them).
Haywain
3 Feb 2013
All we have advised on here is the likelihood of a conviction and the potential means of avoiding one, something which we advise posters on a regular basis regardless of their status. What they do next is up to them.
Some of the solicitor firms I listed above may offer a free consultation.
A solicitor who doesn't offer a free initial consultation isn't worth dealing with. How else could they know if they are able to take on your case?
Isn't that the advice that we're not supposed to give?
styles
7 Dec 2014
Gwynedd
The law prohibits giving legal advice on immigration status unless we're Immigration Advice Authorities. It doesn't prohibit recommending people get advice from IAAs. OP's mileage may vary, but if my immigration status were at risk I would absolutely seek legal advice. I probably wouldn't go to Reddit as my first port of call though!
Haywain
3 Feb 2013
Thanks, but I was referring to forum policy.
Egg Centric
6 Oct 2018
My understanding of forum policy (and I'm prepared obviously to be told I'm wrong by a mod) is exactly the same as what Styles is saying - it's fine to recommend getting immigration advice, not fine to give it, and I don't consider linking to places to get said advice to be giving the advice. In the OP's circumstances of seeking citizenship soon I think it would be extremely sensible.
Cowley
15 Apr 2016
Devon
Yes we don’t have a specific policy as such, perhaps it might be something we need to add in at some point though as it does come up from time to time.
@BristolLondon - You’ll need to seek legal advice on that side of things. We can only really help with the railway case from here on.
Thanks everyone
firmbutfare
30 May 2025
Preston
The Immigration and Asylum Act 1999 defines "provision of immigration advice" as being provided "in the course of a business carried on (whether or not for profit) by him or by another person"; for the same reason people provide advice on reddit and Facebook groups, it's hard to imagine construing occasional advice from strangers on this forum as "in the course of a business" of any sort. The Act also explicitly exempts "matters ancillary to criminal proceedings" from being immigration advice.
Whether it's prudent or not to provide such advice on a rail forum is a different question, but I really don't think it is illegal.
Gloster
4 Sep 2020
Up the creek
Subsection 1 of Clause 84 of The Immigration and Asylum Act 1999 (as amended) states ‘No person may provide immigration advice or immigration services unless he is a qualified person’. The remaining subsections go on to make clear how a qualified person is defined and what exceptions there are.
Quite simply it appears to my non-legal mind that unless a poster is prepared to indicate how they qualify, they should not give advice. I doubt that many do qualify and would not expect them to state how they do (or who they are).
My feeling is that it is acceptable to indicate where such advice may be found, such as the official listings on .gov.uk. But absolutely no more.
I am not a legal expert.
