Mark IV carriages: Could TPE use them?
Segedunum
International Transport
22 Dec 2013
Up North
Does XC currently have any routes that are 100% under the wires?
The only viable flow I can think of that's wholly under the wires would be Manchester Piccadilly to Birmingham New Street. (the wires continue to Coventry and Bromsgrove but I can't see them being popular or practical termini)
gimmea50anyday
8 Jan 2013
Back Cab
XC did used to run mk2 shuttles between Man and BHM which freed up a voyager or two for other services, but that was in the bad old days of Virgin, back when there was a country wide network...
NotATrainspott
2 Feb 2013
Since TPE have already got a rolling stock solution, could the MK4 sets not find better use with XC? Even if they just worked Doncaster-Newcastle with shortened 91 sets, that would free up Voyagers for the core without any route clearance issues.
Additionally, they could then also replace (or supplement) the HST's with 67's (going cheap) and MK4 sets which would improve station dwell times and probably helps with DDA compliance too.
The ScotRail/XC/GWR HST upgrades have probably killed off any possibility of the Mk4s being used elsewhere. Extra conversions are now cheap and easy and the trains would be ready for use basically everywhere on the network. Shortened HSTs will be able to run faster and cheaper than traditional loco haulage of coaches, even with a DVT at the other end.
jopsuk
13 May 2008
As in have a 67 on one end and a 91 on the other? Would have thought that would be rather tricky to get to work. On the other hand I'd imagine converting the Mark 4 DVTs to work with 67s or 68s should be a similar job to doing the same to the Mark 3 DVTs
Roast Veg
28 Oct 2016
Unfortunately the classic idea of a 67 and Mk4 rake would be painfully slow and noisy without removing about half of the carriages.
CosherB
23 Feb 2007
Northwich
How many more times does it have to be posted that, even in crude terms, replacing a 6,500hp 91 with a 3,000hp 67 on a full Mk4 rake just isn't going to work as a viable high speed train? :roll:
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Kraków
How about three Class 67s? :lol:
D365
29 Jun 2012
It's quite mild for a SpacePhoenix 'suggestion'.
D365
29 Jun 2012
Assuming that the Mk4s and the DVTs have the same design maximum lifespan then the 225 sets will probably all go to the scrapyard as the 800s replace them
I specifically didn't mention them as they might last a little longer, seeing as they are 'passive' components.
Nym
2 Mar 2007
Somewhere, not in London
They do keep the lights on though...
And the convertors are in that nice, difficult to support dark zone of the late 80s / early 90s. Probably with NOS only caps, crowbar and main invertors...
CosherB
23 Feb 2007
Northwich
Why? Carefully looked after LHCS should last a lot longer than 35 years. Just look at Mk3s and HSTs ....
GrimShady
13 Dec 2016
Can someone explain why the MKIV is thought of as cheap rubbish and what the maintenance issues are with them?
Metro Cammell products were renowned as good were they not?
Jonny
10 Feb 2011
The interiors weren't exactly well specified, but the coaches themselves were pretty decent. They were also designed to fit the profile of a tilting train, although they were never fully equipped for it.
Roast Veg
28 Oct 2016
The 91s have been run very hard throughout their lives and are definitely at end of life, but the Mk4s have plenty of use in them to come as long as locos with a high enough ETS rating and TDM exist. It wouldn't be the end of the world if they never saw 125mph again.
GrimShady
13 Dec 2016
The original interiors were terrible but the Mallard upgrade seen to that. Id still rather travel in them than anything with an engine under the floor although as I said before being propelled sometimes can be uncomfortable.
Discussion of the 800s is off-topic. Any further such posts will be deleted. Please use the relvent existing thread or start a new thread if there is not already one available.
