Vectorspace
- Joined
- 8 Mar 2011
- Messages
- 32
There is a mark 2 coach in old Virgin Trains livery parked at Leamington, it's been there for a few weeks. Anyone know why it's there?
I was on the train and it was nearly three hours! As far as the charter train itself was concerned, thanks to the schedules charter trains are generally given, an hour was recovered between Leamington and Canterbury. Agreement was reached to depart an hour late on the return from Canterbury to give a reasonable time there, and we ended up 15 early at Banbury! It did cause a lot of disruption to scheduled services through Leamington in the morning however.Just under two hours I believe (happy to be corrected if someone has the times!).
Obviously the actual shunt manoeuvre didn't take that long, but the problem needed to be identified/inspected and a plan put in place, signallers informed etc.
The coach involved was in the premier dining section. Although the train arrived at Leamington before 0800, I believe the service of breakfast had been completed by the time they had identified the fault and decided on a course of action. As far as I know there was sufficient space in the rest of the train for the people affected. Passengers had to leave the rear part of the train during the shunt move, though the catering crew remained on board.I take it the tour was not fully booked or did everybody just squeeze up a bit?
Passengers intending to travel south from Leamington were being sent to either Coventry, Warwick or Warwick Parkway for southbound services, and those heading to Leamington from the north had to go via Banbury.Would those services that had to omit Leamington because of this have called at Warwick instead?
..Is still there apparently. In a way I'm rather surprised that it's remained there for so long, but given that it's owners are Riviera Trains then perhaps not so surprised. At this rate they could just open it up in situ and make a use of it there!
Three months later and the carriage is still at Leamington Spa.
Not three months but it's starting to rack up to an impressive 9 months by now. Clearly Riviera can't be bothered anymore! At this rate they might as well turn it into a station feature like additional waiting space or a café!![]()
Its gone. 31601 took it away about an hour ago. At 16:30 the 31, the mark 2 and a few other coaches were sat in the siding just outside the station.
Wow surprised it was in a fit state to be able to move anywhere without a crane and a lorry.
Sam
It's not beyond the realms of possibility that some on site work had been done prior to the move?
