Manchester CTLZ
ServerHoster
15 Jun 2019
North West
Hi, just wanted to check what railway stations the Manchester CTLZ ticket is valid to.
I bought a Stockport to Manchester CTLZ, would it allow me to get off at, say, Oxford Road, Deansgate or Victoria, then use the tram? I've got the more expensive "any permitted route" and not "avanti only" ticket since I would need to use a Northern service.
py_megapixel
5 Nov 2018
Northern England
Yes, that's exactly the purpose of a CTLZ ticket, it allows tram travel in the central zone (now Metrolink zone 1) from anywhere in the Manchester stations group (Victoria, Deansgate, Ox Rd, Piccadilly). Bear in mind though that there are no tram connections from Oxford Road!
However, if you need to travel outside Metrolink Zone 1 you will have to buy an additional ticket.
PupCuff
27 Feb 2020
I've no doubt there will be some debate over the technicality and minutiae of what internal NRE or the routing guide or whatever says, however in real life as long as your ticket isn't operator restricted (ie you have the any permitted and not avanti only) then you will have no problem using a Manchester CTLZ ticket to or from any of the Manchester Stations (clearly if say you were catching a connection at Piccadilly, for instance, and you'd come in from Bolton there would be no requirement to alight at Deansgate as the first Manchester Station you arrive at then walk the rest of the way to Picc) and yes, you can use the tram, but only within the city zone/zone 1/whatever it's called this week.
Fokx
19 Jul 2019
Manchester CTLZ tickets allow travel to either Victoria, Deansgate, Oxford Rd or Piccadilly
And free tram travel between the following stops:
Deansgate-Castlefield, St Peters Square, Exchange Square, Victoria, Shudehill, Market Street, Piccadilly Gardens and Piccadilly
ServerHoster
15 Jun 2019
North West
Thanks for the responses everyone. I'm already aware of the tram capabilities. Thanks for confirming I can use it at any of those 4 Manchester stations by train.
Fokx
19 Jul 2019
Just to add also, as you have purchased an any route permitted you are allowed to change at Piccadilly for example if you were intending to travel to Deansgate or Oxford Road from Stockport if you are not on a direct train
Ianno87
3 May 2015
Also Cornbrook and New Islington, also in Zone 1
David Goddard
8 Aug 2011
Ely
So assuming CTLZ is the destination on the ticket, it shouldn't get swallowed by the gates either?
David Goddard
8 Aug 2011
Ely
Thanks. Shame also this is only available in the GM area and not from further afield
Fokx
19 Jul 2019
Indeed! I always forget about New Islington and Cornbrook was interestingly only added to what is now the former ‘city zone’ a few years ago when the zones became numerical (which makes a lot of sense as it’s frequently used as a terminus for when things go dramatically wrong with the network along with Castlefield)
Fokx
19 Jul 2019
Yep, hence me having to “split ticket” from my local station to Stockport. Still cheaper than getting a Manchester Stations ticket then Tram travelcard, though.
Are you aware that you can buy single/return ticket from booking offices directly to Metrolink Zone 1 with train to tram ticketing system of outside of GM?
I can’t say if it will be cheaper or not however!
ServerHoster
15 Jun 2019
North West
No, I didn’t know that! But, the ticket office will be closed before I get to the station.
Fokx
19 Jul 2019
If you ever require it again from outside of Manchester, the person selling you the ticket (guard or office) can simply sell a ticket from XXX to ‘GM Metrolink zone 1’ (or additional zones as required).
It’s not well known but it’s something I’ve recently been taught to sell with TPE that comes in particularly handy for leisure travellers with the new Trafford Centre Line!
Ianno87
3 May 2015
I don't believe any Railcard discounts are available on through tickets, however.
Ianno87
3 May 2015
Which gateline? I've heard Oxford Road and Victoria will swallow them but Piccadilly won't (don't quote me on that)
Fairly sure I stuck one through the Victoria barriers not too long ago, and it was returned.
ServerHoster
15 Jun 2019
North West
496F2F2C-A8BF-438F-A8E4-FB40F6EC1423.jpegF52B4EA6-15C9-4469-A461-65492086D222.pngI have found something interesting on Trainline. When you do a Cheadle Hulme - Manchester CTLZ CIA Deansgate, it advises you to go to Piccadilly, change for a tran to Deansgate then double back to Piccadilly. Just a weird bug I wanted to share.
CHESHIRECAT
27 Jul 2010
Just a random thing on TPE..it doesn't show the Transport for Wales only fares for Crewe and other stations to Manchester.. Annoying as I use their app as it gives Nectar points!
