Low-speed, empty stock derailment at Bletchley (26/06)
Harpo
21 Aug 2024
Newport
Yes. Two of the switches of a diamond could divert and likely derail, due to the dog leg turn, if misaligned. Limiting the distance limits the running time from the moment the last check of the mechanism was conveyed to the driver when passing the clear signal to encountering the facing switches.
Thanks for that.
MadMac
13 Jun 2008
Moorpark, CA
I’m aware of an instance where someone tried that with a ballast train: unsurprisingly, it didn’t work.
LowLevel
26 Oct 2013
So does 9821 just read for a route to line R1? Would one approach 9753 from lines R1/R2 via the crossover that is immediately prior to the junction with the US?
My direct knowledge is based on the resignalling of the Bournemouth line, but I am sure that flexibility on the GN&GE was mentioned during a tour prior to the commissioning of the resignalling at Lincoln - I must have misunderstood the exact flexibility they were referring to (it is some time ago now!).
As far as I know the extra signals on the GNGE serve two purposes, one is to turn back trains via signalled moves over crossovers if necessary, and the second is to avoid the need for a handsignalman opposite the final signal during single line working as all of the Miniature Stop Light/Automatic Half Barrier crossings are also fitted with "wrong direction" controls.
They aren't except as mentioned otherwise actual signalled long bidirectional sections.
Wilts Wanderer
21 Nov 2016
Wasn’t there a fairly recent SPAD at Stafford Trent Valley Jn where a light Class 90 successfully negotiated a set of switch diamonds without derailing and came to rest on the adjacent running line (with another train approaching the other way, luckily stopped!) That will have been a brown-trousers moment.
Northampton
jfollows
26 Feb 2011
Wilmslow
Northampton
1Z99 has moved towards 5Y26 and now disappeared of the open data maps sites, so is presumably attaching. Anybody know if it's planned to be directly hauled to a depot or if it will be simply moved out of the way for further asssessment?
Silverlinky
3 Feb 2012
Being propelled onto the relief road 2. Up Fast will be blocked to allow this move to take place.
midland1
18 Aug 2019
wigston
Just in case it has not been already said 1Z99 the loco is 37901 from Leicester. I was waiting for 0Z85 at Wigston South Jn. when this came along.
tram21
29 Dec 2022
How long are we expecting disruption due to this to last? National Rail states until the end of the day tomorrow, but is that likely given the train is being moved/ has now moved?
hexagon789
2 Sep 2016
The track is damaged though, so that will need repairing.
Annetts key
13 Feb 2021
West is best
Depends on how long it takes to restore the track so that it's fit for trains to run. Its likely that some of the point work is damaged, so not all lines may be reopened initially, or part or all of the diverging routes on or off the junction may not be available.
Plus there is likely damage to the signalling equipment. If the point work cannot be repaired or replaced and plain line is fitted instead, a temporary design may be needed for part of the signalling.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
But, no, a switch diamond has moveable point ends to make the crossing smoother, especially at higher speeds, but the crossing can only be used as a diamond crossing.
The reason behind switched diamonds is surely that, due to the crossing angle, it is possible for wheels to take the wrong path? Possibly relevant to this incident....
So am I - Haymarket East Junction?
jfollows
26 Feb 2011
Wilmslow
I don’t think the “reason behind” switch diamonds is that they might not work, they’re there for faster crossings because traditional diamonds might limit speed. But of course it’s possible that if they fail in some way what you describe might be possible. However they’ve been used for many years and they don’t fail in this way, otherwise we’d have heard about it. Slade Lane Junction near me has them and works fine.
MarkyT
20 May 2012
Torbay
The smaller the crossing angles, the longer the gap in the running surface necessary for the flange to pass through. Wheels drop further into longer gaps, creating impact damage, increasing wear to wheel and crossing, and causing a nasty jolt onboard. In extreme cases, derailment might be possible, but the ride and damage implications make very long fixed crossings undesirable on their own.
Tilting007
21 Oct 2024
Rugby
Going from the left, thats the Down Fast, Up Fast, Down Slow, Up Slow. That layout seems to suggest the move from Up Slow (in down direction) to Down Slow is impossible.
Although the layout remained switch diamonds, this picture is before the renewal last year.
Yes but that was going a lot faster and the driver reported they had derailed initially.
For sure a brown trouser moment.
Also a driver that happily posted their journeys on YouTube…. Hopefully they have reviewed this after such a serious incident where they were regularly speeding.
6Gman
1 May 2012
West Coast Main Line still struggling today (I've just left a rather crowded Manchester train with faulty air-con to add to the overcrowding).
Does anyone know why the Up Fast wasn't being used between Crewe and Stafford this afternoon?
It didn't help!
M60lad
31 May 2011
Weren't there signalling problems between Crewe and Stafford limiting how many lines could be used? Should I read something to the affect.
NSEWonderer
5 Dec 2020
Looks like the slow lines will not be open tomorrow. Heard tamper staff are out of hours so have to comeback at some point, tomorrow night.
Northampton
1Z99 is still showing on the signalling maps, so assuming the unit hasn't been cleared yet? Is the extent of the damage to the track known in full yet?
sonic2009
19 Jan 2010
Crewe
The delays caused by this incident seemed to have a knock on effect up at Crewe.
The 0708 Avanti to Manchester which starts at Crewe - usally comes ECS from Longsight, but this morning was sat in Platform 12 - ran down to Crewe Sth Jn reversed and came into Platform 6 55mins late.
Avanti Platform staff said it had been there all night. Didn't look like the train had been cleaned either.
800001
24 Oct 2015
Could be due to the OHL issues which occurred yesterday in the northern section of Wcml. Not necessarily to do with the derailment:
td97
26 Jul 2017
Correct, it was stationary on the down slow around an hour ago
andyjhatton
8 Apr 2023
Dartford
A possibly tangential question.
Much is made of the passenger number and revenue figures.
How is delay repay factored into these?
I imagine many trevellers will have had free or much reduced fairs over the past few days.
If the railway can't actually run its timetable and everybody is travelling for free, makes you think.
(I've enjoyed a fair few cheap journeys over the years courtesy of the purely imaginary teimetable)
