Low-speed, empty stock derailment at Bletchley (26/06)
hexagon789
2 Sep 2016
What does ‘SSO’ mean?
Special stop order, meaning that as the services which nornally serve Nuneaton are withdrawn, special arrangements to call there in other services have been implemented.
RealTrains07
28 Feb 2019
Travelling to glasgow today and safe to say its chaos all over. Avanti seem to be cancelling every other trains to and from london. Not sure how bad its been for london northwestern?
hexagon789
2 Sep 2016
Travelling to glasgow today and safe to say its chaos all over. Avanti seem to be cancelling every other trains to and from london. Dunno how bad its been for london northwestern?
Various alterations with service groups amended to terminate/start short.
There's also now damage to the overhead wires between Preston and Lancaster, compounding earlier disruption to Anglo-Scottish workings.
Tilting007
21 Oct 2024
Rugby
The exact same set of points at Denbigh hall were ran through by a track machine during last night's engineering possession. Points were secured in normal and a further assessment was required, but not sure if that was actually undertaken.
It wasn’t the same set. The set that were run through are on the line between Bletchley High Level and Denbigh Hall South.
RealTrains07
28 Feb 2019
Yeah just heard about that after boarding the 17:21 Man to glasgow train which was already delayed. Now being terminated at preston.
james_the_xv
29 Oct 2019
West Midlands
Potential problem might come with those set of points likely being customised prefabricated, so getting a replacement in quickly if not repairable on site may take days.
That'll be the last we see of that 350, can't see the ROSCO wanting to repair it straight away if it's going to sit in storage for ages.
If 350 370 was the unit derailed (not obvious from the pictures), WMT will want it back in service, or a substitute.
It is one of the retained 350/3s.
Fast lines are open. 2Ks being caped at Bletchley, 1Ys are all over the place. 1Us are terminating/starting from MK or Rugby. Avanti doing their standard cancel 1 Brum and 1 Manchester.
WMT is a mess. Nothing calling at MKC for ages and they dropped the MKC call from the fast Northampton relief.
Late boarding of everything causing concourse congestion.
Absolutely shocking performance. Not sure what happened to the old contingencies like dropping the Tring semi fasts and breaking the service at Northampton both of which would have helped a lot.
And once again the presence of the transverse displays caused congestion in the platform tunnel.
trackam
29 Jun 2023
Midlands
Taken from a very late 1816 to Wolverhampton.
Picture shows derailed LNWR train.
westcoaster
4 Dec 2006
DTOS A or B
Is there a diamond crossing under the front unit (looking at google maps). From the video online it looked to be heading Northbound.
sad1e
26 Aug 2024
A little ironic that 350247 has a London midland golden spanner decal (see attached) considering the mess it has just caused.
Intercity_225
13 Jan 2024
March
Looks like Southern have thrown in the towel when they don't even operate to MK...
(From NRE)
An operational incident earlier today in the Milton Keynes Central area means some lines to / from Watford Junction are currently closed. As a result, Southern services running to / from Watford Junction will be revised to start / terminate at Shepherds Bush.
Disruption is expected until the end of the day.
Harrow & Wealdstone and Watford Junction will not be served.
Tilting007
21 Oct 2024
Rugby
Its a switch diamond not a fixed diamond / crossing.
No point in knocking out the Tring’s as they are unaffected.
Brum’s could be split at Northampton or spun in P2 at MKC but must be a reason why not. Can’t can all the LNRs..
Two line railway MKC to Ledburn so should be a standard service contingency in place.
It will be very tight as you would normally do Ledburn to Drayton Road.
RealTrains07
28 Feb 2019
Situation has gotten so bad north WCML, avanti are now ferrying passengers north of preston with taxis
james_the_xv
29 Oct 2019
West Midlands
From my anecdotal evidence the past year WMT control have come on leaps and bounds from a few years ago in regards to service recovery & communicating changes (my delay repay account backs this up), but I agree today was a shambles especially with the 1Ys.
My guess would be crewing issues preventing spinning at MK, but crews change at NMP so no excuse there
24 Oct 2015
All line block is going to be taken tonight between 00:01 - 05:30 to re-rail the train
londonmidland
22 Dec 2009
Leicester
Major disruption on both the north and south side of the route, due to two separate incidents which couldn't have happened at a worse time. Derailment at Bletchley and OLE damage at Garstang.
1M16 15:38 Glasgow Central to London Euston has been sat at Oxenholme for over an hour now, running over two and a half hours late. No signs of it moving anytime soon.
Sentinel
8 Dec 2019
Macclesfield
It seems it was initially cancelled due to brake problems and hence possibly flats. Returning northwards to the depot, possibly a false flange has been created due to a wheelset locking. Hence the derailment at a set of points. Luckily it derailed to the right between the slow lines. If it had derailed to the left by the same amount shown in the photos, it would have fouled the up fast with 125mph Pendolinos hurtling through. The consequences don’t bear thinking about…. The RAIB report will be very interesting, especially regarding what checks there were regarding fitness to run following the fault that caused the service to be cancelled.
Horizon22
Jobs & Careers
8 Sep 2019
(From NRE)
They may have been told to Network Rail as part of an agreed contingency plan.
Tilting007
21 Oct 2024
Rugby
The location of the derailment not being a cross over between the US and DS can’t have helped either…
Someone has some explaining to do…
