Long term plan for Chiltern's Mk3 "Heritage" rake.
route:oxford
1 Nov 2008
I travelled on the the "Banbury" rake from Marylebone to Haddenham last night. It is definitely good crowd-buster (although I would have preferred safer high back seating).
What's the long-term plan for this "heritage" rake? Is it likely to be Chilternised with power doors and perhaps upgraded with modern safer seating?
Yew
12 Mar 2011
It's hardly heritage, there are still hundreds of slam door Mk3's, and a lot of them still have IC70s
Cherry_Picker
18 Apr 2011
It is compared to the rest of the fleet and it's painted in "heritage" BR intercity livery, the refurbished Mk3 coaches really make the slam door set look old even if the interior is only a Virgin refurb from the 1990s.
route:oxford
1 Nov 2008
Up to 40 years old and two/three comprehensive refurbishments and rebuilds behind their peer stock on Chiltern.
That's heritage to me.
47802
6 Mar 2010
Well if Chiltern can get hold of some of the Scotrail 170's in the next few years they might get rid of all the loco hauled stuff, or at least the non power door rake.
XCTurbostar
13 Sep 2014
Based on the money which Chiltern has spent on those Chilternised MK3s.. I'd be very surprised if what you say actually happens. Since the 67s are being replaced by 68s with a longer contract, this suggests that chiltern obviously favors the MK3s over the 168s.
Chiltern will keep their Mk3s until the end of their franchise quite comfortably. It is a selling point over Virgin which I think is a reason to retain them. I always choose Chiltern over Virgin just because of the comfort levels.
I've said this before but I wouldn't be surprised if Chiltern swap the Class 68s/DVTs in favor of HST power cars when they become available. It would be the obvious next step for Chiltern. This would help with timings and enable them to have better acceleration to keep with unit diagrams.
Thanks,
Ross
Suraggu
23 Oct 2013
The Far North
Thanks,
Ross
Then they either spend a fortune rewiring their entire mk.3 fleet for Power Car use or spend a fortune re-engineering the power cars to supply the Chiltern Mk.3's, severely doubt that will happen.
59CosG95
18 Aug 2013
Beeston (Notts)
Since Boris' plan is to wire the Chiltern by 2024, I think the Mk3s will be around for a while yet, but the locos may change...
Hope we order Vectrons!!:D
DXMachina
24 Oct 2011
Why would they swap locomotives which can haul their Mk3 carriages for power cars which cannot? Mk3 loco hauled and HST trailers are not interchangeable, they arent even electrically compatible. Even if they managed to refit TDM to some of the buffered HST PCs from which it was removed years ago, they'd still have no ETS
[Edit] MODS - please delete this post, Suraggu made the point first and its merely an unnecessary duplication
6 Mar 2010
Thanks,
Ross
Chiltern is essentially a unit based railway and expect if they can get hold of more 170's at some point then I wouldn't be surprised if that's what they do, with the current Loco hauled stock other than building new there was little alternative at the time.
XCTurbostar
13 Sep 2014
Ill agree with you on that point.
Thanks,
Ross
CyrusWuff
20 May 2013
I stand for correction, but I believe DB own rather more DVTs and Mk3 coaches than are currently in service with ATW, Chiltern and making up the Schenker "Company Train", such that the entire Mainline service could potentially go over to loco-hauled operation in the future...
That could, of course, be a load of geriatric shoemenders, however!
47802
6 Mar 2010
If they wanted to do that why get the TPX 170's in that case?
47802
6 Mar 2010
Extra services? Anyway hasn't that plan been out on hold for now?
Well given they want them for Oxford services, the alternative would have been to get additional loco hauled stock to run either to Oxford or a Birmingham and run freed up 168's to Oxford, the fact they preferred the 170 says it all in my book.
DT611
7 Nov 2013
once the stock is life expired they will probably replace with units yes. doubt it before hand though
in that case they were going to have to get extra stock for those services, and those units came off lease, so they could go over to units for those. in the case of the current loco hauled stock they have, they have spent a lot of money on them, so they will want to get a return and get the full worth out of that refurbishment.
6 Mar 2010
Or maybe not if there are significant saving to be made by using the 170's, in any case its likely to be at least a couple of years before the prospect of any more 170's being released,
Actually you wouldn't have to re-engineer the power cars.
You could just stuff (almost) off the shelf static converters into the redundant luggage compartments of the power cars. (If a true SMPS is too pricey then a more bulky but simpler installation out of a three phase transformer and a six pulse diode rectifier would easily suffice).
Very little work to the PCs - and a new set of jumper heads would allow the AAR cables to function as HST MU cables - while the HST connector has 36 lines to the AAR's 27 only 24 of the former are actually used.
So assuming its a compliant AAR installation (all wires must be through wired on all stock) it should be fine to fit.
This is not the 1970s when the only practical means to convert between loco hauled DC/AC single phase and the three phase used by COTS equipment (like air conditioning units) was a motor-generator.
This is not even the early 2000s when the SMPS had not yet come of age (and the loco hauled Mark 3s had to be fitted with MU cables regardless) - this is now.
XCTurbostar
13 Sep 2014
I didn't think that it would involve that much work. Like I said before, it could still happen..
Thanks,
Ross
Sunbird24
26 Oct 2013
La Mont Ravana
A pair of HST power cars would drink far more fuel than than a 68/DVT combination for only a marginal increase in power (3800 HP against 4500 HP) and they can easily be uprated to 200kmh (120 mph) as per their Spanish cousins (Eurolight and class 334).
Old diesel stock of any sort is very thirsty and expensive to maintain when compared to modern products, especially when they come with lengthy maintenance contracts.
capital12
20 Aug 2012
I don't want to seem rude but if your first concern is how safe the seating is then to me that implies every time time you board a train you think you're going to crash?! Maybe train travel isn't for you?!
I'd prefer a comfy seat over a supposedly safer, but much more uncomfortable seat, any day as I don't expect to crash whenever I travel by train!
Reminds me when I worked at sea and there was a very slight swell causing a little movement of the ship - but there was one old lady sat in the restaurant with her life jacket on! If she was that worried about sinking I don't think cruising was really for her!
They aren't just for Oxford services though. There is a simultaneous project going on to increase the length of existing services between Banbury and Marylebone up to 9 car.
47802
6 Mar 2010
Yes and doesn't that add up to more units for a unit based commuter railway which is the most suitable rolling stock for the line.
Ideally you would think this line ought to be a high priority for electrification which would be the most suitable option.
DT611
7 Nov 2013
those loco hauled carriges won't be going anywhere until they get a return on the investment they put into them at least. they may even keep them as a USP. we'l just have to wait and see.
apk55
7 Jul 2011
Altrincham
A class 68 has about twice the tractive effort of two HST power cars so it would be much quicker starting from a stop. This would be a usefull atribute when compeeting for space on congested urban networks.
What state the HST power cars are in I do not know, but many could many could be in need of extensive refurbishment. I could well see a controled rundown of the fleet with the worst examples being scrapped.
47802
6 Mar 2010
I expect the investment they put into then was peanut's in the grand railway scheme of things, so if other costs override them it wont matter a bean.
Apart from the power doors a lot of the refurb for these trains was done under Wrexham and Shropshire anyway.
route:oxford
1 Nov 2008
How can you possibly have comfort if there is nowhere to rest your head? IC70 seating is only suitable for people of limited stature.
The safety is limiting the movement of the head in rapid deceleration or acceleration. You don't have to crash to be injured.
Sunbird24
26 Oct 2013
La Mont Ravana
The linear (fore and aft) acceleration forces which a normal human can withstand safely are +17 to -7 acceleration units. Accelerating and braking trains get absolutely nowhere near these figures. Lateral (sideways) figures are much lower but a high seat back will have no effect on that.
Millions of people travel daily in light weight metros and trams which have sideways mounted seating only and start and stop with considerably more force than most heavyweight trains which have controlled acceleration and braking, of the order of 2m/s squared, which is absolutely harmless.
To put this into context, 1 acceleration unit is very roughly 0-100 MPH in 5 seconds, the average healthy human should be able to withstand an acceleration of 0-300mph in 1 second when facing forward.
